    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • KrassK
      Krass
      In the meantime, to transfer a project to another machine, simply go to the editor of the material and open the texture in the Windows viewer, then save it in the images folder generated by the Rayscaper material archive once SU is opened on the other machine (from the archive created by Rayscaper).
      Krass
        Alattab @Krass
        @Krass thank you
          Alattab @pixelcruncher
          @pixelcruncher Where can I add specular luminosity maps? Or where can i mange specular value
            Alattab
            Just a suggestion: all PBR parameters should be available, in addition to an AO parameter that allows the user to add all PBR maps. Also, the ability to add FORE GROUND AND BACK GROUND should be added instead of using the environment image, and the ability to resize the environment image should also be included.
            pixelcruncherP 1 Reply Last reply 👍
            • KrassK
              Krass
              Yes, when you talk about resizing HDRI maps, it's an ideal function, but you know, even D5 Render doesn't have that feature yet. It's available in Twinmotion and V-Ray (Infinite Dome) for the programs I use. For the background, you can also place an arc-shaped plane with an image in Raycacaper, which often works.
              Have you tried that slot for your specular map?
              Krass
              A 1 Reply Last reply 👎
              • majidM
                majid
                Unbelieveably good!
                1 Reply Last reply ♥
                  Alattab @Krass
                  @Krass thank you , i will try this slot , but there is an However, there is a difference between specular and specular tint. For clear water that has a specular, it is best to use metallic with the transparency.
                  • KrassK
                    Krass
                    Hi, would it be possible to have the total render time remain displayed in the dedicated window after the render is complete? Of course, I've noted the estimated time that appears during the animation render, but the final time disappears once the job is finished...
                    Krass
                    Mike AmosM pixelcruncherP 2 Replies Last reply
                      Mike Amos @Krass
                      @Krass
                      Not here mate. The render time is a constant.![Render Time Persistent.
                      • KrassK
                        Krass
                        Hi, I don't quite understand, do you mean the total rendering time is displayed at the bottom here? Also for the animation?
                        Krass
                          Pardon me, I missed the 'animation' part of your post, just wondering if it was a new behaviour from the app.
                          • pixelcruncherP
                            pixelcruncher Extension Creator @Alattab
                            @Alattab said in Rayscaper New Releases:
                            Which application is this?
                            AO parameter is on the list, but I haven't gotten around to it yet.
                            By background, you mean adding an image to the backplate, for example for compositing? And would you then save this image as part of the render, or not?
                            What is foreground? Do you have an example from other render software?
                            The ability to resize the environment image should also be included.
                            I'm not sure what that means. Do you mean a smaller / bigger resolution, or something else? The environment is wrapped as a "sphere" around your scene, so resizing will only impact the level of detail.
                            Thanks for the feedback!
                            Regards,
                            Thomas
                            • pixelcruncherP
                              @Krass
                              So you mean keeping this window open until you explicitly close it after rendering?
                                Alattab
                                I'm still learning, and I hope the program's creator will allow me to provide feedback and suggest improvements. I'm a beginner with SketchUp and have tried many rendering programs that work independently, like Stanalone. I think it's great that it supports Intel OpenImage Denoiser. I'd like contrast control added to the post-processing section, and full PBR properties added, along with additional materials like transparent liquids, bubbled, fizz, and airborne water.
                                  @pixelcruncher Back palette (background) and front plate (foreground), like a keyshot render. If you choose a transparent background, you can add other images as a background or in front image as clipart in front of rendered image , some thing like whate happen in sketchup style editting
                                  • KrassK
                                    Krass
                                    Hi, why dont you use sky alpha mask with a photo editor ?
                                    Krass
                                    • KrassK
                                      Krass
                                      About hdri scale I think Alattab means a physical dôme, like infinite dôme in vray, that can be stretched and scaled. This is very usefull. It is an hemisphere
                                      Krass
                                        Alattab
                                        To make the program fully functional without relying on external applications, background and overlay options can be added to this list.
                                          Alattab @Krass
                                          @Krass ، as example simlab composser render engain can scale dome
                                            Alattab
                                            It is good thing to copy light properties to each each other
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 37
                                            • 38
                                            • 18 / 38
