    I’ve Been “Boxed”
    54 Posts 7 Posters 6.4k Views 6 Watching
    • tuna1957T
      tuna1957 @ntxdave
      @ntxdave I use SU Pro15 and 18. The finished image was rendered in Twilight. The glass has a “Flint Glass” template applied in Twilight. To my understanding even with the added PBR materials in SU25 if you want true realism your going to have to use a render software.
        Very bloudy sharp, Sir. Inspirational.
        tuna1957T 1 Reply Last reply
        • tuna1957T
          tuna1957 @Mike Amos
          @Mike-Amos Thank you Mr. Mike
          • ntxdaveN
            ntxdave @tuna1957
            @tuna1957 OK, I just messed around with the FredoScale tool and some additional messing around with things in 2025 and here is my latest trial.
            So, I think to your suggestion of the FredoScale tool and messing around I have made some more progress. 😀
            Press F1...thank me later
            • L
              I love where you are heading with this, very cool stuff, you have been very boxed indeed👍
              • tuna1957T
                tuna1957 @L i am
                @L-i-am Thank you sir. ✌️
                • tuna1957T
                  tuna1957
                  More fun time stuff. Only three components. Drew the path for the upper twists directly on the globe. Fredo’s Tools on Surface makes short work of it. The most time was spent on the render side. Played in Twilight’s Deep Material Editor to get the effect on the globe. 😎
                  ntxdaveN 1 Reply Last reply
                  • ntxdaveN
                    ntxdave @tuna1957
                    @tuna1957 said in I’ve Been “Boxed”:
                    I need to understand how you drew the path.
                    • tuna1957T
                      tuna1957 @ntxdave
                      @ntxdave “Tools on Surface” allows you to draw on curved surfaces. Turned on hidden geometry which helps to keep things aligned. You just have to play and experiment to get used to how it works. The upper twists are 24 copies of one component.
                      • ntxdaveN
                        ntxdave @tuna1957
                        OK, I just installed Tools on Surface but I am having problems trying to figure out how to draw things like you did. Any advice as to any tutorials or places to learn how to use the tool?
                        • tuna1957T
                          tuna1957 @ntxdave
                          @ntxdave check here
                          https://community.sketchucation.com/topic/105258/plugin-tools-on-surface-v2-6a-01-apr-24
                          • ntxdaveN
                            ntxdave @tuna1957
                            @tuna1957 Well, I am beginning to learn but I have a LONG way to go. 😁
                            • tuna1957T
                              tuna1957
                              More late night twisty things. 😎
                              Reply Quote 5
                              • L
                                You have been very boxed, nice work mate
                                  It's muddy brilliant...
                                  • tuna1957T
                                    tuna1957
                                    Thanks gentlemen.
                                    • Bryan KB
                                      Excellent work!
                                      • 3 / 3
