    Rayscaper render.
    34 Posts 4 Posters 4.6k Views 4 Watching
    • pixelcruncherP
      Despite the gremlins, nice render. Working on chasing down the gremlins.
      Mike AmosM 1 Reply Last reply
        Mike Amos @pixelcruncher
        @pixelcruncher OK, another week another Windoze solution that is not. Not able to activate the Rayscaper license now.
          Manage your seats at https://sketchucation.com/webshop/my-licences.php
          If you keep activating on different devices you will run into seats exceeded.
          You need to release seats on devices you don't use.
            Got it Rich, the system not reacting to inputs was a bit of a drain but I got there. I cannot match the sketchup viewport in Rayscaper now but then since reset of windoze, everything has been more than a little off.
            I cannot say the entertainment level is low tho'.
            • ntxdaveN
              ntxdave
              OK guys, this is not a very good one, but I have been doing some fooling around and testing. First, I will share some pictures of something I received from a fried that I then did a 3D model of using SketchUp and then rendered with Rayscaper.
              Here are some images of what i received: (OK, images too large)
              Here is my render with Rayscaper:
              I know this is not very fancy. I would like to have some advice as to how it might be made better.
              Press F1...thank me later
                HDR environment light. Search the Studio category and set the Transparent flag on.
                Setting HDR to Transparent in Rayscaper
                With the lighting set you can play with materials to see how they interact with the light.
                ntxdaveN 1 Reply Last reply πŸ‘
                • ntxdaveN
                  ntxdave @Rich O Brien
                  @Rich-O-Brien Thanks @Rich-O-Brien . I will try this later.
                  I have some images/photos that I took with my iPhone that I would like to share, however, I am having problems opening them. They say that are PNG file but every app I try to open them with says they are not a valid file type.
                  Can someone give me some advice about how to open these files so that I can get them into a format/size that I can share on the forum?
                  One of the things I would like for people to see is that the item that was share with me, and the model I created and shared in the previous post is not really created the way viewers might suspect. The word "Jesus" was created by creating pieces that are attached to a wood block that outline the word. It was not created by adding text to the block. I found this kind of interesting and is what inspired me to create a model using the same technique.
                  @Rich-O-Brien Here is a new render using the approach you suggested. Jesus Rayscaper 2.png
                  I also have done an animation that show creating "Jesus" one letter at a time. However, I have not found a way to create the animation using Rayscaper. If someone can tell me how to do that, I would appreciate it so a can "bring the model to life". πŸ˜€
                  • pixelcruncherP
                    Maybe the easiest is to attach one of those image files so we can have a look?
                    Nice, it played a trick on my brain because it took a while before I saw the word "Jesus".
                    Currently, Rayscaper does not have animation support. But that will come with the next release, although that will only support SketchUp scene animations (camera & sunlight). How are you animating these letters?
                    Cheers,
                    Thomas
                      @ntxdave kinda hard to suggest improvements. Share the file
                      • ntxdaveN
                        ntxdave @pixelcruncher
                        @pixelcruncher said in Rayscaper render.:
                        OK, I finally got a couple of the images so I can now share them.
                        😁 That is part of what triggered me developing the model in SketchUp
                        In this case, my animation is a set of scenes animated. Yes, I am animating presenting the letters. πŸ˜€
                        Did I also see/read that you are also looking into working with Animator?
                        Cheers,
                        Thomas
                        @Rich-O-Brien said in Rayscaper render.:
                        Although there are some problems in the model, I am sharing it here: Jesus Animation.skp
                        And here is the animation: Jesus Animation.mp4
                        • ntxdaveN
                          ntxdave @ntxdave
                          Was kind of hoping for some feedback. πŸ˜€
                            The camera is set to Orthographic which doesn't suit Environmental maps so you won't get the correct lighting.
                            Your textures applied to the main board are a herring bone floor texture. Not quite sure if that is correct? Unless it is some type of intentional choice?
                            Your texture for the 'font' are scaled to a large value which seems to clash with the tiny herringbone texture.
