    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • Rich O BrienR Online
      Libfredo is the engine his other extensions require to function.
      You can download whatever other of Fredoโ€™s extensions you want.
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v15.3c - 17 Apr 25
        LibFredo6 15.3c is a minor release. It includes changes related to:
        • ROB Axyz
        • Bug Fixing and technical adjustments
          TeKnoel
          I'm having a problem after a crash. all of a sudden SketchUp keeps crashing when loading my plugins. I've deleted LibFredo6 and it will open. Then ill re install it and it will crash. do you have any advice?
          T 1 Reply Last reply Reply Quote 0
            TeKnoel @TeKnoel
            @TeKnoel I've been working on a fresh install of all my plugins it seems the conflict might be s4u frame and scene exporter. i just deleted that one and it seems to be loading most of my stuff again
              Mario van Hout Newcomers
              This is the first time i uploades plug-ins.
              The download and installation went well (even though normally i have to ask the administrator).
              I can see the LibFredo6 settings under tab Windows
              But how do i get the toolbar on my workspace? I don't see it... in the video it shows the LibFredo6 toolbar.
                LibFredo is a helper library. On its own it does very little and does not need a toolbar.
                You need to install Fredo extensions that use it.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v15.4a - 13 May 25
                  LibFredo6 15.4a is a minor release. It includes changes related to:
                  • LayOps v1.1 (dual Dimensions in Layout)
                    chaochaiva Newcomers
                    Every time use Roundcorner 3.4a after select conner then press enter ,theSketchup2025 always turn off
                    XXX note i already update to LibFredo 15.4a
                    • fredo6F Offline
                      Which platform?
                      Do you get a bugsplat?
                      Does it happen with any model?
                        simulat
                        Hello, I'm running sketchup 2020 and all of your plugins have recently started causing sketchup to crash all the time. I keep getting these errors. I have attempted reinstalling etc but no luck. any thoughts?
                        Error: #<FrozenError: can't modify frozen String>
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:299:in upcase' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:299:in store_value'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:226:in block in set' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:209:in each'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:209:in set' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:199:in []='
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:71:in <module:Traductor>' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:23:in <main>'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:353:in eval' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:353:in require'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:353:in require_ruby' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1159:in block (2 levels) in load_full_rubies'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1156:in each' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1156:in block in load_full_rubies'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1154:in each' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1154:in load_full_rubies'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1081:in effective_load_part2' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1040:in effective_load'
                        c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/loader__libfredo6.rbe:1:in <main>' C:/Users/trask/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:47:in eval'
                        Error: #<NoMethodError: undefined method +' for nil:NilClass> c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugindialogs.rbe:156:in purge'
                        !libfredo6/top_libfredo6.rbe:470:in after_startup' c:/users/trask/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:605:in detect_startup_of_sketchup'
                        !libfredo6/top_libfredo6.rbe:600:in `block in detect_startup_of_sketchup'
                        • fredo6F Offline
                          Did you do something specific so that these errors occur, like reinstall Sketchup? I mean what you say as 'recently'
                            simulat
                            No I was getting these errors and sketchup crashing just this week prior to doing anything. I haven't changed anything with my installs. When I opened sketchup this week it asked me to update fredo6 which I did. I was also having issues with thru paint showing up. So I uninstalled that and reinstalled. It then said my trial expired, so I purchased that. Still was getting these errors and sketchup crashing. Every so often it will crash and then when I reload sketchup all of your fredo toolbars are stacked in the middle of my screen not where I had them. I've had to put them back probably 16 times now. In an attempt to fix things, I did a "repair" install on sketchup, but that did not change anything.
                            Should I attempt a full uninstall reinstall? anything else I could try before that?
                            Thank you
                            TIGT 1 Reply Last reply Reply Quote 1
                              TIG Moderator @simulat
                              @simulat
                              When you did the 'Repair' did you 'Run' the SketchUp installer's exe file by double-clicking it, or by selecting it > right-clicking > context-menu > Run as administrator
                              The second way is correct, the other way is wrong, and it can lead to all kinds of unpredictable permission related issues, such as settings being unsaved etc...
                                simulat
                                It was already set to run as administrator, I had to give permission to repair. I was getting these errors and issues before doing that too.
                                  simulat
                                  This is what it keeps doing to my tool bars. I was just using Thrupaint and it crashed. This is how my file opens after
                                    Dave R @simulat
                                    @simulat that is typical of incorrect installation on Windows which prevents SketchUp being able to write the required file that stores the toolbar locations. . Correct installation requires right clicking on the installer and choosing Run as administrator. That's not the same as running SketchUp as administrator.
                                    Are you running a cracked version of SketchUp 2020?
                                      simulat
                                      Hi Dave, I am very familiar with how to install programs as an administrator. No where did I say I'm running sketchup as an administrator.
                                      I did a repair install as an administrator. I will say this again, this problem started before I changed or did any repair installs. It happened before and after.
                                      This definitely has to do with Thrupaint or other fredo plugins to some degree. I did some tests where I tried to use it and it crashes sketchup every time within 1 to 2 mins. Whatever the recent updates were to the plugin changed something.
                                        simulat
                                        Ok I did a full uninstall, restart, right clicked run as admin, installed. Everything is still crashing. Here is a video while using Thrupaint.
                                        2025-06-07_11-39-59.mp4
                                        • fredo6F Offline
                                          Based on your video, the bugsplat may be due to the model, not to the installation of ThruPaint / LibFredo6. ThruPaint seems to work on some surfaces, and then crashes on one particular.
                                          Maybe, the best would be to send me the model and some instructions to reproduce the problem.
                                            simulat
                                            Here's a link to the file:
                                            https://www.dropbox.com/scl/fi/0xdfoi2n7tw8aqzg8p7j0/Bathroom-01.skp?rlkey=jmtzzwv7m0x6uooq9oczdo4pl&dl=0
                                            • I just open the file, open thrupaint, select the brass material on the faucet or the material on the towel and attempt to paint the towel. That was causing me the most crashes. Also messing with the scale rotate feature after painting.
                                            -I had issues with other large sketchup files crashing too, I don't think it was just this file.
                                            I was able to test it with someone that has sketchup 2025 and thrupaint was working fine no crashes. I think it has something to do with 2020 version.
                                            I was also noticing I can't always get the Thrupaint dialog window to load, I have to click around several times sometimes it will open sometimes it won't.
                                            Thank you!
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 109
                                            • 110
                                            • 63 / 110
