    Make Unique Texture giving weird results
    Scheduled Pinned Locked Moved Solved SketchUcation Community Forums
    19 Posts 3 Posters 2.0k Views 3 Watching
    • grizzlerG Offline
      grizzler
      Hello. For over a decade I've used the same workflow when I create garden designs. As I only show the house for a bit of context and shadows because it's not the primary focus, then I don't spend much time on the house model, I just create the shape and map site photos onto the faces (with a well calculated focal point this has saved me many hours over the years). When I import the texture images I then place the pins in the corners of the house image and drag to make sure everything lines up nicely - but render softwares don't like this (Enscape in particular) so I found that if I 'Make Unique Texture' after I've adjusted it then that has always resolved the problem until now. In 2024 I'm also seeing that Sketchup doesn't like making textures unique and I end up with some kind of contorted mess.
      Here's an example that I'm just starting on. I'm not doing anything different to what I've always done, but this feature is now unuseable and I'll have to manually create versions of every house from start to finish which I'm far too lazy to be doing πŸ˜†
      Before M.U.T
      After M.U.T
      • grizzlerG Offline
        grizzler
        Here's the fix for anyone with this issue:
        Window > Preferences > Graphics, and set the Graphics Engine to "Use Classic Graphics Engine"
        grizzlerG 1 Reply Last reply Reply Quote 0
          Rich O Brien Moderator @grizzler
          @grizzler Yeah, it looks like SketchUp 2024 is kicking out the UV transforms when you execute the Make Unique command. Causing the image generated to be of no use.
          Looks what happens if you set texture to projected, sample it and then paint a face....
          As a workaround, you can export the face with the transformed UVs as an image and then bring that image in.
          • grizzlerG Offline
            grizzler @Rich O Brien
            @Rich-O-Brien I'm hoping they'll fix this issue soon rather than me having to pay for Photoshop or similar to edit images first, the oath of least resistance is always my favourite 😁.
              @grizzler said in Make Unique Texture giving weird results:
              I'd recommend Affinity Photo before PS. But, you're right they need better QC at SketchUp to stop regressing things that having no reason to break.
              • grizzlerG Offline
                @Rich-O-Brien I used to use Photoshop Elements for years because I only do basic stuff, but now I'm trying to get to grips with GIMP which seems to offer everything I need for free, but it's offered in a more confusing way πŸ˜–
                • grizzlerG Offline
                  grizzler
                  • Rich O BrienR Rich O Brien marked this topic as a question on
                  • grizzlerG Offline
                    grizzler @grizzler
                    @grizzler I just updated to the latest version of SU 2024 this morning having ignored the previous incremental updates; this issue still persists. I really want to use the new graphics engine but I can't πŸ˜–
                      Dave R @grizzler
                      What graphics card are you using?
                      • grizzlerG Offline
                        grizzler @Dave R
                        @Dave-R RTX 4090, so that should cope with anything.
                        Rich O BrienR Dave RD 2 Replies Last reply Reply Quote 0
                          @grizzler That's a beast of a card
                          • grizzlerG Offline
                            @Rich-O-Brien said in Make Unique Texture giving weird results:
                            I needed to upgrade from my old 3060Ti (good card but lacks vram), so I deliberated for a week whether to get the 4080 or 4090 and in a moment of madness I just went for it 😁
                              Dave R @grizzler
                              @grizzler that graphics card will support the new graphics engine. I expect there's something else going on in your model.
                              • grizzlerG Offline
                                grizzler @Dave R
                                @Dave-R It happens on every single model though. If I use the pins to stretch an image to fit a flat surface in Sketchup where it looks fine, I then look at it in a render software (I've had this in 3 renderers so far) and it's a mess, so I found that by making the material unique it resolved the issue in all softwares - that is until I use the new graphics engine.
                                • grizzlerG Offline
                                  grizzler
                                  I'm re-igniting this thread because even though I've upgraded my PC, moved onto SU2025 and switched from Enscape to D5, this problem of contorted textures from images imported into Sketchup still persists with the new graphics engine only. I've upgraded all that other stuff I mentioned but I'm having to use the old graphics engine - is nobody else having this issue? It only happens when I import an image as a texture (eg the side of a building) and then "position" the texture using NON-fixed pins to correct perspective distortion.
                                    Dave R @grizzler
                                    What graphics card are you using? What OS?
                                    • grizzlerG Offline
                                      grizzler @Dave R
                                      @Dave-R said in Make Unique Texture giving weird results:
                                      Nvidia RTX4090
                                      Studio Driver 576.02 (although I've tried Game drivers and older Studio drivers too)
                                      Windows 11
                                      • grizzlerG Offline
                                        grizzler
                                        I've tried taking the original photos on different devices, both apple and android (HEIC has to be turned off for Apple pics to be useable, but they still deform)
                                          Are you using the the Yellow pin to skew the image?
                                          That's UVW mapping which is not the same as your regular UV mapping which is purely 2D.
                                          If you skew an image in SketchUp you can introduce additional UV points so a plane with 4 verts could have 5 points when you view the UVs.
                                          Hopefully this shows what I mean. I think if this type of mapping is where the issue may lie.
                                          Either its the new engine thats flaky or the destination app does not support UVW mapping.
                                          I could be wrong.....it has happened before....many many times.
                                          • grizzlerG Offline
                                            I don't use the coloured pins, I used the non "fixed pins". I think I understand how the UV mapping might get messed up when I first make the adjustments, but once the image is in place I simply "Make texture unique" and that used to resolve the issue.
