    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • KrassK
      Krass
      No, I did get a window indicating a problem loading the Rayscaper extension, but it hasn't reappeared.
      Krass
      • KrassK
        Krass
        However, I had installed it correctly without any problems before.
        Krass
        • majidM
          majid
          I have a question regarding material libraries. I have prepared a Carpaint collection and am also going to prepare a water material pack. The question is that if the same name materials will be replaced? i.e. a car paint in my library is called 001red. Imagine there is another material in the Sketchup model by user and called 001red, I am wondering if RS will replace the same name with my material? To be more precise: How do material libraries in RS work?
            I must admit to being more than a little biased here, Majid's contributions in this department have been extremely helpful. Personally, I would like to see all the finish items from twilight included in Rayscaper, they would much improve the goal of simplicity with speed.
            Reply Quote 2
            • pixelcruncherP
              pixelcruncher Extension Creator @majid
              @majid said in Rayscaper New Releases:
              Nice, users will love those material packs!
              No — naming your materials isn’t essential for Rayscaper. Names only matter for finding them in the material library. They are necessary for the user, not for the software.
              Behind the scenes, Rayscaper stores each material as a material pack, which is simply a ZIP file. This pack includes a human-readable configuration file and all the texture images used by the material. I will add this format to my documentation. I hope that, in the age of AI vibe-coding, people can build tools to convert materials from other renderers into Rayscaper, and vice versa.
              When you apply a material in Rayscaper to any material in your SketchUp model, Rayscaper doesn’t replace the SketchUp material. Instead, it configures the existing SketchUp material using the parameters it reads from the material pack.
              You can view the material packs that Rayscaper saves in the %%AppData%%/AssetCache folder (the exact path escapes me, I'm not at my PC right now).
              Cheers,
              Thomas
              • pixelcruncherP
                pixelcruncher Extension Creator @Mike Amos
                @Mike-Amos
                I think my friend @majid requested that before as well 🙂 He has a keen eye for this.
                Given that the Twilight website is offline, is there a source where I can find these things? Maybe I can actually provide tools for using Twilight materials in Rayscaper, or at least the same templates.
                • pixelcruncherP
                  @Krass I will have a look soon to help you out here, stay tuned.
                  • KrassK
                    Krass
                    are you both talking about Twilight render ?
                    Krass
                    • pixelcruncherP
                      @Krass said in Rayscaper New Releases:
                      Yes, @majid and @Mike-Amos are talking about Twilight render. But I'm not too familiar with it myself. But it seems to have a couple of dearly missed features?
                      • KrassK
                        Krass
                        Twilight render was great, but Rayscaper is marvelous compared to it.
                        I can give you the last version of Twilight
                        Krass
                          Yep, trying to get to grips with the actual process or getting them back into the wild.
                            sashapepperspray @sashapepperspray
                            I think I figured something out about the blue material bug, I can make it happen in any file if I use the "edit texture in external editor" in the sketchup material editor, It shows up as blue.
                            (Another thing I noticed, is that If i edit a material in sketchup, it does not automatically update the material in rayscaper.)
                            • pixelcruncherP
                              That's a good clue. I think it also has to do with SketchUp's colorized textures only. But I haven't looked at that part in depth.
                              This is by design; You should press the reload button in the Rayscaper material editor. I could add an "auto-sync" option to do this automatically. Rayscaper has a richer set of material capabilities than SketchUp. I assumed you want to edit the materials in Rayscaper, and that it would be counterproductive to override them from SketchUp repeatedly. Maybe that's not a reasonable workflow assumption.
                                sashapepperspray
                                okay, thanks (a feature request- maybe you can make a seperate reload button for the regular texture, for the metalness, roughness, and normal maps, so If I edit the regular texture in sketchup but want to keep the metallness changes in rayscaper I can do that.)
                                • KrassK
                                  Krass
                                  when I display a SketchUp scene in RS, the hidden tags within that scene are still visible.
                                  And there's still this problem with certain groups containing other groups and components that don't display unless everything inside is exploded. And I can't always explode everything, as I have variations to make in subsequent steps.
                                  And i no graphic card
                                  Krass
                                  • pixelcruncherP
                                    Hey, Rayscaper users!
                                    Rayscaper 0.9.79 Beta is available. You can get it via:
                                    • The SketchUcation store.
                                    • Direct download: link.
                                    I recommend upgrading to the latest version.
                                    What Changed?
                                    • Add log export feature. You can now export Rayscaper logs directly from the application menu, making it easier to
                                      share diagnostic information when reporting issues. You can access it via the SketchUp menu bar:
                                      Extensions > Rayscaper > Export Logs for Support.
                                    • Add a reset button for the post-processing tab. Quickly restore default post-processing settings with a single click.
                                    Help Me Build the Community 👍
                                    If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities
                                    to new users.
                                    Follow me on https://x.com/rayscaper3d.
                                    Happy Rendering!
                                    Thomas
                                    • pixelcruncherP
                                      @Krass
                                      Do you mind sharing the scene via e-mail?
                                      Same here, a scene with screenshots of the components would help a lot.
                                      Can you check with the latest version I just released? Also check if that version brings the icons back. I think this has to do with your broken installation.
                                      Regards,
                                      Thomas
                                      • KrassK
                                        Krass
                                        anyway, it's fixed, the latest version installed correctly.
                                        As for objects on hidden tags, it's still the same; objects on hidden tags in the SU viewport are displayed in the Rayscaper render.
                                        Krass
                                        • KrassK
                                          Krass
                                          I finally understand how to use the denoiser. You might initially think that a low-resolution render will be calculated faster... But actually, when the denoiser is applied during rendering, especially when the render resolution is high, the denoising is very clean.
                                          It might seem obvious to you, but it took me a while to figure it out. So I leave the denoiser at full power and immediately set the render size to 2k or higher.
                                          Krass
                                          • KrassK
                                            Krass
                                            Thomas, you asked me why I apply an upscale layer after a ray-scaping render. For scenes with windows, I have to do two renders, like a photographer: a light one for the room's exposure and a dark one to replace the "blown-out," overexposed parts of the window. D5 Render doesn't have this problem because its renders aren't truly photographic; they're a kind of pseudo-pathtracing.
                                            Krass
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 37
                                            • 38
                                            • 15 / 38
