    [Plugin] FredoSection - v1.5c - 30 Jan 26
    42 Posts 14 Posters 8.2k Views 14 Watching
    • fredo6F
      NEW RELEASE: FredoSectiont v1.3b - 27 Dec 25
      Requirements
      • LibFredo6: v15.7a or above
      • Sketchup version: SU2026 and above
      FredoSection 1.3b is a maintenance release including:
      • Adjustments for Section Boxes
      Home Page of FredoSection for information and Download.
      Main post of this FredoConnect thread.
      • N
        Neodimium
        Hi.
        Is there similar tool for SU2017?
        And it doesn't need to be so advanced.
        TIGT F 2 Replies Last reply
          TIG Moderator @Neodimium
          @Neodimium said in [Plugin] FredoSection - v1.3b - 27 Dec 25:
          Hi.
          My free SectioncutFace extension is compatible, it lets you apply a material to a simple section-cut face. If you unlock its group you can manually change its material. However, the material is not reliant on the cut container and manual changes are lost if the section is ever changed/remade. So this Fredo's new toolset is like its big, smarter brother...
          • F
            FlorinAp @Neodimium
            @Neodimium Yes, there is Curic Section Lite
            Reply Quote 2
            • N
              Neodimium
              Thank you guys. And happy New Year.
              I'm little lost since it was more than 10 years I used any plugins.
              And I started now, just for fun. Lot of things changed. Not for the better. (trimble)
              But at least community is still alive and that's what's keeping SU alive.
              F 1 Reply Last reply
              • F
                FlorinAp @Neodimium
                @Neodimium Fredo Section is the most advanced and complete tool for sections in SketchUp, but... it is almost unusable at this time - one time works (barely), and 3 times doesn't work... at all...
                It still needs a lot of work.!
                  Rich O Brien Moderator @FlorinAp
                  @FlorinAp said in [Plugin] FredoSection - v1.3b - 27 Dec 25:
                  I'd be more specific with regards 'doesn't work at all'?
                  • F
                    FlorinAp
                    Well, at first i didn't want to bother you with my answer, but then i said this may help improve extensions and SketchUp.
                    "at all" means nothing.!
                    First time it worked well, till the end, but i was just playing and testing...
                    But then, you see the mouse taking the commands from the toolbar, the prompt is correct, and nothing happens, nothing in your model/objects, the "gizmo" that Fredo created is visible, but it doesn't do nothing, sometimes you just have to open a new file, or restart SU, and it works again, but most of the times... DON'T work that way either (and the last version is totally null).
                    This extension is a true spectacle that Fredo created, but i wouldn't use it, even when it will work, and i will tell you why.
                    This idea of coipes over copies over copies is a very bad one, Sim Joubert tried it first (with his Sectionbox), and his plugin works every time, except when you have more than one scene πŸ˜€
                    I once had a 2-room kitchen furniture, each room with about 10 meters length of furniture, and all the doors had very complex profiles, everything visible was complex profiled.
                    Bottom line - at the end, i couldn't believe that by opening model info, i saw millions of entities, in only 2 rooms of furniture.
                    I dont even wanna try to imagine what would happen if i open that model, and create sections with Sectionbox, or FredoSection.
                    At first i thoughtt that this is the only way (copies over copies...), until i bought Curic Boxview - i don't know what this guy did (because is totally counteintutitive.!), but the model is clean, this extension doesn't create any extra geometry, only a hidden group of sections, and it works easy and simple, every single time, and works in scenes...
                    • fredo6F
                      @FlorinAp
                      Thanks for signaling the problem which was inadvertedtly introduced with version v1.3b, only for the Section Box Outside. I have fxed it and will publish an update soon. It works fine for the Section Box Inside.
                      Note that all plugins doing section box have to pile up a hierarchy of dummy groups to enclose the 6 section planes. However, there is no copy of the original geometry, but instance of it, so that any change in the section box mode is done on the original geometry. This is illustrated in the video:
                      At least this is how it works in FredoSection, and most likely in Curic SectionBox (I don't know for SJSectionBox).
                      • fredo6F
                        NEW RELEASE: FredoSectiont v1.4a - 08 Jan 26
                        Requirements
                        • LibFredo6: v15.8a or above
                        FredoSection 1.4a is a major release including:
                        • Bug fixing for Section Boxes
                        • Introduction of Pattern Modes (container and/or Tag) and the possibility to assign patterns to tags, as shown in the video below.
