    Is there a way to "define the scale" of a group of objects in SketchUp?
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    15 Posts 3 Posters 890 Views 3 Watching
    • alexpacio2013A Offline
      alexpacio2013
      Is there a way to "define the scale" of a group of objects or multiple selected components simultaneously, with the option to also scale nested objects and components? For me, it’s a useful command, but I haven’t found a solution.
        alexpacio2013
        I’m not a programmer, and I don’t know Ruby. I tried using artificial intelligence to create a plugin, and it works, but only on main objects and components, not on nested ones.
          If your AI is clever enough. you need to ask it how to process the entities inside definitions [i.e. components and groups] using an iteration...
          alexpacio2013A 1 Reply Last reply Reply Quote 1
            alexpacio2013 @TIG
            @TIG I didn't manage to do it. In your opinion it's not a useful function. I would need it. there is a solution
              I'm not AI.
              BUT I'll outline the steps for you...
              Run these snippets in the Ruby Console.
              1. Find all 'containers' [i.e. groups and component-instances].
              2. Decide if you want to process all of them in your model. OR those in a selection. Here are the two ways a and b.
              3a. #code
              model = Sketchup,active_model
              containers = model.definitions.to_a #an array of ALL groups and component definitions, including any nested ones.
              OR
              3b. #code
              model = Sketchup.active_model
              selection = model.selection
              containers = [] #an empty array
              selection.each{|e|
                next if ! e.is_a?(Sketchup::Group) || ! e.is_a?(Sketchup::ComponentInstance)
                containers << e.definition
              containers.uniq! #ignore duplicates
              #containers is now an array of selected groups and component-instances' definitions, BUT not any that are nested.
              1. #use puts to see the results, e.g.
              puts containers
              Process [scale ?] the array of the 'containers' as you desire... one at a time e.g.
              containers.each{|e|
                # whatever...
              alexpacio2013A 1 Reply Last reply Reply Quote 0
              • Rich O BrienR Rich O Brien marked this topic as a question on
                alexpacio2013 @TIG
                @TIG I've tried but it doesn't work. I'm attaching an image as an example where I've modified the scale of each cube and also the scale of a group that contains three cubes. In practice, I would like that once all objects are selected, I can define the scale for all of them, even those nested inside the group.
                  Once you have a collection of selected 'containers' [groups and component-instances] you need to go though that array and do the same again to each 'container's' entities, selecting any new 'containers', repeat this until all nested 'containers' are got.
                  Here's an outline of an example...
                  def miner(entities=Sketchup.active_model.to_a)
                    entities.each{|e|
                    #process the containers
                    containers.each{|e|
                      #do scaling code on 'e'...
                    #containers is an array of selected groups and component-instances' definitions,
                    #BUT not any that are nested.
                    #Next go through the container.entities -
                    #this repeats until there are no containers left to process.
                    return nil unless containers[0]
                    containers.each{|e|
                      miner(e.entities) #repeats itself !
                  end#def
                  #run with miner(Sketchup.active_model.selection.to_a) after first making your selection...
                  alexpacio2013A 2 Replies Last reply Reply Quote 0
                    alexpacio2013 @TIG
                    @TIG
                    Is it necessary to repeat this operation for every single object? I need a single command to set the scale for all selected elements (including nested components and groups) with just one click. Otherwise, it would be faster to do it manually
                    TIGT 1 Reply Last reply Reply Quote 0
                      alexpacio2013 @TIG
                      @TIG I think I found it. Gemini gave me this solution and it works logically. The components will become unique, but it does exactly what I wanted. Since you're the expert, could you check if it works well?
                      require 'sketchup.rb'
                      module Visual_Scale_Applier
                      def self.apply_scale_to_selection
                      if selection.empty?
                        UI.messagebox("Seleziona gli oggetti a cui vuoi 'fissare' la scala.")
