    Post diagnosis.
    72 Posts 5 Posters 7.3k Views 5 Watching
    • Mike AmosM Online
      Mike Amos @Mike Amos
      I have added a directional (Rayscaper) light and set to sunlight which IIRC is 6800k. Aimed into the centre of the view.
      • Mike AmosM Online
        Trying a Hotrod which I have rendered before in Twilight V2. Initially opening Rayscaper led to failed renders. Just va simple report, 'Failed'.
        Being a Hotrod, there will be flames. The PNG is on a seperate 'face copied from the model and painted as a component. Twilight see's the transparency fine but Rayscaper does not, when it does render.
          Spicy. Interesting that Rayscaper fails. Is this model very heavy in terms of file size?
          • Mike AmosM Online
            Mike Amos @Rich O Brien
            @Rich-O-Brien
            Not that big, nor the texture.
              @Mike-Amos do you mind sending me the model?
              • Mike AmosM Online
                Mike Amos @pixelcruncher
                @pixelcruncher
                I have sent an email with a link.
                • Mike AmosM Online
                  Movement?
                  Twilight.
                  Rayscaper.
                  Mike AmosM P 2 Replies Last reply Reply Quote 0
                  • Mike AmosM Online
                      pixelcruncher Extension Creator @Mike Amos
                      @Mike-Amos said in Post diagnosis.:
                      Movement?
                      Twilight.
                      Rayscaper.
                      Something wonky, the 0/0 samples/px doesn't look good. It seems like it never started rendering. What happens if you switch to CPU rendering as a test?
                      • Menu > File > Settings...
                      • Tick off the "Use GPU Rendering"
                      • Mike AmosM Online
                        I have already ticked 'use gpu rendering' a while ago when the system was changed.
                          Hey Mike,
                          I just wanted to check if the model renders correctly with the CPU and try to isolate the problem to GPU rendering.
                          It does render for me using GPU rendering; the model is surprisingly polygon-heavy. I do see the same problem with the flames texture and the alpha channel:
                          I guess you are using the same flames texture in Twilight Render. I'm surprised it gives such a nice result because this flame texture doesn't have a clean alpha channel. There's a pattern in the alpha channel:
                          Does Twilight Render have a way to display thumbnails for textures? I'm intrigued at how it can render this so cleanly.
                          Cheers,
                          Thomas
                          • Mike AmosM Online
                            @pixelcruncher
                            I spotted the alpha chanel stuff earlier when attemping to use that =texture for the log fire in the cold view scene. Weird.
                            Transparency png are flaky tbh and I am looking to 'try' with 3d flames, I shall need a lot of paracetamol for that though.
                            No idea if Twilight has any fanciness in this respect, Fletch and Chris are now gone so, relying on my daffy memory which is seive quality.
                            I have notice that having a backgrounbd which has some commonality to the transparency helps. The red/scarlet works best here.
                            I have attempted to recreate a scene with cutaway and limiting nayural light to that provided by the geometry, windows etc. Many splats with no report just the windows desktop.
                            I shall leave this here, needs a lot of adjustemnt lighting levels wise but gives a reasonable render potential.
                            The semi opaque walls, not so sure about.
                            • Mike AmosM Online
                              Adjustment.
                              • Mike AmosM Online
                                OK, finally got the onboard graphics online, adopted the classic engine in Sketchup and rebooted. Produced an immediate error in windows which I hope is a transient.
                                I think there is an improvement in this image, same view and same render time but 'feels' better. Opinions?
                                  When you mention onboard are you referring to integrated graphics in a CPU like Intel UHD? Or is this onboard the GPU?
                                  I'd be concerned by the 'immediate error' as that suggest conflict.
                                  • Mike AmosM Online
                                    @Rich-O-Brien
                                    Sorry, I do not think the graphics are the issue.
                                    Something about megascans when I restarted Sketchup after making the changes in BIOS.
                                    I am seeing a thirty second or more delay when selecting, painting a surface or importing an object which is something I have been seeing anyway. SKetchcup can take a minute or more to load to the welcom screen and then open a model even one saved to the OS drive.
                                    Having said that, I sometimes get a onedrive saving error "Cannot save, this file is already in use by another user", this turns out to be a one drive folder in my microsnot account. These two renders were consecutive and I have no clue. The bonus is that in true architect fashion, the second render does bring the garden "Indoors"......
                                    • Mike AmosM Online
                                      BTW, onedrive was deleted after being deactivated.
                                      • Mike AmosM Online
                                        Well, that vanishing trick with walls/floors has not repeated.
                                        Close to the intent with this.
                                        • Mike AmosM Online
                                          Exterior view.
                                          • tuna1957T Offline
                                            tuna1957
                                            Interesting design. Keep after it. πŸ‘
                                            • 3 / 4
