    Open the extension store in sketchup
    16 Posts 6 Posters 850 Views 6 Watching
      Bereng Newcomers
      Hello,
      I just created a count. I downloaded your extension store in SketchUp 2025. When I click on the red icon to open all the plugins you offer, I have to enter my username and password, which I do but it remains stuck on this page. What should I do to unblock the situation? Thank you for your help.
      Berengere
      G 1 Reply Last reply Reply Quote 1
        Can you provide screenshots of where it 'sticks'.
        Are your username and password both exactly as set up for the main web site ?
          Gábor
          Could you describe which page you are stuck on? The one where you enter your login details? Are you getting any error messages after clicking on the "Sign In" button?
            Dam303 Newcomers
            Hello,
            I am facing the same problem on SKP2025, first time using the extension. Hereafter a video showing the login issue:
            https://streamable.com/pxlu8v
            I am running SKP 25.0.633 on OSX 12.7.6, Intel MBP 15" 2015.
            Regards,
            Damien
            Rich O BrienR 1 Reply Last reply Reply Quote 2
            • Rich O BrienR Online
              Rich O Brien Moderator @Dam303
              @Dam303 said in Open the extension store in sketchup:
              Hello,
              Regards,
              Damien
              Do you mind if I reset your password manually and send you the new details via email? So we rule out some stuff?
                Dam303 Newcomers
                Yes you can reset my password.
                Regards,
                Damien
                  @Dam303
                  Please logout of your account and I'll send login details to the email associated to your account.
                    Dam303 Newcomers
                    I logged with credentials you provided and still facing the same issue.
                      OK, we will explore it more and see if we an find a root cause.
                      Thanks for testing.
                      If you need to revert to 4.4.1 it is below:
                      SketchUcationTools_v4.4.1.rbz
                        Dam303 Newcomers
                        I just revert to 4.4.1 linked below and this version is working.
                          leoww95
                          +1 with the same problem, 5.0 keeps asking to login, type username, password click login, it refresh without any mesage back to login again.
                          install back 4.4.1 login ok.
                            Gábor @Bereng
                            @Bereng , @leoww95
                            Can I ask you which operating system do you use? (IOS or Win)
                              Gábor
                              All,
                              Could you please try again with v5.0? I made some changes at server-side and would like to see if it fixed the problem or not.
                                Dam303 Newcomers
                                I just tried V5.0 (SKP25 / OSX) and I can now log on correctly. Thanks !
                                  Gábor
                                  @Dam303 Thank you very much for reporting the original issue and testing the fix today.
                                  It was a hard-to-fix, nasty issue. Three of us worked on it yesterday, and at last we managed to fix it.
                                  D 1 Reply Last reply Reply Quote 0
                                    Dam303 Newcomers @Gábor
                                    @Gábor Great , I also tried V5 on SKP25 running WIN10 and it logs correctly too.
                                    thank you for you fast reaction.
                                    Damien
