    I’ve Been “Boxed”
    54 Posts 7 Posters 4.5k Views 6 Watching
    • tuna1957T Offline
      tuna1957
      More fun time stuff. Only three components. Drew the path for the upper twists directly on the globe. Fredo’s Tools on Surface makes short work of it. The most time was spent on the render side. Played in Twilight’s Deep Material Editor to get the effect on the globe. 😎
      ntxdaveN 1 Reply Last reply Reply Quote 1
      • ntxdaveN Offline
        ntxdave @tuna1957
        @tuna1957 said in I’ve Been “Boxed”:
        I need to understand how you drew the path.
        Press F1...thank me later
        tuna1957T 1 Reply Last reply Reply Quote 0
        • tuna1957T Offline
          tuna1957 @ntxdave
          @ntxdave “Tools on Surface” allows you to draw on curved surfaces. Turned on hidden geometry which helps to keep things aligned. You just have to play and experiment to get used to how it works. The upper twists are 24 copies of one component.
          • ntxdaveN Offline
            ntxdave @tuna1957
            OK, I just installed Tools on Surface but I am having problems trying to figure out how to draw things like you did. Any advice as to any tutorials or places to learn how to use the tool?
            • tuna1957T Offline
              tuna1957 @ntxdave
              @ntxdave check here
              https://community.sketchucation.com/topic/105258/plugin-tools-on-surface-v2-6a-01-apr-24
              • ntxdaveN Offline
                ntxdave @tuna1957
                @tuna1957 Well, I am beginning to learn but I have a LONG way to go. 😁
                • tuna1957T Offline
                  tuna1957
                  More late night twisty things. 😎
                  1 Reply Last reply Reply Quote 5
                    You have been very boxed, nice work mate
                      It's muddy brilliant...
                      • tuna1957T Offline
                        tuna1957
                        Thanks gentlemen.
                        • Bryan KB Offline
                          Excellent work!
                          • 3 / 3
