    [Plugin] FredoSection - v1.5c - 30 Jan 26
    44 Posts 15 Posters 9.7k Views 15 Watching
      Rich O Brien Moderator @FlorinAp
      @FlorinAp said in [Plugin] FredoSection - v1.3b - 27 Dec 25:
      Fredo Section is the most advanced and complete tool for sections in SketchUp, but... it is almost unusable at this time - one time works (barely), and 3 times doesn't work... at all...
      It still needs a lot of work.!
      I'd be more specific with regards 'doesn't work at all'?
      • F
        FlorinAp
        Well, at first i didn't want to bother you with my answer, but then i said this may help improve extensions and SketchUp.
        "at all" means nothing.!
        First time it worked well, till the end, but i was just playing and testing...
        But then, you see the mouse taking the commands from the toolbar, the prompt is correct, and nothing happens, nothing in your model/objects, the "gizmo" that Fredo created is visible, but it doesn't do nothing, sometimes you just have to open a new file, or restart SU, and it works again, but most of the times... DON'T work that way either (and the last version is totally null).
        This extension is a true spectacle that Fredo created, but i wouldn't use it, even when it will work, and i will tell you why.
        This idea of coipes over copies over copies is a very bad one, Sim Joubert tried it first (with his Sectionbox), and his plugin works every time, except when you have more than one scene πŸ˜€
        I once had a 2-room kitchen furniture, each room with about 10 meters length of furniture, and all the doors had very complex profiles, everything visible was complex profiled.
        Bottom line - at the end, i couldn't believe that by opening model info, i saw millions of entities, in only 2 rooms of furniture.
        I dont even wanna try to imagine what would happen if i open that model, and create sections with Sectionbox, or FredoSection.
        At first i thoughtt that this is the only way (copies over copies...), until i bought Curic Boxview - i don't know what this guy did (because is totally counteintutitive.!), but the model is clean, this extension doesn't create any extra geometry, only a hidden group of sections, and it works easy and simple, every single time, and works in scenes...
        • fredo6F
          @FlorinAp
          Thanks for signaling the problem which was inadvertedtly introduced with version v1.3b, only for the Section Box Outside. I have fxed it and will publish an update soon. It works fine for the Section Box Inside.
          Note that all plugins doing section box have to pile up a hierarchy of dummy groups to enclose the 6 section planes. However, there is no copy of the original geometry, but instance of it, so that any change in the section box mode is done on the original geometry. This is illustrated in the video:
          At least this is how it works in FredoSection, and most likely in Curic SectionBox (I don't know for SJSectionBox).
          • fredo6F
            NEW RELEASE: FredoSectiont v1.4a - 08 Jan 26
            Requirements
            • LibFredo6: v15.8a or above
            • Sketchup version: SU2026 and above
            FredoSection 1.4a is a major release including:
            • Bug fixing for Section Boxes
            • Introduction of Pattern Modes (container and/or Tag) and the possibility to assign patterns to tags, as shown in the video below.
            Home Page of FredoSection for information and Download.
            Main post of this FredoConnect thread.
            • fredo6F
              NEW RELEASE: FredoSectiont v1.5a - 15 Jan 26
              Requirements
              FredoSection 1.5a is a maintenance release including:
              • Major bug fixing (issue with displaying the Color Selector)
                sayerdesign
                I've been working with the plugin today on a series of drawings for some cabinetry.
                Curious if there's a way to add to the Vector hatching library or if that's not something that can be customized? There are a number of materials (plywood, solid wood, stone, etc...) that I'd like to have Vector hatches for.
                Thoughts?
                • fredo6F
                  @sayerdesign
                  Currently, the Vector hatching is not customizable but I can easily add any type of hatching, including with dashed lines, multiples, etc.....
                  For a general customization of vector patterns, this should be possible based on providing a repeatable component.
                  However, I am interested in seeing the kind of patterns you want for plywood, solid-wood and stone, and why raster images would not work.
                  • G
                    Gjenio
                    Adding more standard vector hatch types (ANSI) would be a huge time-saver for me. Currently, LayOut doesn't export them as vector entities, which I need when collaborating with other offices
                      There are a lot of ANSI vector hatch patterns...
                      Here are 900+ paid -
                      https://www.etsy.com/uk/listing/1602392539/900-autocad-hatch-library-2d-cad?ls=r&external=1&rec_type=cs&ref=landingpage_similar_listing_top-5&pro=1&dd=1&content_source=c2a30f16a8732b6e51f219c67c46c892%253ALTc4ad72921e17107e0a3f67f035a6ecc77a3039a0&logging_key=c2a30f16a8732b6e51f219c67c46c892%3ALTc4ad72921e17107e0a3f67f035a6ecc77a3039a0
                      These are free -
                      https://www.cadblocksdwg.com/hatch-patterns-download.html
                      Perhaps suggest a base set of say 16 patterns ?
                      If they can add their own patterns it's then down to each user ?
                      • fredo6F
                        I am not familiar with the DWG export from layout.
                        My understanding is that:
                        • Sketchup only uses Raster material. There is no such concept as Vector pattern. Otherwise, this is just linework.
