    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
    • ntxdaveN
      ntxdave @Rich O Brien
      @Rich-O-Brien Thanks. I thought I was doing something wrong. πŸ‘πŸ‘
      That 1 second pause in between the scenes is giving me what I wanted. I think I will be able to use it in the models I have in mind.
      Can you give me a clue as to why I cannot delete some of the unwanted/unneeded clip names.
      This is turning into a real learning experience πŸ˜€πŸ˜€
      Press F1...thank me later
      • fredo6F
        This should be fixed with LibFredo6 v15.8a, just published.
        ntxdaveN 2 Replies Last reply
          Rich O Brien Moderator @ntxdave
          @ntxdave said in Scene animation with Animator:
          Would you consider that if you have unused animation elements in your model that this is animation data saved into the file?
          The clue:
          Could it be that marking unused animation data that is saved into the file for purging needs to be saved?
          Could the save icon go from disabled to enabled after you have told Animator to trash it?
          Also if you do mark unused elements to be purged by clicking the Maintenance of Data button and Save Changes and then Exit the tool using the Exit Tool button are you prompted that there are changes that have not been saved?
          The clue:
          • ntxdaveN
            ntxdave @fredo6
            @fredo6 said in Scene animation with Animator:
            Thanks @fredo6 and @rich-o-brien Yes, this fixed the problem I was having. Just for fun (and my learning process), here is a video of an example of how the update to LibFreedo6 v15.8a solved my problem/issue.
            Animator Learning 3.mp4
            Now I can go off and work on some things I want to use this resolution for. πŸ˜€
            • ntxdaveN
              ntxdave
              Since the last update to LibFredo6 v15.9a I am having problems creating an animation with multiple scene views. Seems like no matter what camera view I try to capture; there is no longer a transition from one scene to another. I thought I was using the same process as before the update.
              • fredo6F
                Difficult to tell without seeing the model.
                Do you get errors in the Ruby console?
                ntxdaveN 1 Reply Last reply
                • ntxdaveN
                  ntxdave @fredo6
                  @fredo6 No, I am not getting errors.
                  Look at this file. The last two segments (Box One and Box Two) are not showing up correctly in the animation. I have tried multiple times and I do not see what I am doing wrong.
                  Camera Positioning 5.skp
                  OK, I did some more testing, and I think I have made some progress. Here is a different SketchUp file that is getting pretty close. I think you will see the progress and can point out my mistake so I can get it right.
                  Here is the new file: Camera Positioning 6.skp
                  • ntxdaveN
                    ntxdave @fredo6
                    @fredo6 I just updated to LibFredo6 v15.8b and I am having more problems. In particular, when I try to take a picture, it does not seem to select the view i need/want. I tried working with both of the files I posted before.
                    Can you please give me an updated instruction of which of the camera options I should click on.
                    Also, should since I am using layers/tags on every scene, should I apply the layer/tag visibility option to the entire animation of just each segment
                    Maybe I am not going about things correctly. Actually, the version 4 is closer to what I have in mind. I am thinking about a couple of models/animations where I want some text (and maybe some animations) before I show the actual animation (which might involve more than one SketchUp scene and then maybe some more text after the animation giving credits or other comments.
                    • fredo6F
                      I tested your Camera Positioing 6 model. No error and I can set any view.
                      However, since I don't know what you want to achieve, it's difficult to help....
                      • ntxdaveN
                        ntxdave @fredo6
                        @fredo6 Which camera tool are you using?
                        I have tried both types and I seem to be getting scene views instead of the current screen shot.
                        • fredo6F
                          I am using Static View
                          • ntxdaveN
                            ntxdave
                            OK - I went back to the 6 file and got everything to work fine.
                            Now, this file is closer to where I am trying to go but I am having several problems with it. Hope you can straighten me out.
