    Scene animation with Animator
    107 Posts 3 Posters 20.2k Views 3 Watching
    • ntxdaveN Offline
      ntxdave
      Since the last update to LibFredo6 v15.9a I am having problems creating an animation with multiple scene views. Seems like no matter what camera view I try to capture; there is no longer a transition from one scene to another. I thought I was using the same process as before the update.
      Press F1...thank me later
      • fredo6F Offline
        Difficult to tell without seeing the model.
        Do you get errors in the Ruby console?
        • ntxdaveN Offline
          ntxdave @fredo6
          @fredo6 No, I am not getting errors.
          Look at this file. The last two segments (Box One and Box Two) are not showing up correctly in the animation. I have tried multiple times and I do not see what I am doing wrong.
          Camera Positioning 5.skp
          OK, I did some more testing, and I think I have made some progress. Here is a different SketchUp file that is getting pretty close. I think you will see the progress and can point out my mistake so I can get it right.
          Here is the new file: Camera Positioning 6.skp
          • ntxdaveN Offline
            ntxdave @fredo6
            @fredo6 I just updated to LibFredo6 v15.8b and I am having more problems. In particular, when I try to take a picture, it does not seem to select the view i need/want. I tried working with both of the files I posted before.
            Can you please give me an updated instruction of which of the camera options I should click on.
            Also, should since I am using layers/tags on every scene, should I apply the layer/tag visibility option to the entire animation of just each segment
            Maybe I am not going about things correctly. Actually, the version 4 is closer to what I have in mind. I am thinking about a couple of models/animations where I want some text (and maybe some animations) before I show the actual animation (which might involve more than one SketchUp scene and then maybe some more text after the animation giving credits or other comments.
            • fredo6F Offline
              I tested your Camera Positioing 6 model. No error and I can set any view.
              However, since I don't know what you want to achieve, it's difficult to help....
              • ntxdaveN Offline
                ntxdave @fredo6
                @fredo6 Which camera tool are you using?
                I have tried both types and I seem to be getting scene views instead of the current screen shot.
                • fredo6F Offline
                  I am using Static View
                  • ntxdaveN Offline
                    ntxdave
                    OK - I went back to the 6 file and got everything to work fine.
                    Now, this file is closer to where I am trying to go but I am having several problems with it. Hope you can straighten me out.
                    • ntxdaveN Offline
                      ntxdave
                      OK, I had everything working in the Camer Positioning 6 file so I copied it and tried rearranging some things. In particular, I tried moving the Box One scene and camera capture to the beginning and it through everything off. So, I am becoming more confused as to what my "rules" need to be. Maybe I need to just do the object movement portion in Animator and do the "other stuff" in a video editor (which is something @rich-o-brien had suggested).
                      Am I being unrealistic as to the type of stuff I should do with Animator?
                        Rich O Brien Moderator @ntxdave
                        @ntxdave said in Scene animation with Animator:
                        Horses for courses.
                        Do whatever makes you happy...😀
                        Animator is primarily a tool to animate objects in SketchUp.
                        That doesn't mean it can't do other things.
                        I think you need to spend time learning it
                        • ntxdaveN Offline
                          ntxdave @Rich O Brien
                          @Rich-O-Brien said in Scene animation with Animator:
                          Horses for courses.
                          I have been doing a lot to learn it (IMO), also @fredo6 has been working with me. He even found a bug related to one of the first files I shared and created an update which resolved the problem. know I am getting old and do not use SketchUp as much as I used to. But it seems that some of the issues I am having are more related to some things I am doing in native SketchUp rather than Animator.
                          If I do some of the stuff I want to do in addition to the Animator animation, I still need to find another product (video editor) that I can afford ( or free). All of this is for my enjoyment/pleasure. As we age (at least some of us) do things like this for pleasure/hobby and unfortunately cost does become a factor.
                          Even though this has been a little frustrating and a learning challenge, I want to continue and want people like you to not give up on me. Even though I still cannot get everything to work (as of now) the things I have learned have been fun. 😀😀😀
                            That maybe true. You just need to persevere. I would hold the belief you need a good foundation on using SketchUp to really getting the most from Animator.
                            If you knowledge level in SketchUp is low that is easy fix. Model, model and model.
                            • ntxdaveN Offline
                              OK, I think I am learning and I keep working on learning more things. Now back to this subject. I am sharing the animator animation that has led me to all of this. This is the model that inspired me to get more involved with Animator. I hope you see it as a step forward. I know it is pretty basic but it where I want to start. Now I want to see if I can figure out a way to add two text scenes. One at the beginning that gives some insight to what the model/animation is all about and the second text scene will be to give some information about the model/animation.
                              Here is the file for you to download/view to get some insight about where I am headed.
                              Learning Animator Animation.skp
                              Yes, I know I could have saved the movements as a clip but did not do it yet. I also thought there should have been an animator file but did not see it to download.