                        • Layout renders the Sketchup model based on these Raster materials and treats them as images. I am not aware that Layout would convert them to vector.
                        • Layout seems to have a concept of Pattern which can be used for filling shapes. That may well be converted to vector patterns (.pat) when exporting to DWG. However, my understanding is that this only applies to shapes created and painted in Layout, not coming from the 3D model.
                        • FredoSection Vector Hatching is just a set of edges and faces, as the rest of the geometry. So, it renders as such in Layout. But I don't think it will end up as CAD patterns when the Layout document is exported to DWG.
                        I don't know if I am correct....
                          sayerdesign
                          Thank you, all, for picking up this dialogue.
                          First off, I should give my thanks and gratitude to Fredo6 for making this plug-in happen. Thank you!
                          For my workflow, I avoid using anything but the Vector setting for scenes in Layout, and I don't use a style that shows the textures unless it's abosolutely needed . Raster doesn't handle lines well and is 'fuzzy'. The Rastor materials included look great in Sketchup, but don't translate over to Layout. When I tried a hybrid compromise, the Rastor section fills become blurry and not very useful.
                          I'd be more than happy to give examples of hatch patterns I'd love to see available for the types of materials I use creating drawings for cabinetry (in addition to the Vector patterns currently available at least four different types of sheet goods, three types of solid wood, plaster/gypsum and stone countertops would all be fantastic).
                          If it's something that's doable with relative ease for you, Fredo, how can I help?
                          • fredo6F
                            Raster materials often look blurry in Layout (especially when you zoom). However, when you print the document on paper at the correct paperscale, you get a readable pattern visually.
                            Anyway, to help progressing, I would suggest you post a few images of you vector patterns (e.g. four different types of sheet goods, three types of solid wood, plaster/gypsum and stone countertops).
                              sayerdesign
                              Here's a group of them that were on the https://www.cadblocksdwg.com/hatch-patterns-download.html website that TIG shared previously. If this group were avaiable, that would be great so far as I'm cencerned.
                              • fredo6F
                                Getting these patterns as Vector is technically feasible, at least by me in FredoSection.
                                However, if you use them in a real model, that would represent a lot of lines (and a longer time to decoarte cut faces). Keep in mind that in FredoSection, a Vector pattern is just drawing edges in the model. Already with simple hatches, you have a lot of geometry created.
                                As suggested, could you try with these patterns in Raster (most of them are in the standard materials, under 'Patterns') and check they print correctly when the proper paperscale is set in Sketchup scenes and corresponding Layout viewports.
                                  slbaumgartner
                                  I just got these errors reported in the Ruby Console when I opened a new model on my Mac (SketchUp 2026, macOS 26.2). Looks like a bug in handling MDI on the Mac:
                                  <NameError: uninitialized constant F6_FredoSection::FredoSection>
                                  /users/steve/library/application support/sketchup 2026/sketchup/plugins/fredo6_fredosection/bootstrap_fredosection.rbe:579:in `switch_model'
                                  /users/steve/library/application support/sketchup 2026/sketchup/plugins/fredo6_fredosection/bootstrap_fredosection.rbe:459:in `model_changed'
                                  /users/steve/library/application support/sketchup 2026/sketchup/plugins/fredo6_fredosection/bootstrap_fredosection.rbe:391:in `onActivateModel'
                                  • fredo6F
                                    NEW RELEASE: FredoSectiont v1.5b - 26 Jan 26
                                    Requirements
                                    FredoSection 1.5b is a maintenance release including:
                                    • Bug fixing for Mac
                                      slbaumgartner
                                      And another error popping up in the Ruby Console on my Mac:
                                      #<NoMethodError: undefined method dialog_close_all' for #<F6_FredoSection::Common:0x00000001738b4f10>> /users/steve/library/application support/sketchup 2026/sketchup/plugins/fredo6_fredosection/bootstrap_fredosection.rbe:587:in close_model'
                                      /users/steve/library/application support/sketchup 2026/sketchup/plugins/fredo6_fredosection/bootstrap_fredosection.rbe:472:in model_changed' /users/steve/library/application support/sketchup 2026/sketchup/plugins/fredo6_fredosection/bootstrap_fredosection.rbe:390:in onOpenModel'
                                      • fredo6F
                                        NEW RELEASE: FredoSectiont v1.5c - 30 Jan 26
                                        Requirements
                                        • Another bug fixing for Mac
                                        S 1 Reply Last reply
                                          slbaumgartner @fredo6
                                          @fredo6 I installed the recent second version of 1.5b. When I quit SketchUp on my Mac, a whole flock of messages appear in the Ruby Console. Unfortunately, they flash past so quickly that it is not possible to read them, but the little I am able to spot seems to say they are coming from either libFredo6 or FredoSection. Are these (could they be) logged in a file somewhere so that they can be examined?
                                          • T
                                            TonedF
                                            Can you make it work in 'Hidden Line Mode' or 'Shaded using all the same' or 'Shaded mode' please?
                                            fredo6F 1 Reply Last reply
                                            • 1 / 3
