    2.3k Posts 515 Posters 2.5m Views 520 Watching
      Donations are direct to developers PayPal. You’d need to ask whoever it is you sent a donation to.
        sd091688 Newcomers
        I recently installed round corner but when I use it it appears as per photo attached mentioned trial period expired. Asking to get license.
        Hope anyone can help to make it work cause I need it urgently.
        TYIA
        • fredo6F
          What happens if you click on Manage License and revalidate the license?
            @sd091688 did you click manage license?
            • L
              LEADERFIT3D Newcomers @Rich O Brien
              @Rich-O-Brien
              Bonjour, voici un exemple
              Et ce que vous m'avez demandé me semble t'il :
              Fredo6 Plugins Information on 2025-10-15 12:44:23 +0200
              • Platform: x64-mswin64_140 - Ruby: 2.7.7
              • Sketchup: 23.1.340
              • LibFredo6: v15.2a
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.1
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                Curviloft v2.0a
                Curvizard v2.5a
                FredoScale v3.6a
                FredoTools v4.5c
                RoundCorner v3.4a
                ToolsOnSurface v2.6a
                TopoShaper v2.7a
                VisuHole v1.5a
                Signature File: 2025-06-04 13:40:49 +0200
                @LEADERFIT3D
                You have a few items to update
                • Librfredo is now 15.5a: https://sketchucation.com/pluginstore?pln=LibFredo6
                • Sketchucation Tools is now 5.0.3: https://sketchucation.com/plugin/696-sketchucationtools
                Restart SketchUp after updating and try licensing again.
                If the error repeats it maybe related to your device name. Special character like áéíóú etc are not allowed. Please rename your device to only use alphanumeric characters.
                If you have recently reinstalled your OS this can raise errors. If so, please go to C:\Users\SomeName\AppData\Local\SCF Licenses and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file.
                Restart SketchUp and try again.
                L 1 Reply Last reply
                • N
                  nlipovac
                  Hi Fredo,
                  I work for a school where I teach 3D modeling to interior designers, and they would like to purchase Fredo6Bundle2022Corp30 - A bundle of 8 plugins for activation on 30 devices, but the administrator would like a proforma invoice instead of buying it through the Sketchucation store. Is that doable?
                  • E
                    epitaph Newcomers
                    After using fredoghost in the model, there will be a warning as shown in the figure when the model is opened again. In addition, lord of toolbar cannot be used normally in version 2026, and it will disappear after adding a custom toolbar and restarting.
                      This looks more like an issue with Libfredo and FredoGhost than our licensing system.
                      Maybe ping Fredo on his FredoGhost thread
                      • T
                        Tramhuong Newcomers
                        @sd091688 said in SCFLicense: Extension Licensing on Sketchucation:
                          @Tramhuong Do you have a problem ?
                          You are quoting another user's problem.
                          • L
                            @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
                            C:\Users\SomeName\AppData\Local\SCF Licenses et supprimez le fichier SCFLicenseSignature - NE PAS MODIFIER NI SUPPRIMER.txt .
                            Bonjour
                            Voici ce qu'il y a dans le dossier en question :
                            Je n'ai pas réinstallé le système, j'ai changer de PC en intégralité... Système d'exploitation inclus
                              @LEADERFIT3D
                              The advice here: https://community.sketchucation.com/post/1617255
                              Delete this:
                              Restart SketchUp
                              1 Reply Last reply 👍
                              • O
                                othn11 @fredo6
                                @fredo6
                                hi, ther's any type of discount for subscription "Fredo6 Bundle 2022 - A bundle of 8 plugins"
                                thank's
                                • P
                                  ppappa0099 Newcomers
                                  @fredo6
                                  Can you help me.!!
                                  I don't know why.
                                  螢幕擷取畫面 2025-11-13 010402.png 螢幕擷取畫面 2025-11-13 010420.png 螢幕擷取畫面 2025-11-13 010429.png
                                    Rich O Brien Moderator @ppappa0099
                                    @ppappa0099
                                    Please follow the prompt and delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
                                    Restart SketchUp
                                    If your device name uses special characters please rename it to only use alphanumeric.
                                    P 2 Replies Last reply
                                    • P
                                      ppappa0099 Newcomers @Rich O Brien
                                      @ppappa0099
                                      Restart SketchUp
                                        mandraget
                                        hi fredo can you help me releasing my round corner license because there no option to release it from web, i need it asap, thank you
                                        • N
                                          nguyenhung269 Newcomers
                                          I can't log out of activation on other computers can you help me
                                            Rich O Brien Moderator @mandraget
                                            @mandraget said in SCFLicense: Extension Licensing on Sketchucation:
                                            Update extensions on all these devices to enable online releasing.
                                            Most important is to update Sketchucation Tools.
                                            M 1 Reply Last reply
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 115
                                            • 116
                                            • 107 / 116
