    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
    • ntxdaveN
      ntxdave @Rich O Brien
      @Rich-O-Brien πŸ‘
      Still wondering about some video editing software
      Press F1...thank me later
        Rich O Brien Moderator @ntxdave
        @ntxdave said in Scene animation with Animator:
        Go research it. But if you keep biting off more and more things to learn you'll get nowhere.
        What's the rush? Take things at a sensible pace and enjoy the journey. Make the best animation in SketchUp you can then fuss over the rest when that part is sorted.
        • ntxdaveN
          ntxdave
          OK, I have created a very basic model/animation that has an object that I view via the front, right, left, back, top and bottom. Each of the segments is 2.0 seconds. Not what I would like to do is control the transition from one sequence to the next. However, so far, I have not been able to figure out how to control the transitions,
          Here is the silly little model.
          Camera Positioning.skp
          I probably should also figure out a nice clean way to animate the change from one scene to another. Again, this is really helping me get to the direction I want to go with my future 2 models/animations.
            Try reverse engineer this:
            nxtdave-camera.skp
            I didn't look at your file but check that to see if there are scenes in my file. If not then figure out how the camera moves without using scenes.
            ntxdaveN 1 Reply Last reply
            • ntxdaveN
              @Rich-O-Brien Thanks Rich but that is not my issue. I have some totally different objects in multiple scenes. I can capture the camera position/view in each of the scenes but I cannot get a smooth transition from one of the views to another. Each camera view is the different view, not always but usually different objects' When Animator goes from one camera view to the next, it is a crisp shot. I would like to have a way to make the transition rather smooth instead of just a different shot.
                That is because the Scene is Static. Hover the buttons to see the tooltips.
                Use the first icon
                Click the Scene tab and then Capture View. Repeat for each Scene.
                • ntxdaveN
                  ntxdave
                  OK, @rich-o-brien I have made some progress thanks to your post in the @majid thread.
                  So here is an updated file with the multiple scenes and the video I was able to create after following you response.
                  Camera Positioning 2.skp
                  amera Positioning 2.mp4
                  Now back to the last thing I am still trying to solve. How do you create a nice smooth transition between the clips. Just to let you (and other) know, I learned that before you do the screen capture, I needed to lick on the scene first.
                  Again, progress....πŸ‘
                    If it is movement between Camera A position and Camera B position you can see how that is done in the file I shared further up.
                    If the element in your timeline is stretched or fills the duration between A and B then the transition has no space to occur.
                    So lets say you capture camera position at 0.0 and make it last 1 sec and then capture at 1.0 for another 1sec. You are essentially telling Animator keep that captured view held from 0.0 to 1.0 then switch to the next view at 1.0 etc.
                    What should happen is you capture at 0.0 and then set the duration you want that held for. Then space for the Fadeout before your next captured view.
                    In that 'space' the Fadeout will execute.
                    • ntxdaveN
                      ntxdave
                      Well, again, I have made some progress. On the positive side, I found out that adding a one second blank space between the clips provides a transition between the clips that I like.
                      However, I have run into 2 problems:
                      • For some reason, the animation stops after the 3rd clip (right). I have not been able to figure out why.
                      • I have had problems trying to clean up the Animator clip names. I have tried deleting the names, clicking the Purge Unused, Save Changes, and then exiting Animator. When I come back to the animation, the clip names I tried to delete are still there.
                      Here is the updated version of the file:Camera Positioning 3.skp
                        That's a bug. I discovered that today playing with your file. Fredo is aware and will post a fix with a new Libfredo.
                        • ntxdaveN
                          @Rich-O-Brien Thanks. I thought I was doing something wrong. πŸ‘πŸ‘
                          That 1 second pause in between the scenes is giving me what I wanted. I think I will be able to use it in the models I have in mind.
                          Can you give me a clue as to why I cannot delete some of the unwanted/unneeded clip names.
                          This is turning into a real learning experience πŸ˜€πŸ˜€
                          • fredo6F
                            This should be fixed with LibFredo6 v15.8a, just published.
                            ntxdaveN 2 Replies Last reply
                              Would you consider that if you have unused animation elements in your model that this is animation data saved into the file?
                              The clue:
                              Could it be that marking unused animation data that is saved into the file for purging needs to be saved?
                              Could the save icon go from disabled to enabled after you have told Animator to trash it?
                              Also if you do mark unused elements to be purged by clicking the Maintenance of Data button and Save Changes and then Exit the tool using the Exit Tool button are you prompted that there are changes that have not been saved?
                              The clue:
                              • ntxdaveN
                                ntxdave @fredo6
                                @fredo6 said in Scene animation with Animator:
                                Thanks @fredo6 and @rich-o-brien Yes, this fixed the problem I was having. Just for fun (and my learning process), here is a video of an example of how the update to LibFreedo6 v15.8a solved my problem/issue.
                                Animator Learning 3.mp4
                                Now I can go off and work on some things I want to use this resolution for. πŸ˜€
                                • ntxdaveN
                                  ntxdave
                                  Since the last update to LibFredo6 v15.9a I am having problems creating an animation with multiple scene views. Seems like no matter what camera view I try to capture; there is no longer a transition from one scene to another. I thought I was using the same process as before the update.
                                  • fredo6F
                                    Difficult to tell without seeing the model.
                                    Do you get errors in the Ruby console?
                                    • ntxdaveN
                                      ntxdave @fredo6
                                      @fredo6 No, I am not getting errors.
                                      Look at this file. The last two segments (Box One and Box Two) are not showing up correctly in the animation. I have tried multiple times and I do not see what I am doing wrong.
                                      Camera Positioning 5.skp
                                      OK, I did some more testing, and I think I have made some progress. Here is a different SketchUp file that is getting pretty close. I think you will see the progress and can point out my mistake so I can get it right.
                                      Here is the new file: Camera Positioning 6.skp
                                      • ntxdaveN
                                        ntxdave @fredo6
                                        @fredo6 I just updated to LibFredo6 v15.8b and I am having more problems. In particular, when I try to take a picture, it does not seem to select the view i need/want. I tried working with both of the files I posted before.
                                        Can you please give me an updated instruction of which of the camera options I should click on.
                                        Also, should since I am using layers/tags on every scene, should I apply the layer/tag visibility option to the entire animation of just each segment
                                        Maybe I am not going about things correctly. Actually, the version 4 is closer to what I have in mind. I am thinking about a couple of models/animations where I want some text (and maybe some animations) before I show the actual animation (which might involve more than one SketchUp scene and then maybe some more text after the animation giving credits or other comments.
                                        • fredo6F
                                          I tested your Camera Positioing 6 model. No error and I can set any view.
                                          However, since I don't know what you want to achieve, it's difficult to help....
                                          • ntxdaveN
                                            ntxdave @fredo6
                                            @fredo6 Which camera tool are you using?
                                            I have tried both types and I seem to be getting scene views instead of the current screen shot.
                                            • 3 / 6
