    Make Unique Texture giving weird results
    Scheduled Pinned Locked Moved Solved SketchUcation Community Forums
    19 Posts 3 Posters 2.3k Views 3 Watching
    • grizzlerG
      grizzler @Rich O Brien
      @Rich-O-Brien I used to use Photoshop Elements for years because I only do basic stuff, but now I'm trying to get to grips with GIMP which seems to offer everything I need for free, but it's offered in a more confusing way πŸ˜–
      • grizzlerG
        grizzler
        Here's the fix for anyone with this issue:
        Window > Preferences > Graphics, and set the Graphics Engine to "Use Classic Graphics Engine"
        grizzlerG 1 Reply Last reply
        • Rich O BrienR Rich O Brien marked this topic as a question on
        • grizzlerG
          grizzler @grizzler
          @grizzler I just updated to the latest version of SU 2024 this morning having ignored the previous incremental updates; this issue still persists. I really want to use the new graphics engine but I can't πŸ˜–
          Dave RD 1 Reply Last reply
            Dave R @grizzler
            @grizzler said in Make Unique Texture giving weird results:
            What graphics card are you using?
            • grizzlerG
              grizzler @Dave R
              @Dave-R RTX 4090, so that should cope with anything.
              Rich O BrienR Dave RD 2 Replies Last reply
                Rich O Brien Moderator @grizzler
                @grizzler That's a beast of a card
                • grizzlerG
                  @Rich-O-Brien said in Make Unique Texture giving weird results:
                  I needed to upgrade from my old 3060Ti (good card but lacks vram), so I deliberated for a week whether to get the 4080 or 4090 and in a moment of madness I just went for it 😁
                    Dave R @grizzler
                    @grizzler that graphics card will support the new graphics engine. I expect there's something else going on in your model.
                    • grizzlerG
                      grizzler @Dave R
                      @Dave-R It happens on every single model though. If I use the pins to stretch an image to fit a flat surface in Sketchup where it looks fine, I then look at it in a render software (I've had this in 3 renderers so far) and it's a mess, so I found that by making the material unique it resolved the issue in all softwares - that is until I use the new graphics engine.
                      • grizzlerG
                        grizzler
                        I'm re-igniting this thread because even though I've upgraded my PC, moved onto SU2025 and switched from Enscape to D5, this problem of contorted textures from images imported into Sketchup still persists with the new graphics engine only. I've upgraded all that other stuff I mentioned but I'm having to use the old graphics engine - is nobody else having this issue? It only happens when I import an image as a texture (eg the side of a building) and then "position" the texture using NON-fixed pins to correct perspective distortion.
                          Dave R @grizzler
                          What graphics card are you using? What OS?
                          • grizzlerG
                            grizzler @Dave R
                            @Dave-R said in Make Unique Texture giving weird results:
                            Nvidia RTX4090
                            Studio Driver 576.02 (although I've tried Game drivers and older Studio drivers too)
                            Windows 11
                            • grizzlerG
                              grizzler
                              I've tried taking the original photos on different devices, both apple and android (HEIC has to be turned off for Apple pics to be useable, but they still deform)
                                Are you using the the Yellow pin to skew the image?
                                That's UVW mapping which is not the same as your regular UV mapping which is purely 2D.
                                If you skew an image in SketchUp you can introduce additional UV points so a plane with 4 verts could have 5 points when you view the UVs.
                                Hopefully this shows what I mean. I think if this type of mapping is where the issue may lie.
                                Either its the new engine thats flaky or the destination app does not support UVW mapping.
                                I could be wrong.....it has happened before....many many times.
                                • grizzlerG
                                  I don't use the coloured pins, I used the non "fixed pins". I think I understand how the UV mapping might get messed up when I first make the adjustments, but once the image is in place I simply "Make texture unique" and that used to resolve the issue.
