    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F
      New Release: Animator - v4.6a - 18 Dec 25
      Requirement: LibFredo6 v15.6
      Animator 4.6a is a maintenance release for:
      • Extension of validity
      See plugin home page of Animator for Download of RBZ from the PluginStore.
      See Main Post of the Animator thread for more information.
      • ntxdaveN
        ntxdave
        I would like to create an animation that looks like I am writing something or drawing something. Is there a way to do that with Animator?
        Press F1...thank me later
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @ntxdave
          I am suddenly having interface problems. I cannot control how the timeline looks/is located and some other user information is not all visible for me.
          Here is a view of the timeline, and no matter which thing I click on, I cannot get the timeline to show up vertically (which used to be the default and the way I like it the best). Here is a view of how it currently looks: Screenshot 2026-01-03 095627.png
          Here is another image that shows the Animator default settings. Notice that at the bottom, not everything is showing (at least as far as I can tell) and there is no option for me to scroll so that I can see what is below (if anything). Screenshot 2026-01-03 095301.png
          I also have been having a problem trying to select multiple items to make part of a clip (or how to add things to an existing clip).
          I have tried shutting down SketchUp and Animator multiple times to see if restarting or selecting models where I had some existing Animator animations to see if that would have any effect and it did not. I have also reported these problems (at least some of them). in this thread https://community.sketchucation.com/topic/164682/scene-animation-with-animator/29
          OK, I just went back to SU 2025 and tried to create a new Animator file with 2025 and am having the same issues with the Animator UI. I first had to update Animator in 2025 and then I restarted SU and as I just said, I am seeing the same issue with the Animator UI.
          What the heck am I/have I done wrong?
            Please hover these UI buttons:
            These allow you to position the UI
            • ntxdaveN
              ntxdave @Rich O Brien
              @Rich-O-Brien Thanks, @rich-o-brien, clicking on the yellow bar solved the problem for me. πŸ‘ πŸ‘
              Now I have to solve the problem of how to combine multiple sequences (movements) into a single Clip. When I try to use the shift key to select multiple items and put them into a clip, it does not work. Also, if I have a clip, how to I add additional items to it?
              I watched @fredo6 tutorial (Tutorial 1), I thought I understood how to combine items, but I must be missing something. I think (at least for now) figuring this issue out will help me make a lot of progress to where I want to do.
              As I have said before (in multiple threads/posts), I appreciate the feedback and patience from you. I have tried to watch videos and read some stuff to understand these issues on my own. Maybe I am just getting to old learn how to do things. 😲
              DUH I just figured out the combining issue. I used the Ctrl key to select multiple items instead of the shift key a LALa, it worked. πŸ‘
              Reply Quote -1
              • ntxdaveN
                ntxdave
                OK, I think I have finally figured out all of the tricks I need to make a video with Animator.
                Here is an example
                Model View.mp4
                Yes the video/model is pretty basic but through it, I think I have learned how to accomplish the things I want for some upcoming Animator generated videos.
                I just have one last silly question; how do I set the location for where the video is created (folder name and location).?
                • ntxdaveN
                  ntxdave
                  Is it possible to start a new thread or category for asking "how to" questions for Animator. I think I have recently learned a lot of very useful information, but I still have a number of questions that I have not been able to find answers to. Yes, I can do a lot of testing but there are topics where other users might be able to provide good feedback/advice for.
                  • ntxdaveN
                    ntxdave
                    I am suddenly getting a message that my license expired on 23 Jan 2026 and I do not know how to update/get it working again. Right now I cannot use Animator.
                    • ntxdaveN
                      ntxdave @ntxdave
                      I am suddenly having a problem generating a video. When I click on the link to generate a video, nothing is happening.
                      Here is the file I am trying to use to generate a video. Hope someone can either generate a video for me, or look at my file and tell me what is happening.
                      3 Scene Animator.skp
                      fredo6F 1 Reply Last reply
                      • fredo6F
                        fredo6 @ntxdave
                        @ntxdave
                        Can you open the Ruby console.
                        • ntxdaveN
                          ntxdave @fredo6
                          @fredo6 Right now I am having a problem with my laptop and cannot doe things as normal. I will try to get back to you when I have things under control agaon.
                          • ntxdaveN
                            ntxdave @ntxdave
                            Here is the ruby console when I clicked on the Generate Video button.
                            • fredo6F
                              When you report a Ruby error, please copy the text in the Ruby console from the Error line and paste it as text here in the forum. This screenshot can be exploited.
                              • ntxdaveN
                                ntxdave
                                There was no error message so I shared what I saw. I fully understand what you are saying though. πŸ‘
                                Any idea why I am not getting a video though?
                                • fredo6F
                                  Yes there is an error as shown in your screenshot.
                                  Simply, I miss the beginning of the error message.
                                  By the way resize to lower part of the console to the minimum (one line). The upper part is for the display of messages.
                                  • ntxdaveN
                                    ntxdave
                                    Is this what you are looking for?
                                    fredo6_animator/animatorpalette.rbe:820:in `block in palette_clip_name_duration_video'
                                    c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:in `execute_button'
                                    c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:in `onLButtonUp'
                                    c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in `onLButtonUp'
                                    c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:1293:in `onLButtonUp'
                                    • fredo6F
                                      Better but I need the top message starting by 'Error...'. This is where the error is stated.
                                      • ntxdaveN
                                        ntxdave @fredo6
                                        @fredo6 said in [Plugin] Animator - v4.6a - 18 Dec 25:
                                        OK, here it everything that is in the top box
                                        #<NoMethodError: undefined method custom_convert_id' for Traductor::ChromiumWdlg:Class> c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:159:in cid'
                                        c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:44:in initialize__' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6weblist.rbe:33:in initialize'
                                        c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in new' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in job_dialog_select_repair'
                                        c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1641:in job_detect_repairing' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:2293:in movie_clip_generation'
                                        c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorpalette.rbe:820:in block in palette_clip_name_duration_video' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:in execute_button'
                                        c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:in onLButtonUp' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp'
                                        • fredo6F
                                          Which version of LibFredo6 do you have?
                                          • ntxdaveN
                                            ntxdave
                                            I thought I had the latest version. It says I am up to date. I will have to go to my laptop to find out. Where is the best place to check?
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 28 / 30
