    Julia Eneroth's Viewport Resizer / SketchUp 2023
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    20 Posts 6 Posters 2.4k Views 6 Watching
    • HornOxxH Offline
      HornOxx @Rich O Brien
      πŸ‘ many thanks Rich for all the input and also to you πŸ‘ Tig! for your encouragement!
      I have installed everything, learnt that I need the older HotKey version 1 instead of 2, finally installed an editor with line display because of "...It is lines 24 to 27 that..." πŸ˜‰ and of course I immediately realised what potential lies in this systematic approach - wonderful!
      (I originally hoped that this topic could still be dealt with via ruby - I can't do that either (LOL) but it still reads somehow more logically in my opinion)
      And Rich, your script runs wonderfully, but of course doesn't lead to the desired result on the basis of my SkUp setup - but never mind, still great!πŸ‘
      Now I have to get to grips with the script parameters and variables which take into account my typical SkUp setup whichcan be guessed by the screenshot below...
      never trust a skinny cook
      • F Offline
        faust07
        If that helps: a plugin for easily exporting SketchUp images, as shown in the viewport but with free input of height, width, format and compression.
        Originally modified for a smooth scene animation to coincide with the Skindigo AnimationExport (Indigo Render Animation).
        Here reduced to a SketchUp single image output with input of image parameters.
        Transfer the code to an rb file called Single_Image_Export.rb and copy it to the plugin folder of the respective SUp version (tested up to SUp2022).
        Restart SketchUp ....
        # Formerly Created by Dale Martens AKA 'Whaat' as "Smoothstep Animation"
        # Released 6 Oct 2008 As-is and without warranty of any kind.
        # Originally modified by faust07 for a smooth scene animation to coincide with the Skindigo AnimationExport (Indigo Render Animation).
        # Here reduced to a SketchUp single image export with input of image parameters.
        # Modified by faust07 (AT) 2024-03-25
        require 'sketchup.rb'
        if( not file_loaded?("Single_Image_Export.rb") )
        	menu=UI.menu("Plugins")
        	menu.add_separator
        	menu.add_item("Export Single Image") {(SingleImageExport.new(true))}
        file_loaded("Single_Image_Export.rb")
        class SingleImageExport
        def initialize(export)   # export should be true or false
        if export			# Inputs
        	prompts = ["Width","Height","Format","Compression"]
        	values = ["1920","1080","JPG","1.0"]
        	format_choices = "JPG|PNG"
        	enums = [nil,nil,format_choices,nil]
        	results = UI.inputbox(prompts,values,enums,"Export Options")
        	if results
        		@width = results[0].to_i
        		@height = results[1].to_i
        		@format = results[2]
        		@comp = results[3].to_f
        		if @comp < 0.1 or @comp > 1.0
        			UI.messagebox("Compression must be between 0.1 and 1.0")
        			@export = false
        			return
        		def_filename = "SU."+@format.downcase
        		path = UI.savepanel "Export Frame","",def_filename
        		if path
        			@export_path = File.dirname(path)
        			@filename = File.basename(path,".*")   # remove the file extension
        # single image export
        @image_path = File.join(@export_path,@filename + ".#{@format.downcase}")
        Sketchup.set_status_text("Exporting Frame to #{@image_path}")
        Sketchup.active_model.active_view.write_image(@image_path, @width, @height, true, @comp)
        end 	# end def initialize(export)
        end # class
          Rich O Brien Moderator @HornOxx
          @HornOxx said in Julia Eneroth's Viewport Resizer / SketchUp 2023:
          You can just press CTRL+F10 to set it to 'My Square' and then use File > Export >2D Graphic. In the option box if you click Use View Size you will see what the image dimension is for you.
          Then adjust line 24 values accordingly to get you to 600px. Not the most elegant approach.
          I think the better approach would be to ask Fredo if his Screenshot tool in Fredo Portrait could be extended to handle this. It already has ratio based selecting.
          HornOxxH 1 Reply Last reply Reply Quote 1
          • HornOxxH Offline
            ...Rich, I will definitely try your approach (first) to get a better understanding of what is going on between your script and the result "in front" since all that is pretty new to me and then continue by trying to tweak the script here and there to find out which are the right "lines" and values which are necessary - what an exciting thing and refreshing to learn always on top of that.