                        • fredo6F
                          NEW RELEASE: FredoSectiont v1.5a - 15 Jan 26
                          Requirements
                          FredoSection 1.5a is a maintenance release including:
                          • Major bug fixing (issue with displaying the Color Selector)
                            sayerdesign
                            I've been working with the plugin today on a series of drawings for some cabinetry.
                            Curious if there's a way to add to the Vector hatching library or if that's not something that can be customized? There are a number of materials (plywood, solid wood, stone, etc...) that I'd like to have Vector hatches for.
                            Thoughts?
                            • fredo6F
                              @sayerdesign
                              Currently, the Vector hatching is not customizable but I can easily add any type of hatching, including with dashed lines, multiples, etc.....
                              For a general customization of vector patterns, this should be possible based on providing a repeatable component.
                              However, I am interested in seeing the kind of patterns you want for plywood, solid-wood and stone, and why raster images would not work.
                              • G
                                Gjenio
                                Adding more standard vector hatch types (ANSI) would be a huge time-saver for me. Currently, LayOut doesn't export them as vector entities, which I need when collaborating with other offices
                                  There are a lot of ANSI vector hatch patterns...
                                  Here are 900+ paid -
                                  https://www.etsy.com/uk/listing/1602392539/900-autocad-hatch-library-2d-cad?ls=r&external=1&rec_type=cs&ref=landingpage_similar_listing_top-5&pro=1&dd=1&content_source=c2a30f16a8732b6e51f219c67c46c892%253ALTc4ad72921e17107e0a3f67f035a6ecc77a3039a0&logging_key=c2a30f16a8732b6e51f219c67c46c892%3ALTc4ad72921e17107e0a3f67f035a6ecc77a3039a0
                                  These are free -
                                  https://www.cadblocksdwg.com/hatch-patterns-download.html
                                  Perhaps suggest a base set of say 16 patterns ?
                                  If they can add their own patterns it's then down to each user ?
                                  • fredo6F
                                    I am not familiar with the DWG export from layout.
                                    My understanding is that:
                                    • Sketchup only uses Raster material. There is no such concept as Vector pattern. Otherwise, this is just linework.
                                    • Layout renders the Sketchup model based on these Raster materials and treats them as images. I am not aware that Layout would convert them to vector.
                                    • Layout seems to have a concept of Pattern which can be used for filling shapes. That may well be converted to vector patterns (.pat) when exporting to DWG. However, my understanding is that this only applies to shapes created and painted in Layout, not coming from the 3D model.
                                    • FredoSection Vector Hatching is just a set of edges and faces, as the rest of the geometry. So, it renders as such in Layout. But I don't think it will end up as CAD patterns when the Layout document is exported to DWG.
                                    I don't know if I am correct....
                                      sayerdesign
                                      Thank you, all, for picking up this dialogue.
                                      First off, I should give my thanks and gratitude to Fredo6 for making this plug-in happen. Thank you!
                                      For my workflow, I avoid using anything but the Vector setting for scenes in Layout, and I don't use a style that shows the textures unless it's abosolutely needed . Raster doesn't handle lines well and is 'fuzzy'. The Rastor materials included look great in Sketchup, but don't translate over to Layout. When I tried a hybrid compromise, the Rastor section fills become blurry and not very useful.
                                      I'd be more than happy to give examples of hatch patterns I'd love to see available for the types of materials I use creating drawings for cabinetry (in addition to the Vector patterns currently available at least four different types of sheet goods, three types of solid wood, plaster/gypsum and stone countertops would all be fantastic).
                                      If it's something that's doable with relative ease for you, Fredo, how can I help?
                                      • fredo6F
                                        Raster materials often look blurry in Layout (especially when you zoom). However, when you print the document on paper at the correct paperscale, you get a readable pattern visually.
                                        Anyway, to help progressing, I would suggest you post a few images of you vector patterns (e.g. four different types of sheet goods, three types of solid wood, plaster/gypsum and stone countertops).
                                          sayerdesign
                                          Here's a group of them that were on the https://www.cadblocksdwg.com/hatch-patterns-download.html website that TIG shared previously. If this group were avaiable, that would be great so far as I'm cencerned.
                                          • fredo6F
                                            Getting these patterns as Vector is technically feasible, at least by me in FredoSection.
                                            However, if you use them in a real model, that would represent a lot of lines (and a longer time to decoarte cut faces). Keep in mind that in FredoSection, a Vector pattern is just drawing edges in the model. Already with simple hatches, you have a lot of geometry created.
                                            As suggested, could you try with these patterns in Raster (most of them are in the standard materials, under 'Patterns') and check they print correctly when the proper paperscale is set in Sketchup scenes and corresponding Layout viewports.
                                            • 1 / 3
