    2.2k Posts 482 Posters 856.6k Views 487 Watching
    • TIGT Online
      TIG Moderator @Prorab
      @Prorab
      It says you already have three seats allocated to computers using those licenses., so there are none free
      If you have changed the name of a computer, then that counts twice etc.
      You can log in and manage your licenses using
      https://sketchucation.com/webshop/my-licences.php
      Remove what's not needed and then validate again...
      Also ensure you have the latest versions of the extensions, LibFredo6 and the SketchUcation toolset [for licensing] installed and SketchUp restarted to sync everything...
        tibor310599
        Hi, can I please get some help with releasing licences on Curviloft from other devices? I have reached the limit of seats and I want to release all of them but can't seem to do so through the my licenses page on sketchucation. Thanks πŸ™‚
          Rich O Brien Moderator @tibor310599
          @tibor310599 Update Sketchucation Tools and libfredo on all devices to enable online releasing at https://sketchucation.com/webshop/my-licences.php
          T 1 Reply Last reply Reply Quote 0
            tibor310599 @Rich O Brien
            @Rich-O-Brien Hey, thanks for the reply. Although I tried this, it still doesn't let me release licences on curviloft. Other plugins are fine, just this one. Is there no way to ask for a global release on all licences so I can organize my licences again? thanks πŸ™‚
              @tibor310599 Just email us at support@sketchucation.com and we'll take a closer look
                Salvaier Newcomers
                Where do I go to purchase the Curvizard license?
                TIGT 1 Reply Last reply Reply Quote 0
                • TIGT Online
                  TIG Moderator @Salvaier
                  @Salvaier
                  After it's installed it creates a Tools submenu item.
                  In the dialog there's a Fredo6 Collection item and under its Curvizard there's 'license'...
                  In the dialog that opens there's a Purchase License button...
                    manova
                    Hi I purchased the licensed but after a month it already expires can you help
                    • TIGT Online
                      This suggests that your extension's free trial period has expired.
                      At the moment the extension is not licensed.
                      You must download the license file onto your computer, then apply that license [validate] to the related extension.
                      You need the latest version of the extension, LibFredo6 and the SketchUcation toolset installed and SketchUp restarted to sync everything...
                      There are lots of help posts and so on in the forum...
                        kessg Newcomers
                        I want to fix the curvuloft license error that occurred after purchasing the plugin.
                        • SCFLicenseSignature - Do not modify or delete
                        • SCFLicenseLog
                          After deleting the SCF license, it still does not run with error B03.
                          The extension store is also up to date. Please tell me how to fix it.
                          @kessg
                          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                            juu118 Newcomers
                            μ—λŸ¬κ°€ λ– μ„œ μ‚¬μš©ν•  수 μ—†μ–΄μš”
                            μ–΄λ–»κ²Œ ν•΄μ•Όν•˜λ‚˜μš”?
                              anggasaputrae
                              hello , how can i get fredo ?
                                You can mention him in a reply using...
                                @fredo6
                                Or comment in one of his threads that's related to your query
                                  PRONAY24 Newcomers
                                  how to get free trial in curviloft?
                                  • TIGT Online
                                    TIG Moderator @PRONAY24
                                    @PRONAY24
                                    Download/install the extension.
                                    After a while it needs licensing...
                                    Also remember that it needs LibFredo6, SketchUcation toolset etc to work...
                                      Mol93
                                      I've been using the plugin for while now. recently I have changed the PC name.
                                      After I changed the PC name, all of Sketchucation paid Plugins stopped working.
                                      Can you please assist.
                                      Thanks,
                                        Please follow the instruction in the alert.
                                        Click Yes and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                        Restart SketchUp
                                        M 1 Reply Last reply Reply Quote 0
                                          Mol93 @Rich O Brien
                                          @Rich-O-Brien Thank you,
                                          But now i get a warning of exceeding license seats.
                                          Is there a way to remove/reset all seats from my license ?
                                            Make sure your devices are running Sketchucation Tools 4.4.1: https://sketchucation.com/plugin/696-sketchucationtools
                                            This enables online releasing at https://sketchucation.com/webshop/my-licences.php
                                            • 109
                                            • 110
                                            • 1 / 110