                        return
                      model.start_operation('Fissa Scala Corrente', true)
                      selection.each do |entity|
                        self.process_entity(entity)
                      model.commit_operation
                      puts "Scala 'fissata' a 1.0 per la selezione e tutti i contenuti nidificati."
                      def self.process_entity(entity)
                      return unless entity.is_a?(Sketchup::ComponentInstance) || entity.is_a?(Sketchup::Group)
                      # 1. Se è un componente con più copie, lo rendiamo unico per non rovinare il resto del modello
                      entity.make_unique if entity.is_a?(Sketchup::ComponentInstance)
                      t = entity.transformation
                      # Estrarre i fattori di scala correnti
                      scale_x = Math.sqrt(t.to_a[0]**2 + t.to_a[1]**2 + t.to_a[2]**2)
                      scale_y = Math.sqrt(t.to_a[4]**2 + t.to_a[5]**2 + t.to_a[6]**2)
                      scale_z = Math.sqrt(t.to_a[8]**2 + t.to_a[9]**2 + t.to_a[10]**2)
                      # Se la scala è già 1.0, non facciamo nulla su questo livello
                      unless (scale_x - 1.0).abs < 0.001 && (scale_y - 1.0).abs < 0.001 && (scale_z - 1.0).abs < 0.001
                        # 2. Creiamo una trasformazione di scala per la geometria interna
                        internal_scaling = Geom::Transformation.scaling(scale_x, scale_y, scale_z)
                        # 3. Trasformiamo la geometria interna (bordi, facce, etc.)
                        entity.definition.entities.transform_entities(internal_scaling, entity.definition.entities.to_a)
                        # 4. Resettiamo la scala del contenitore esterno a 1.0 mantenendo posizione e rotazione
                        new_transformation = Geom::Transformation.axes(
                          t.origin,
                          t.xaxis.normalize,
                          t.yaxis.normalize,
                          t.zaxis.normalize
                        entity.transformation = new_transformation
                      # 5. Entra ricorsivamente nei gruppi/componenti nidificati
                      entity.definition.entities.each do |child|
                        self.process_entity(child)
                      Esegui
                      Visual_Scale_Applier.apply_scale_to_selection
                        alexpacio2013
                        @tig
                        I have included a final status message and a count for the modified objects.
                            if selection.empty?
                              UI.messagebox("Seleziona gli oggetti a cui vuoi 'definire' la scala.")
                              return
                            @count = 0
                            model.start_operation('Definisci Scala Corrente', true)
                            # Messaggio di successo richiesto
                            UI.messagebox("Scale definition of all objects/components successfully completed.\nElementi elaborati: #{@count}")
                            # Rende unico il componente se necessario per non influenzare copie non selezionate
                            # Calcolo dei fattori di scala correnti
                            # Applica la trasformazione interna se la scala non è già 1.0
                              # Resetta il contenitore esterno a scala 1.0
                                t.origin,
                                t.xaxis.normalize,
                                t.yaxis.normalize,
                                t.zaxis.normalize
                              @count += 1
                            # Processo ricorsivo per elementi nidificati
                        # Esecuzione
                          TIG Moderator @alexpacio2013
                          @alexpacio2013
                          You have misunderstood.
                          It works on your selection of 'containers' AND any 'containers' inside those etc, iterating...
                          As your later example shows too.
                          You just needed you to add in some of your scaling code...
                          alexpacio2013A 1 Reply Last reply 👍 Reply Quote 0
                            alexpacio2013 @TIG
                            @TIG @thomthom
                            The created Ruby script works with practically all objects and components, except for those not converted to SubD and QuadFace. Furthermore, these types of objects do not work even when handled individually with standard scale commands.
                            • panixiaP Offline
                              panixia
                              I think that there's a pretty obvious logical problem with this.
                              If you have a component with X instances of another component nested into it and each one of them has a different scale factor, only one of them can be used to set the "definition".
                              And which one the algorithm should choose?
                              Based on which criteria?
                              That's why Gemini is trying to make each instance unique.
                              It's not a code problem. It's definitely a logical problem.
                                alexpacio2013 @panixia
                                @panixia In certain situations, I am willing to lose the instances. This is particularly true when I am building external component libraries: every component within is stripped of all scale and instance definitions. I accept this compromise.
                                Buon anno, Marcello. 🖐
                                • panixiaP Offline
                                  panixia
                                  Yeah, I think you'll definitely need to live with the compromise, because there's not some "universal" solution to this problem (and it can get even more complex with multiple nesting levels and/or multiple instances of the "father" component with different scale factor.
                                  You will indeed loose the "instancing" benefit, otherwise it will be a mess.. No matter the code.
                                  Buon anno a te!
                                  • alexpacio2013A alexpacio2013 has marked this topic as solved on