            1000 times thanks for guiding me this far. And if Tig contributes from his almost inexhaustible fundus of knowledge, this is always and everywhere welcome in any case!!!!! ❀️
            @Faust07
            Hi and as always I am very happy to hear from You and when I look around in this fantastic group of people here I ask myself "where on earth did I go to school and was it worth it all these years" 😁 πŸ™„ πŸ˜€
            Yor Script worked out of the Box and and delivered the result I need for my/our workflow.
            I rendered a hiddenline (1920 x 1080) from SketchUp and did the same with the view synchronised Enscape, also in 1920 x 1080. Both graphic components fit together exactly. This means that I can also use the functional renderings from Enscape, such as Material-ID or Depth-mask etc. without any time-consuming fiddling in Photoshop and it also means that every other machine in my team reproduces exactly the same "picture"-result.
            So, thank you too for dealing with my topic and for providing a working script on top of that! ❀️
            (πŸ˜‚ Which schools did you all attend?)
            • F Offline
              faust07
              I'm glad this helps.
              I find it a shame that the SkerchUp programmers have not yet considered it necessary to implement a precisely definable image export, even though the basic functions are available in Rubi.
              Regarding school: "Hochschule fΓΌr Architektur- und Bauwesen Weimar" today "Bauhaus UniversitΓ€t" - we punched out punched cards and handed them over to the computer center (short time after Konrad Zuse...) πŸ˜‰
              I learned most of Rubi from AntonS for scripting in MSPhysics and from customizing simple plugins for my own purposes. It's enough for small things...
              • HornOxxH Offline
                HornOxx @faust07
                TH Darmstadt / Architektur, and a completely digital-free education back then (not even Zuse) πŸ˜‰ This (CAD) topic then came over me very intensively in my first year of work, but thankfully in a company that provided very good training...
                Yes, I agree with you that this issue discussed here has been a flaw since the beginning and yes, it also annoys me that Sketchup never fixed this flaw.
                Again to your script and for information for everyone participating here - in the meantime I played through at least 10 scenarios (a: because this topic is so important to me and b: because I have to simulate the output of my many colleagues and our cross-workplace collaboration) and in all these scenarios your script consistently delivered the same and good output results! Prima! I even included the downstream render output in this test, with excellent results as well.
                Again, Thanks! to All!!
                I'm definitely going to deal with the scripting topic - because that's the only key to solving problems like this!
                • HornOxxH Offline
                  HornOxx @HornOxx
                  Hi all - apparently there is a solution to my (for you surely annoying) viewport export dilemma, and that is by using Sketchup's own onboard tools:
                  Instead of using the classic 2D export you can use the animation export instead. There you do not export a video file but individual frames, for example as png or jpg with the setting 1 frame per second.
                  There you can set a viewport-independent export resolution. I have tested this under all possible settings and various viewport modifications, I always get identical export image results, and these even fit together with a downstream renderer (e.g. Enscape) provided the renderer is set to Sketup's viewport synchronisation.
                  I wouldn't have come up with this obvious solution if Eric M Sargeant hadn't posted his video Batch Exporting Scenes and Styles
                  So thanks to Eric M Sergeant and all of you here πŸ˜‰
                  • F Offline
                    Firdaus_KL Newcomers @Rich O Brien
                    @Rich-O-Brien Hi sir. Really appreciate your help. Can I know how to get window stats to create more preset? I see in the script it state "+F8" and when I press those keys, nothing happen. Sorry Im a bit noob in this script-things.
                      Rich O Brien Moderator @Firdaus_KL
                      @Firdaus_KL said in Julia Eneroth's Viewport Resizer / SketchUp 2023:
                      Windows Stats is to report the current dimensions of the active window. Pressing CTRL+SHIFT+F8 will open a dialog with the dimensions of the window.
                      To create a new preset you would need to add a line with your preferred dimensions after line 27
                      ^F6::ResizeWin(1301,524) ; Ctrl+F6
                      • F Offline
                        FlorinAp
                        MC Vie Size still works, tested and use it every day in SU23 and 24, the catch is it has a difference in pixels (which is constant) that you have to remember, for example in SU23 you have to type minus 2 pixels for horizontal and minus 32 pixels for vertical, and after that you will see the correct and intended dimensions of viewport in the measurements field.
                        Eneroth is the same, but I don't remember why, I concluded that MC View Size is better...
                        • F Offline
                          FlorinAp
                          Anyway, the best export tool I've found so far is S4U export Scene with complete control over everything - resolution, select the scenes as you please, auto transfer the names of the scenes...
                            @FlorinAp
                            I love this
                            https://sketchucation.com/pluginstore?pln=ViewportBuster
