    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • pixelcruncherP
      @Krass Yikes, can you get me the logs after a crash happened?
      Report a Bug
      How to send a bug report that we can act on, with the log files, a description and a scene that shows the problem.
      Rayscaper (rayscaper.com)
      • pixelcruncherP
        pixelcruncher Extension Creator @majid
        @majid I'm supporting 2026, 2025, 2024. I changed that a couple of releases back.
        • KrassK
          Krass
          Done, I send the bug report
          1 Reply Last reply πŸ‘
          • pixelcruncherP
            pixelcruncher Extension Creator @pixelcruncher
            @krass - Here's the animation guide: https://rayscaper.com/guides/animation/ - Please let me know if everything is clear, or if there are any issues with the feature, because it's brand new πŸ™‚
            • KrassK
              Krass
              Yes, I've already figured out how to render an animation! I'm testing it now.
              • KrassK
                Krass
                Too bad, my first animation attempt crashes after three frames... yet the functions, animation settings, and interface are very well done.
                As soon as I minimize the window to show the desktop, it crashes.
                • KrassK
                  Krass
                  By dragging the Rayscaper window to the bottom of the screen, it seems to be holding... I'll let you know in about an hour and a half.
                  • pixelcruncherP
                    @Krass Sorry about that, it's a brand new feature (implemented two weeks ago), so rough around the edges. It would be great if you could also send the logs for this crash?
                    Pro tip, first render out a small resolution, low samples per pixel animation. They you get an immediate feel for it without having to wait too long πŸ˜‰
                    • KrassK
                      Krass
                      yes I'm now rendering with default SPP, anyway this new feature is such I giant step, i'm so exited...
                      • pixelcruncherP
                        @Krass Thanks for the kind words! Great to hear that you like it!
                        • KrassK
                          Krass
                          This post is deleted!
                          • KrassK
                            Krass
                            My first animation with Rayscaper!
                            Comparatif rayscaper/magnific upscale – jskup
                            https://jskup.fr/wp-content/uploads/2025/12/animationsuite_0000_1.mp4 Avant Après
                            jskup (jskup.fr)
                            • pixelcruncherP
                              @Krass Nice, thanks for sharing! Super cool to see this result.
                              • pixelcruncherP
                                Hey, Rayscaper users!
                                Rayscaper 0.9.83 Beta is available. You can get it via:
                                • The SketchUcation store.
                                • Direct download: Rayscaper_0.9.83_Beta.rbz.
                                I recommend upgrading to the latest version.
                                What Changed?
                                • Add Nishita sky sun tracking from SketchUp shadows. The procedural sky will now automatically follow the sun position set in SketchUp's shadow settings, making it easier to match lighting conditions across your workflow. You can enable this via the menu Extensions > Rayscaper > Sync Nishita with Sun. See Syncing with SketchUp Sun for more details.
                                • Improve environment power controls with logarithmic sliders. Environment intensity is now easier to adjust precisely across a wide range of values.
                                • Fix crash when changing render resolution. Rayscaper will no longer crash when you adjust the resolution settings.
                                • Fix alpha textures to use linear color space. Alpha channels in textures now render with correct transparency values.
                                Help Me Build the Community πŸ‘
                                If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                                and helps me showcase its capabilities to new users.
                                Follow me on X.
                                Happy Rendering!
                                Thomas
                                KrassK 1 Reply Last reply
                                • ntxdaveN
                                  ntxdave
                                  What tool can you use to create an animation that works with Rayscaper?
                                  Press F1...thank me later
                                  • ntxdaveN
                                    ntxdave
                                    Any plans to ,ake Rayscaper work withAnamator?
                                    • KrassK
                                      Krass @ntxdave
                                      @ntxdave i think it only works with scene transitions. Wait for pixel cruncher answer about Animator.
                                        Alattab
                                        How can I make a water material ?
                                        • pixelcruncherP
                                          pixelcruncher Extension Creator @ntxdave
                                          @ntxdave Like @krass mentioned, it only works for SketchUp scene animations. Fredo animator is not supported yet. Here is a guide on how to animate regular SketchUp scenes: https://rayscaper.com/guides/animation/
                                          • KrassK
                                            Krass @Alattab
                                            @Alattab forwater may be try a transparent or glass material and try several wave normal maps in the normal slot, play with material scale
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 37
                                            • 38
                                            • 16 / 38
