    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    529 Posts 101 Posters 588.5k Views 99 Watching
    • O
      optimaforever @VD20
      @VD20
      I already reported this error earlier.
      • O
        optimaforever
        May we expect a fix for this issue between D5 render livesync and LOTT?
        panixiaP 1 Reply Last reply
        • panixiaP
          panixia @optimaforever
          @optimaforever man, check your n inbox đź‘»
            MarissaW
            For some reason while trying to set up my toolbars, my V-Ray tool sets do not show up in the Master Toolbar Manager. It seems like almost everything except that shows up.
            Is there something specific I need to do to get it to show?
            Using SketchUp 2026, version 26.0.429
            Thank you!
            fredo6F 1 Reply Last reply
            • fredo6F
              fredo6 @MarissaW
              @MarissaW said:
              Thank you!
              Nothing you can do. I had to remove VRay from the list of icons because VRay does something to precisely avoid indirect calls (liek LOTT does).
                dlannetts
                I don't particularly use D5 Render LiveSync, but just wanted to note that I had to remove it for this plugin to function.
                • fredo6F
                  fredo6 @dlannetts
                  @dlannetts
                  Could you tell me what is the name of the main folder of the D5 extension. I don't have it.
                  Then I can exclude it from LOTT.
                  • fredo6F
                    NEW RELEASE: LordOfTheToolbars v3.0a - 21 Apr 26
                    Requirements
                    • LibFredo6: v15.9b or above
                    LordOfTheToolbars 3.0a is a maintenance release including:
                    • Bug fixing
                    • Future compatibility
                    Home Page of LordOfTheToolbars for information and Download.
                    Main post of this LordOfTheToolbars thread.
                      JanSteinman Newcomers
                      It is not able to run on my SketchUp 2025. (And SketchUp 2026 won't run on my machine for some reason…)
                      • fredo6F
                        fredo6 @JanSteinman
                        @JanSteinman
                        Did you upgrade LibFredo6 to v15.9b?
                        J 1 Reply Last reply
                          Yes.
                            JanSteinman Newcomers @fredo6
                            @fredo6 What do I need to do to get out of Sketchucation jail?
                            Moderators are holding my postings for FOUR DAYS before putting them up here!
                            When you pay money for a product, I consider this lousy service! I know developers are busy, and I'd be quite forgiving, but demanding FOUR DAYS before a developer can even see my answer to their question is insane!
                            panixiaP 1 Reply Last reply 👎
                              joiner
                              Hallo, bei mir werden nur einige Iconleisten im Sketchup-Native Commands angezeigt, obwohl ich viel mehr habe. Auch bei Fredo wird nur die LOTT-Tollbar angzeigt, obwohl ich FredoScale gekauft und instaliert habe (Sketchup 24) Wie kann ich das ändern ? Gruss Joiner
                              Hello, I only show some icon bars in the Sketchup-Native Commands, although I have a lot more. Also with Fredo only the LOTT-Tollbar is displayed, although I bought and installed FredoScale (Sketchup 24) How can I change that ? Greeting Joiner
                                joiner
                                Sorry, nach mehreren Starts von Sketchup war plötzlich soweit alles in Ordnung. Schönen Tag noch.
                                Sorry, after several starts of Sketchup, suddenly everything was fine. Good day yet.
                                • panixiaP
                                  panixia @JanSteinman
                                  Isn't Lord Of The Toolbars free??
                                  • fredo6F
                                    I don't know what you mean by Sketchucation 'jail'. And as Panixia said, LOTT is free.
                                    Anyway, the trouble might be in the habitat_site_context.rb script, as shown in the Sketchup startup error box..
                                    Did you get an error with the previous version of LOTT and this script installed?
                                    • N
                                      nicolasberthier
                                      Bug Report: SU2026 / Fatal crash on startup with D5 Render LiveSync (Errno::EISDIR)
                                      Hi Fredo,
                                      The last update doesn't fix the D5 issue. Either way, we can only use one of them (LOTT or D5 Render). So now my entire workflow is blocked, and so is the workflow of other D5 and LOTT users. We really need a QUICK fix for this, please.
                                      I am reporting a fatal initialization crash occurring on SketchUp 2026.1.2 when using the latest D5 Render LiveSync plugin alongside Lord of the Toolbars (v3.0a) and LibFredo6 (v15.9c).
                                      The Master Toolbar (yellow wheels) becomes completely unresponsive, and all custom toolbars disappear from the screen.
                                      The Ruby Console highlights an unhandled directory scanning error in lordofthetoolbarsmanager.rbe inside the ghost_command_register method. It appears the script tries to open a sub-directory as a file, throwing an Errno::EISDIR exception.
                                      The main folder causing the issue is d5_converter, located at:
                                      %AppData%\Roaming\SketchUp\SketchUp 2026\SketchUp\Plugins\d5_converter
                                      Exact stack trace:
                                      #<Errno::EISDIR: Is a directory @ rb_sysopen - c:/users/[username]/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/d5_converter>
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2290:in `initialize'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2290:in `open'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2290:in `copy_file'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:1088:in `copy_file'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:887:in `block in cp'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2481:in `block in fu_each_src_dest'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2497:in `fu_each_src_dest0'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:2479:in `fu_each_src_dest'
                                      C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/FileUtils.rb:886:in `cp'
                                      c:/users/[username]/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:733:in `ghost_command_register'
                                      c:/users/[username]/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:1361:in `command_register'
                                      Temporary Workaround found:
                                      Renaming the d5_converter folder to _d5_converter allows LOTT to load correctly, but it completely breaks the D5 LiveSync connection. Downgrading D5 LiveSync to v1.6 also works.
                                      It seems a simple check to skip directories (like File.directory?) during the ghost_command_register file loop would prevent this crash.
                                      Thank you for your work!
                                      • N
                                        nicolasberthier
                                        Hi Fredo. This critical compatibility issue has been documented for several months. It entirely blocks the workflow between LOTT and D5 Render for all users. An urgent patch is required to restore basic functionality. Please prioritize this fix.
                                        • fredo6F
                                          Can you try LordOfTheToolbars v3.0b, just published.
                                          I don't have D5 installed and I don't really understand why it creates problems with LOTT.
                                          • N
                                            nicolasberthier
                                            Thank you but this fix still doesn't work. You can have D5 for free at https://www.d5render.com/download
                                            To understand and reproduce the issue:
                                            1. Install the free D5 LiveSync plugin for SketchUp.
                                            2. It generates a folder named d5_converter inside the SketchUp Plugins directory.
                                            3. Start SketchUp.
                                            4. LOTT scans the Plugins directory, encounters the d5_converter folder, and attempts to open it as a file.
                                            5. This triggers the fatal Errno::EISDIR exception in lordofthetoolbarsmanager.rbe (ghost_command_register).
                                            The script requires a bypass condition (e.g., next if File.directory?(path)) when reading the plugin directory contents.
                                            • D5 Render : https://www.d5render.com/download
                                            • D5 LiveSync for SketchUp : https://www.d5render.com/livesync/sketchup
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 25 / 27