                            When you consider the object itself is 1.5" x 5.5" there seems to be a non-physically correct texture dimension.
                            Hard to create a great or meaningful render if your textures are not physically correct. Having textures reflect real world objects and appearance helps sells believability.
                            The model itself has textures applied to both the groups and geometry within the groups.
                            If it was me, I would consider what it the object made of and go source a texture that helps sell that aspect. Polyhaven has loads of textures but most important is they tell you the size:
                            So if you make a texture using these in SketchUp you can set that size for the correct appearance.
                              • ntxdaveN
                                First, let me say I really appreciate your feedback. Although this model is very "elementary", it is far different from the type of modeling I have done in the past. πŸ˜€
                                Now I will respond to your comments (positively I hope):
                                OK, I will change that that in a future version.
                                Agree, this was not a good texture choice. Again, I will try to improve in a newer version.
                                The size I used when creating the model was based on the actual dimensions of the object I had received. Creating it at that size caused several problems (some of which you have pointed out). I will redraw at a much larger scale and then look at resizing later (not sure I will need to really do that though).
                                I like the texture in your image much better than what I used and will do some looking around (including the site you referenced.
                                There really was no "font" (as I think you pointed out) The texture I used to "outline"/create the text was something I used to try to emulate what was on the item that was given to me. I might stick with that or try to find something closer to "real object".
                                Again, I REALLY appreciate your comments and hope I can use them to improve my model. This project has some meaning to me that I do not know how to share. As I said before, the original object was a gift that I found inspiring, and I would like to be able to create a got SketchUp version.
                                • ntxdaveN
                                  ntxdave
                                  @Rich-O-Brien
                                  I like the material in the image you posted.
                                  • Can you point me to the source or is there a source for "free" materials you would recommend?
                                  • How do you add materials to Rayscaper?
                                  I have redrawn the model completely to overcome some of the problems in the version I posted. One of the main things I did was draw the model at a much larger scale so that some of the problems will be overcome. I also made each segment of the panels that create the text are individual groups which should solve some of the goofiness that showed up in the version I posted. At some time later I will decide whether to resize the model to more closely match the original object or just leave it at the new (larger) size for rendering and animating.
                                  Can you help me understand the issue related to orthographic? BTW: In the new model I used perspective as part of the camera settings. Should I stick with that or do something different?
                                  I know this is a very simplistic model, but it is far different from what I have done in the past (car wash equipment and @Majid Alpha Inspired Sketches of buildings) so please be patient with me. πŸ˜€
                                    Rich O Brien Moderator @ntxdave
                                    @ntxdave said in Rayscaper render.:
                                    Poly Haven
                                    The Public 3D Asset Library
                                    Poly Haven (polyhaven.com)
                                    Those are already bundled with Rayscaper
                                    Materials
                                    Edit materials, sync them with SketchUp and set the color, opacity, normal map and emission that most material types share.
                                    Rayscaper (rayscaper.com)
                                    HDR environment maps a equirectangular. If your camera is Ortho then it cannot 'map' the environment to surround your scene.
                                    If you want the Ortho look then set your FOV in SketchUp to something really low 5-6deg when using Perspective.
                                    You should experiment and learn in small bits and pieces until you begin to understand. There's no magic bullet. Just trial and error.
                                    Butif you have the object to hand then you have all the reference you need.
                                      Just a simple observation. I tried the new designation for the diffuse hey eye render, now simply ai render. It prevents Rayscaper from opening. Tried it several times with the same result. Disable ai render and Rayscaper will function As intended.
                                      I thought I would report this here as information.
                                      • ntxdaveN
                                        Poly Haven
                                        OK, I went there and see one I would like to use, however when I downloaded it, it was a "blend" file. Yes, it is available in Rayscaper but I would also like to use it in SketchUp. Is there a way to do that?
                                          In SketchUp you can apply any bitmap based material onto faces to represent whatever you want.
                                          Then in RS drag any of its materials onto that and it will inherit the UVs.
                                          Just give it a go. Paint a cube in SketchUp with a Brick material. Then press render and drag one of the bundled materials on to the cube.
