    [Plugin] Extension Material Replacer
    1 Cross-posts 20 Posts 5 Posters 842 Views 5 Watching
    • BerserkB Offline
      Berserk
      Hi everybody!
      I am pleased to present my first Sketchup extension.
      This is an advanced synthesis of two already existing great plugins Global Material Changer and Material Tools, plus a few of my ideas.
      Here are functions:
      1 - Filtering by lists of replacement and new material
      2 - The ability to select materials with a pipette
      3 - Work globally or only on selected objects
      4 - The ability to isolate the selected by making it unique. At the same time, the connection between the copies of the components inside the selection remains
      5 - Rubber web dialog
      6 - When selecting the "Unique" mode, the object isolation operation is displayed withe a progress bar
      Many thanks to authors of GMC and MT.
      My main activity is large architectural design, and thanks to AI I was able to create tools for work and just as a hobby.
      If errors or suggestions are found I will try to update ASAP
      The plugin was written for SU 2026 on Windows 10/ 11.
      Launches from the Extension menu - Ultra Material Change
      I'm ashamed, but I haven't figured out how to properly upload plugins here yet! Can someone please tell me?
      ultra_mat_change.rbz
      KrassK 1 Reply Last reply Reply Quote 2
        These AI vibe coding extensions are getting pretty solid. Amazing to see what people are creating.
        If you want to add it to out ExtensionStore let me know.
        BerserkB 1 Reply Last reply Reply Quote 0
        • BerserkB Offline
          Berserk @Rich O Brien
          @Rich-O-Brien Thank you! I'm ashamed, but I haven't figured out how to put the plugin there yet! Can you tell me?
            No need for shame. It is not accessible directly.
            I have reset some privileges on your account to give you access. You need to sign out of your account.
            Then visit Sketchucation.com homepage and login. You should see Dev Tools in the header.
            Have a look there. Extensions need to be approved before going live but feel free to look around.
            BerserkB L 2 Replies Last reply Reply Quote 0
            • BerserkB Offline
              @Rich-O-Brien Thank you a lot! I was able to Dev Tools and will study it!
              • Didier BurD Offline
                Didier Bur
                Thanks for this smart plugin!
                FYI it works on SU2023.
                Regards
                DB
                1 Reply Last reply πŸ™ Reply Quote 0
                  LAGAUCHI Newcomers @Rich O Brien
                  @Rich-O-Brien
                  Hi Rich, apologies for jumping into this thread! I noticed you were helping with developer privileges here.
                  I also submitted a request a few days ago (via email and PM) to set up a vendor account and access the Dev Tools for my new plugin, "Area Divider Plus".
                  Could you please check my account as well when you have a free moment? Thank you so much for your help!
                  • KrassK Offline
                    Krass
                    very good, this is what I was looking for, whereas Material Replacer changes all the model colors! Thanks!
                    Krass
                    • KrassK Offline
                      Krass @Berserk
                      this won't work on my SU 2024...
                      Sketchup says in the entity information that they are still the same components, but in reality they are no longer linked; the geometry modifications I apply after choosing the Deep Unique mode to change the color do not take effect....
                      Krass
                      BerserkB 2 Replies Last reply Reply Quote 0
                      • KrassK Offline
                        Krass
                        It's a shame it doesn't take into account the scale and orientation of the materials, or that these have been modified. Would that be possible?
                        Krass
                        • BerserkB Offline
                          Berserk @Krass
                          @Krass Thanks for the report, I'll see what I can do about it.
                          • BerserkB Offline
                            Berserk @Krass
                            @Krass yes, that would be good and right. I'll try to add it next weekend.
                            • BerserkB Offline
                              Berserk @Krass
                              @Krass Hello! Can you please make a video of it wrong work of the extension? I don't see problems in my Sketchup 2026, but I can just misunderstand you.
                              • BerserkB Offline
                                Berserk
                                Updated the Material Change plugin. Changes:
                                • Added the ability to replace several materials at a time (using a selection in the list or with a pipette when pressing Ctrl)
                                • Now the plugin can save texture transformations or reset them.
                                • Added a reset button for selecting old materials so as not to uncheck manually.
                                • Hints have been added to the status bar at the bottom of the sketchup window to understand whether you are currently choosing old or new material.
                                • Now the plug-in window will not close after pressing Apply (convenient when you need to make several substitutions in a row)
                                • I drew my own eyedropper, otherwise I used to have a pencil))))
                                Material Change v02.mp4
                                Urasik Material Change v02.rbz
                                • KrassK Offline
                                  Krass
                                  parfait, wonderfull ! Un grand merci, thank you !
                                  Krass
                                  1 Reply Last reply 🀝 Reply Quote 0
                                  • KrassK Offline
                                    Krass
                                    I have the impression that the function I wanted isn't available: I want to be able to preserve the mapping of a modified texture.
                                    For example, I have a texture A that I apply and rotate 90 degrees.
                                    I have a textured geometry with B onto which I want to be able to apply the modified texture A, already rotated 90 degrees.
                                    Is this already possible with your update? I can't seem to get it to work. I did manage to preserve the mapping on texture B after applying texture A.
                                    Krass
                                    • KrassK Offline
                                      Krass
                                      video example
                                      SketchUp_DKYU631sqm.mp4
                                      Krass
                                      • BerserkB Offline
                                        Berserk @Krass
                                        @Krass Thanks for the video! Attach this part of your model, please, I'll make some tests.
                                        • KrassK Offline
                                          Krass
                                          I can send a skp file with two textured rectangles if you want..
                                          test textures.skp
                                          Krass
                                          • BerserkB Offline
                                            Berserk @Krass
                                            @Krass Now i understand what's goin on. You need the material you are changing to to convey your transformations. It only makes sense for rotation. For this purpose, it is better and more right way to use additional extensions such as Eneroth Texture Positioning Tools already on the target geometry, or make a new material with rotated texture (in any external image editor) and then use my plugin.
