    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
    • majidM
      majid
      Thanks for the update, though I have issues with it. Here is what I get:
      Error: #<LoadError: 126: The specified module could not be found. - c:/users/magic/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/rayscaper/installed/Windows/2023/0.9.82 Beta/resources/SUEX_Rayscaper_LoadLibs.so>
      E:/Program Files/SketchUp/Sketchup 2023/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:83:in require' E:/Program Files/SketchUp/Sketchup 2023/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:83:in require'
      c:/users/magic/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/rayscaper/main.rbe:174:in <module:Rayscaper>' c:/users/magic/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/rayscaper/main.rbe:8:in <main>'
      E:/Program Files/SketchUp/Sketchup 2023/Tools/extensions.rb:197:in eval' E:/Program Files/SketchUp/Sketchup 2023/Tools/extensions.rb:197:in require'
      E:/Program Files/SketchUp/Sketchup 2023/Tools/extensions.rb:197:in load' C:/Users/Magic/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/rayscaper.rb:18:in register_extension'
      C:/Users/Magic/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/rayscaper.rb:18:in <module:Rayscaper>' C:/Users/Magic/AppData/Roaming/SketchUp/SketchUp 2023/SketchUp/Plugins/rayscaper.rb:6:in <top (required)>'
      I uninstalled the previous version, then removed the entire plugin and its loader and reinstalled it, yet the issue persists.
      • pixelcruncherP
        @majid Sorry about that! Can you send me the log files as described here: https://rayscaper.com/getting-help/report-a-bug/#1-export-the-log-files
        • KrassK
          Krass
          Hi Thomas, I can't believe I read that you can now do animation? I just installed it and it works perfectly on my computer. It's a Christmas present! But I'm eager to understand how to create an animation. A tutorial would be great...
          Krass
          • KrassK
            Krass
            I reinstalled Windows; I suppose that explains the license issue I'm having? Rayscaper is installed on two machines.
            Krass
            • KrassK
              Krass
              Sketchup crashes as soon as I click on "double" in the rendering resolution settings.
              and it's systematic
              Krass
              • KrassK
                Krass
                Regarding the animation, is it in the form of a sequence of images?
                Krass
                • majidM
                  majid
                  I guess it is bkz I use SU 2023... and RS does not support it
                  • KrassK
                    Krass
                    you can't use Rayscaper on your 2023 SU ? If yes do you get the same issue when increasing camera resolution?
                    Krass
                    • KrassK
                      Krass
                      ok, i found it
                      Krass
                      1 Reply Last reply πŸ‘
                      • KrassK
                        Krass
                        To get back to my point about the crash when I change the camera resolution: it doesn't crash on smaller SketchUp files, I've run tests. But it's true that this particular file is quite large, 279 MB.
                        Krass
                        • pixelcruncherP
                          @Krass
                          Have a look at this guide on how to release seats: https://rayscaper.com/faq/licensing/#how-do-i-release-a-license-seat
                          • pixelcruncherP
                            @Krass, I'm updating my documentation, stay tuned. If I have time this week, I will also try a video.
                            • pixelcruncherP
                              @Krass Yikes, can you get me the logs after a crash happened?
                              Report a Bug
                              How to send a bug report that we can act on, with the log files, a description and a scene that shows the problem.
                              Rayscaper (rayscaper.com)
                              • pixelcruncherP
                                pixelcruncher Extension Creator @majid
                                @majid I'm supporting 2026, 2025, 2024. I changed that a couple of releases back.
                                • KrassK
                                  Krass
                                  Done, I send the bug report
                                  Krass
                                  • pixelcruncherP
                                    pixelcruncher Extension Creator @pixelcruncher
                                    @krass - Here's the animation guide: https://rayscaper.com/guides/animation/ - Please let me know if everything is clear, or if there are any issues with the feature, because it's brand new πŸ™‚
                                    • KrassK
                                      Krass
                                      Yes, I've already figured out how to render an animation! I'm testing it now.
                                      Krass
                                      • KrassK
                                        Krass
                                        Too bad, my first animation attempt crashes after three frames... yet the functions, animation settings, and interface are very well done.
                                        As soon as I minimize the window to show the desktop, it crashes.
                                        Krass
                                        • KrassK
                                          Krass
                                          By dragging the Rayscaper window to the bottom of the screen, it seems to be holding... I'll let you know in about an hour and a half.
                                          Krass
                                          • pixelcruncherP
                                            @Krass Sorry about that, it's a brand new feature (implemented two weeks ago), so rough around the edges. It would be great if you could also send the logs for this crash?
                                            Pro tip, first render out a small resolution, low samples per pixel animation. They you get an immediate feel for it without having to wait too long πŸ˜‰
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 26
                                            • 27
                                            • 16 / 27