                            • ntxdaveN
                              ntxdave
                              OK, I had everything working in the Camer Positioning 6 file so I copied it and tried rearranging some things. In particular, I tried moving the Box One scene and camera capture to the beginning and it through everything off. So, I am becoming more confused as to what my "rules" need to be. Maybe I need to just do the object movement portion in Animator and do the "other stuff" in a video editor (which is something @rich-o-brien had suggested).
                              Am I being unrealistic as to the type of stuff I should do with Animator?
                                Horses for courses.
                                Do whatever makes you happy...πŸ˜€
                                Animator is primarily a tool to animate objects in SketchUp.
                                That doesn't mean it can't do other things.
                                I think you need to spend time learning it
                                • ntxdaveN
                                  @Rich-O-Brien said in Scene animation with Animator:
                                  Horses for courses.
                                  I have been doing a lot to learn it (IMO), also @fredo6 has been working with me. He even found a bug related to one of the first files I shared and created an update which resolved the problem. know I am getting old and do not use SketchUp as much as I used to. But it seems that some of the issues I am having are more related to some things I am doing in native SketchUp rather than Animator.
                                  If I do some of the stuff I want to do in addition to the Animator animation, I still need to find another product (video editor) that I can afford ( or free). All of this is for my enjoyment/pleasure. As we age (at least some of us) do things like this for pleasure/hobby and unfortunately cost does become a factor.
                                  Even though this has been a little frustrating and a learning challenge, I want to continue and want people like you to not give up on me. Even though I still cannot get everything to work (as of now) the things I have learned have been fun. πŸ˜€πŸ˜€πŸ˜€
                                    That maybe true. You just need to persevere. I would hold the belief you need a good foundation on using SketchUp to really getting the most from Animator.
                                    If you knowledge level in SketchUp is low that is easy fix. Model, model and model.
                                    • ntxdaveN
                                      OK, I think I am learning and I keep working on learning more things. Now back to this subject. I am sharing the animator animation that has led me to all of this. This is the model that inspired me to get more involved with Animator. I hope you see it as a step forward. I know it is pretty basic but it where I want to start. Now I want to see if I can figure out a way to add two text scenes. One at the beginning that gives some insight to what the model/animation is all about and the second text scene will be to give some information about the model/animation.
                                      Here is the file for you to download/view to get some insight about where I am headed.
                                      Learning Animator Animation.skp
                                      Yes, I know I could have saved the movements as a clip but did not do it yet. I also thought there should have been an animator file but did not see it to download.
                                      • ntxdaveN
                                        ntxdave
                                        OK, as part of my β€œlearning” experience, I have been trying to figure out a way to add a new scene that would have the β€œintroduction” or β€œconclusion” text (and possibly some other things to animate) and cannot get things to work. In the file i shared/posted before the items that are animated were created in a front scene scene. I tried putting way far away on a front view and the new stuff (again way far away) in a top view. I also used tags/layers for each of them so that you should only see what is visible tied to the scene (hope this makes sense) but when I try to transition to the new scene you see the stuff that is supposed to be hidden. I have tried bit of the camera options (current view and scene view) and the results are pretty much the same. When you go from one view/scene to the other you see the stuff that is supposed to be hidden (although from the new view).
                                        I hope this explanation makes sense and someone can give me a way to solve this, if there really is a way to resolve it. I have tried bit of β€œmany” ways to figure this out. 😩
                                        • fredo6F
                                          Again, text drawing would be better managed in a video editor rather than Animator.
                                          If your text is a solid, just treat it like that. Insert Movement (Move, Rotation) in the timeline. Use special effect Visibility to make it appear and disappear (via its tag).
                                          Cameras are independent from object movements.
                                          • ntxdaveN
                                            ntxdave @fredo6
                                            That is what I have been thinking but I have not found software to use. I was thinking I might have some text or other objects I might want to animate as part of the β€œintroduction” or β€œconclusion” though.
                                            That is what I have been trying.
                                            Yes, I understand. However, what I was trying to achieve (or would like to) is to get basically the same result as if when you are looking at your model and clicking on each scene tab but with animations added.
                                            Again, hope that clarifies what I was trying to achieve.
                                            • 4 / 6
