    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
    • KrassK
      Krass
      I finally understand how to use the denoiser. You might initially think that a low-resolution render will be calculated faster... But actually, when the denoiser is applied during rendering, especially when the render resolution is high, the denoising is very clean.
      It might seem obvious to you, but it took me a while to figure it out. So I leave the denoiser at full power and immediately set the render size to 2k or higher.
      Krass
      • KrassK
        Krass
        Thomas, you asked me why I apply an upscale layer after a ray-scaping render. For scenes with windows, I have to do two renders, like a photographer: a light one for the room's exposure and a dark one to replace the "blown-out," overexposed parts of the window. D5 Render doesn't have this problem because its renders aren't truly photographic; they're a kind of pseudo-pathtracing.
        Krass
        • KrassK
          Krass
          On this page I show a comparison slider between the original rendering and the changes that Magnific Upscale adds
          https://jskup.fr/comparatif-rayscaper-magnific-upscale/
          Of course, we then have to go back through Photoshop to correct the errors that the upscaling process generates.
          Krass
          • pixelcruncherP
            pixelcruncher Extension Creator @pixelcruncher
            Just to confirm, your GPU is working again and your icons are back?
            As for objects on hidden tags, it's still the same; objects on hidden tags in the SU viewport are displayed in the Rayscaper render.
            Thanks for reporting. I could find a scene to reproduce it. Seems to happen only for components/groups nested within other groups. I will have a look at this bug.
            I should document that better. The denoiser works on the full resolution image. And it works now as a post-processing step, so enable/disable won't impact the rendering.
            That's a clever trick, thanks for sharing. Does this mean the tone-mapping operations you are getting in the post-processing step aren't sufficient for you? Should there be more options to provide a better image from the get-go?
            Regards,
            Thomas
            S 1 Reply Last reply
            • pixelcruncherP
              And there's still this problem with certain groups containing other groups and components that don't display unless everything inside is exploded. And I can't always explode everything, as I have variations to make in subsequent steps.
              @Krass - Do you mind sending me a scene where this happens? I would like to investigate.
              • KrassK
                Krass
                ok, I will send you the scene. Regarding the issue of geometry not displaying when enclosed in groups and subgroups, if I find an earlier version where I haven't broken everything down inside. As for exposure, there may be aspects I don't fully understand, but generally I have this problem: like in photography, if you take an interior shot focused on objects, your window will be white, with saturated light. If you focus on the window, the outside landscape, a digital camera will make the interior extremely dark so you can see the trees and the garden. Just like the human eye. Except our eyes are very fast and correct in microseconds, which allows us to see both the exterior and the interior so clearly. That's light sensitivity. If there's a way...
                Krass
                • pixelcruncherP
                  Hey, Rayscaper users!
                  Happy holidays, and all the best for 2026!
                  Rayscaper 0.9.82 Beta is available. You can get it via:
                  • The SketchUcation store.
                  • Direct download: link.
                  I recommend upgrading to the latest version.
                  What Changed?
                  Lighting Enhancements
                  • Area Light Support: Create realistic soft lighting effects with area lights, perfect for architectural and product visualization
                  • Multi-Selection for Lights: Select multiple lights at once using SHIFT or CTRL from SketchUp, the lights overlay, or the lights tab for easier management in complex scenes
                  • Light Component Preview: See a preview of light components in the light tool for easier and more accurate placement
                  • Light Grouping: Group Rayscaper light components within SketchUp groups and component definitions for better organization
                  • Enhanced Light Icons: Improved visual feedback with new light icons throughout the interface
                  Material & Texture Improvements
                  • Material Selection Context Menu: Right-click on materials in the asset manager for quick access to common operations
                  • Export Selected Materials: Export materials from your current scene for reuse in other projects
                  • Auto-Wire Alpha Textures: Textures with alpha channels in SketchUp automatically connect to the opacity channel in Rayscaper materials
                  • Float Texture Multipliers: Adjust the strength of roughness and metallic textures with new multiplier controls
                  • SketchUp 2025 PBR Support: Metallic and roughness factors from SketchUp 2025's PBR materials now properly apply as texture multipliers
                  Animation
                  • SketchUp Scene Animation: Render animations based on SketchUp scenes, including sun and shadow positions - perfect for creating time-lapse renders showing how lighting changes throughout the day
                  Interface Improvements
                  • Updated Color Scheme: Refreshed Rayscaper color scheme for better visual clarity
                  • Improved Render Status Bar: Clearer visual indicators make it easier to monitor rendering progress
                  • Better Tooltips: Rewritten tooltips throughout the interface for improved clarity and user-friendliness
                  Here's a nice XMas render by @rich-o-brien
                  Help Me Build the Community πŸ‘
                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                  to new users.
