    Rayscaper render.
    34 Posts 4 Posters 4.6k Views 4 Watching
    • ntxdaveN
      ntxdave @Rich O Brien
      @Rich-O-Brien said in Rayscaper render.:
      @ntxdave said in Rayscaper render.:
      Can you point me to the source or is there a source for "free" materials you would recommend?
      Poly Haven
      The Public 3D Asset Library
      Poly Haven (polyhaven.com)
      Those are already bundled with Rayscaper
      OK, I went there and see one I would like to use, however when I downloaded it, it was a "blend" file. Yes, it is available in Rayscaper but I would also like to use it in SketchUp. Is there a way to do that?
      Press F1...thank me later
        Rich O Brien Moderator @ntxdave
        In SketchUp you can apply any bitmap based material onto faces to represent whatever you want.
        Then in RS drag any of its materials onto that and it will inherit the UVs.
        Just give it a go. Paint a cube in SketchUp with a Brick material. Then press render and drag one of the bundled materials on to the cube.
        ntxdaveN 1 Reply Last reply
          • ntxdaveN
            @Rich-O-Brien yes, I know how to do that. πŸ˜€ However, for my animation I wanted some better looking materials. Currently you cannot render animations in RayScaper (although @pixelcruncher has said that will be in a future release).
              If you are referring to creating SketchUp materials then in SketchUp you can press F1 at any time to go straight to their help docs and get info on making material libraries.
              If you are referring to getting just the bitmaps off Polyhaven then choose ZIP:
              Then you can pick to just grab the bitmaps in whatever format you need.
              ntxdaveN Rich O BrienR 2 Replies Last reply
              • pixelcruncherP
                pixelcruncher Extension Creator @Mike Amos
                @Mike-Amos Thanks for the heads up, will have a look.
                • ntxdaveN
                  OK, but for SketchUp, which format should I pick/download since SketchUp uses SKM files?
                    Rich O Brien Moderator @Rich O Brien
                    I already shared how you can learn to create your own materials in SketchUp.
                    F1 is your friend
                    • ntxdaveN
                      @Rich-O-Brien OK, I am making some progress but not exactly where I want to be yet. Having some silly issues on where things are being saved. 😧
                      Once again, thanks for your feedback and patience.
                      • ntxdaveN
                        ntxdave @ntxdave
                        I created a material, but I am having problems adjusting the texture. I created a wood texture that I want to apply to in my model. Had no problems but now I want to adjust the texture. I applied to a group object and that went fine. Now I want to adjust the texture. Seems like no matter what I do, I cannot get the texture moderator to launch. I have tried selecting a single face and the whole object but when I right click on a face I can not get the option to adjust the texture.
                        I tried the same process in a very simple model and as long as I only select a single face I can get it to work. Doesn't work in my model though.
                        Any suggestions?
                          If you review what you did you'll see the issue.
                          Painting groups is not the same as painting geometry.
                          You shouldn't paint containers.
                          • ntxdaveN
                            ntxdave
                            I think I/we have had to many posts in this thread that distract from the Rayscaper render theme. Is thee any way we can move all of the posts about creating and editing materials to another thread?
                            At some point I would like to get back to the thread topic of rendering a (my) model with Rayscaper so that we can be fair to the Rayscaper team.
                            I also would like to have a better thread for discussing how to create materials and textures and saving them to a folder where I can use them in other models. I am making some progress but keep running into some silly problems and again the issues are not related to Rayscaper and this do not want to distract from this thread's theme.
                              Speaking personally, everything to do with render has a place in a render thread but I understand your point. There is a render section of this forum but perhaps it needs to develop to be more inclusive of render programs so we can more easily relate to individual AND common topics.
                              • ntxdaveN
                                ntxdave
                                In order to get this topic back on track, I have created a new thread to discuss the materials issue(s). Here is a link to that thread https://community.sketchucation.com/topic/164671/create-new-or-adjust-materials
