    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
    • KrassK
      Krass
      Regarding the animation, is it in the form of a sequence of images?
      • majidM
        majid
        I guess it is bkz I use SU 2023... and RS does not support it
        • KrassK
          Krass
          you can't use Rayscaper on your 2023 SU ? If yes do you get the same issue when increasing camera resolution?
          • KrassK
            Krass
            ok, i found it
            1 Reply Last reply πŸ‘
            • KrassK
              Krass
              To get back to my point about the crash when I change the camera resolution: it doesn't crash on smaller SketchUp files, I've run tests. But it's true that this particular file is quite large, 279 MB.
              • pixelcruncherP
                @Krass
                Have a look at this guide on how to release seats: https://rayscaper.com/faq/licensing/#how-do-i-release-a-license-seat
                • pixelcruncherP
                  @Krass, I'm updating my documentation, stay tuned. If I have time this week, I will also try a video.
                  • pixelcruncherP
                    @Krass Yikes, can you get me the logs after a crash happened?
                    Report a Bug
                    How to send a bug report that we can act on, with the log files, a description and a scene that shows the problem.
                    Rayscaper (rayscaper.com)
                    • pixelcruncherP
                      pixelcruncher Extension Creator @majid
                      @majid I'm supporting 2026, 2025, 2024. I changed that a couple of releases back.
                      • KrassK
                        Krass
                        Done, I send the bug report
                        • pixelcruncherP
                          pixelcruncher Extension Creator @pixelcruncher
                          @krass - Here's the animation guide: https://rayscaper.com/guides/animation/ - Please let me know if everything is clear, or if there are any issues with the feature, because it's brand new πŸ™‚
                          • KrassK
                            Krass
                            Yes, I've already figured out how to render an animation! I'm testing it now.
                            • KrassK
                              Krass
                              Too bad, my first animation attempt crashes after three frames... yet the functions, animation settings, and interface are very well done.
                              As soon as I minimize the window to show the desktop, it crashes.
                              • KrassK
                                Krass
                                By dragging the Rayscaper window to the bottom of the screen, it seems to be holding... I'll let you know in about an hour and a half.
                                • pixelcruncherP
                                  @Krass Sorry about that, it's a brand new feature (implemented two weeks ago), so rough around the edges. It would be great if you could also send the logs for this crash?
                                  Pro tip, first render out a small resolution, low samples per pixel animation. They you get an immediate feel for it without having to wait too long πŸ˜‰
                                  • KrassK
                                    Krass
                                    yes I'm now rendering with default SPP, anyway this new feature is such I giant step, i'm so exited...
                                    • pixelcruncherP
                                      @Krass Thanks for the kind words! Great to hear that you like it!
                                      • KrassK
                                        Krass
                                        This post is deleted!
                                        • KrassK
                                          Krass
                                          My first animation with Rayscaper!
                                          https://jskup.fr/comparatif-rayscaper-magnific-upscale/
                                          • pixelcruncherP
                                            @Krass Nice, thanks for sharing! Super cool to see this result.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 26
                                            • 27
                                            • 16 / 27