                              • ntxdaveN Offline
                                ntxdave
                                OK, as part of my “learning” experience, I have been trying to figure out a way to add a new scene that would have the “introduction” or “conclusion” text (and possibly some other things to animate) and cannot get things to work. In the file i shared/posted before the items that are animated were created in a front scene scene. I tried putting way far away on a front view and the new stuff (again way far away) in a top view. I also used tags/layers for each of them so that you should only see what is visible tied to the scene (hope this makes sense) but when I try to transition to the new scene you see the stuff that is supposed to be hidden. I have tried bit of the camera options (current view and scene view) and the results are pretty much the same. When you go from one view/scene to the other you see the stuff that is supposed to be hidden (although from the new view).
                                I hope this explanation makes sense and someone can give me a way to solve this, if there really is a way to resolve it. I have tried bit of “many” ways to figure this out. 😩
                                • fredo6F Offline
                                  Again, text drawing would be better managed in a video editor rather than Animator.
                                  If your text is a solid, just treat it like that. Insert Movement (Move, Rotation) in the timeline. Use special effect Visibility to make it appear and disappear (via its tag).
                                  Cameras are independent from object movements.
                                  • ntxdaveN Offline
                                    ntxdave @fredo6
                                    @fredo6 said in Scene animation with Animator:
                                    That is what I have been thinking but I have not found software to use. I was thinking I might have some text or other objects I might want to animate as part of the “introduction” or “conclusion” though.
                                    That is what I have been trying.
                                    Yes, I understand. However, what I was trying to achieve (or would like to) is to get basically the same result as if when you are looking at your model and clicking on each scene tab but with animations added.
                                    Again, hope that clarifies what I was trying to achieve.
                                    • ntxdaveN Offline
                                      ntxdave @ntxdave
                                      BTW: Just curious if anyone looked at the file I posted before and has any suggestions.
                                      • ntxdaveN Offline
                                        ntxdave
                                        Hope someone can tell me what I am doing wrong.
                                        SketchUp file I used for the movie:
                                        Camera and Animations.skp
                                        Here is the movie that was produced by Animator. Camera and Animations.mp4
                                        So if you download the SketchUp file and then click on each of the scene tabs and compare that to what was generated by Animator, I have the following comments/questions:
                                        • On each of the scenes, there should be text that tells which scene you are viewing.
                                        • On each of the scenes, there should be an object (one that I wanted to add a motion to later)
                                        • The text on each of the scenes is controlled by a tag/layer which Animator seems to be ignoring.
                                        • The object (that I wanted to animate) on each of the scenes is also controlled by a tag/layer which Animator seems to be ignoring
                                        • I used the tag/layer visibility controller for all of the movie. However, I have to admit that I added that feature as the last item. Should I have done that before taking the pictures?
                                        • You will notice that for each of the scenes I used the camera option to use the scene. I have also tried doing the whole thing with the current view option for capturing the camera. But I got the same results when trying that way.
                                        Again, am I doing something wrong?
                                        What I would like for Animator to do is give me the same results as if you click on the scene tabs one at a time and the transition in Animator would be the same as it happens in native SketchUp. @fredo6 is that possible? If so, this would give me (I think) the capability I have been trying to achieve.
                                        • ntxdaveN Offline
                                          ntxdave
                                          OK, after some more “learning” and trying to understand, I think I have figured out what is going on and wonder if there is a way to resolve it.
                                          I started the model in the example by creating a 3D box. I then added a color to each of the faces. The I started adding text and other objects as parts of scenes. If you look at it, I added the “face” name to the front, right, left and back of the 3D box. So, as an example, I created a scene named “Front” using the front face of the 3D box. I then added other items and assigned a tag/layer to the text and other objects. I then used this same approach for the other views.
                                          Now when I add a camera in Animator, I used the name of the scene and all seemed to go well until I try move through the “scenes” itfinallt dawned on me is that when I go from one scene to another it is (I think) using the face side of the 3D box to control what is being shown. As an example, when it goes from, say front, to right, it is using the SketchUp camera setting to navigate between the scenes. Thus it rotates the 3D box to the camera view that I used to create the scene but no applying the tag/layer setting the matches the scene settings.
                                          I hope this description makes sense. In other words, IMO, the script is using the SketchUp face view orientation instead of the scene settings. Again, I hope this makes sense.
                                          • ntxdaveN Offline
                                            ntxdave
                                            OK, I think I am making some progress/learning. Here is my latest video. Visibility Test.mp4
                                            I realize this is not very complicated but during the development process, I think I have learned some new things about how to do some things. Now I want to try to combine this with something in another scene so that I can have two scenes in a model that combines capabilities like this. At the rate I am going/earning though, this will probably not happen for a couple of days.
                                            • 4 / 6