                  Follow me on https://x.com/rayscaper3d.
                  Happy Rendering!
                  Thomas
                  • majidM
                    majid
                    Thanks for the update, though I have issues with it. Here is what I get:
                    Error: #<LoadError: 126: The specified module could not be found. - c:/users/magic/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/rayscaper/installed/Windows/2023/0.9.82 Beta/resources/SUEX_Rayscaper_LoadLibs.so>
                    E:/Program Files/SketchUp/Sketchup 2023/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:83:in require' E:/Program Files/SketchUp/Sketchup 2023/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:83:in require'
                    c:/users/magic/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/rayscaper/main.rbe:174:in <module:Rayscaper>' c:/users/magic/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/rayscaper/main.rbe:8:in <main>'
                    E:/Program Files/SketchUp/Sketchup 2023/Tools/extensions.rb:197:in eval' E:/Program Files/SketchUp/Sketchup 2023/Tools/extensions.rb:197:in require'
                    E:/Program Files/SketchUp/Sketchup 2023/Tools/extensions.rb:197:in load' C:/Users/Magic/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/rayscaper.rb:18:in register_extension'
                    C:/Users/Magic/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/rayscaper.rb:18:in <module:Rayscaper>' C:/Users/Magic/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/rayscaper.rb:6:in <top (required)>'
                    I uninstalled the previous version, then removed the entire plugin and its loader and reinstalled it, yet the issue persists.
                    • pixelcruncherP
                      @majid Sorry about that! Can you send me the log files as described here: https://rayscaper.com/getting-help/report-a-bug/#1-export-the-log-files
                      • KrassK
                        Krass
                        Hi Thomas, I can't believe I read that you can now do animation? I just installed it and it works perfectly on my computer. It's a Christmas present! But I'm eager to understand how to create an animation. A tutorial would be great...
                        Krass
                        • KrassK
                          Krass
                          I reinstalled Windows; I suppose that explains the license issue I'm having? Rayscaper is installed on two machines.
                          Krass
                          • KrassK
                            Krass
                            Sketchup crashes as soon as I click on "double" in the rendering resolution settings.
                            and it's systematic
                            Krass
                            • KrassK
                              Krass
                              Regarding the animation, is it in the form of a sequence of images?
                              Krass
                              • majidM
                                majid
                                I guess it is bkz I use SU 2023... and RS does not support it
                                • KrassK
                                  Krass
                                  you can't use Rayscaper on your 2023 SU ? If yes do you get the same issue when increasing camera resolution?
                                  Krass
                                  • KrassK
                                    Krass
                                    ok, i found it
                                    Krass
                                    1 Reply Last reply πŸ‘
                                    • KrassK
                                      Krass
                                      To get back to my point about the crash when I change the camera resolution: it doesn't crash on smaller SketchUp files, I've run tests. But it's true that this particular file is quite large, 279 MB.
                                      Krass
                                      • pixelcruncherP
                                        @Krass
                                        Have a look at this guide on how to release seats: https://rayscaper.com/faq/licensing/#how-do-i-release-a-license-seat
                                        • pixelcruncherP
                                          @Krass, I'm updating my documentation, stay tuned. If I have time this week, I will also try a video.
                                          • pixelcruncherP
                                            @Krass Yikes, can you get me the logs after a crash happened?
                                            Report a Bug
                                            How to send a bug report that we can act on, with the log files, a description and a scene that shows the problem.
                                            Rayscaper (rayscaper.com)
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 26
                                            • 27
                                            • 15 / 27
