    2.3k Posts 515 Posters 2.5m Views 520 Watching
    • P
      Prorab @Rich O Brien
      @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
      @Prorab
      You need to whitelist *.sketchucation.com on your firewall/antivirus/network
      Or switch to a less strict network. The issue is client side.
      Thanks. I don't speak English well. I am will bee try
        TIG Moderator @Prorab
        @Prorab
        It says you already have three seats allocated to computers using those licenses., so there are none free
        If you have changed the name of a computer, then that counts twice etc.
        You can log in and manage your licenses using
        https://sketchucation.com/webshop/my-licences.php
        Remove what's not needed and then validate again...
        Also ensure you have the latest versions of the extensions, LibFredo6 and the SketchUcation toolset [for licensing] installed and SketchUp restarted to sync everything...
        • T
          tibor310599
          Hi, can I please get some help with releasing licences on Curviloft from other devices? I have reached the limit of seats and I want to release all of them but can't seem to do so through the my licenses page on sketchucation. Thanks πŸ™‚
            Rich O Brien Moderator @tibor310599
            @tibor310599 Update Sketchucation Tools and libfredo on all devices to enable online releasing at https://sketchucation.com/webshop/my-licences.php
            T 1 Reply Last reply
            • T
              tibor310599 @Rich O Brien
              @Rich-O-Brien Hey, thanks for the reply. Although I tried this, it still doesn't let me release licences on curviloft. Other plugins are fine, just this one. Is there no way to ask for a global release on all licences so I can organize my licences again? thanks πŸ™‚
                @tibor310599 Just email us at support@sketchucation.com and we'll take a closer look
                  Salvaier Newcomers
                  Where do I go to purchase the Curvizard license?
                  TIGT 1 Reply Last reply
                    TIG Moderator @Salvaier
                    @Salvaier
                    After it's installed it creates a Tools submenu item.
                    In the dialog there's a Fredo6 Collection item and under its Curvizard there's 'license'...
                    In the dialog that opens there's a Purchase License button...
                      manova
                      Hi I purchased the licensed but after a month it already expires can you help
                        This suggests that your extension's free trial period has expired.
                        At the moment the extension is not licensed.
                        You must download the license file onto your computer, then apply that license [validate] to the related extension.
                        You need the latest version of the extension, LibFredo6 and the SketchUcation toolset installed and SketchUp restarted to sync everything...
                        There are lots of help posts and so on in the forum...
                        • K
                          kessg Newcomers
                          I want to fix the curvuloft license error that occurred after purchasing the plugin.
                          • SCFLicenseSignature - Do not modify or delete
                          • SCFLicenseLog
                            After deleting the SCF license, it still does not run with error B03.
                            The extension store is also up to date. Please tell me how to fix it.
                            @kessg
                            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                              juu118 Newcomers
                              μ—λŸ¬κ°€ λ– μ„œ μ‚¬μš©ν•  수 μ—†μ–΄μš”
                              μ–΄λ–»κ²Œ ν•΄μ•Όν•˜λ‚˜μš”?
                                anggasaputrae
                                hello , how can i get fredo ?
                                  You can mention him in a reply using...
                                  @fredo6
                                  Or comment in one of his threads that's related to your query
                                  • P
                                    PRONAY24 Newcomers
                                    how to get free trial in curviloft?
                                      TIG Moderator @PRONAY24
                                      @PRONAY24
                                      Download/install the extension.
                                      After a while it needs licensing...
                                      Also remember that it needs LibFredo6, SketchUcation toolset etc to work...
                                        Mol93
                                        I've been using the plugin for while now. recently I have changed the PC name.
                                        After I changed the PC name, all of Sketchucation paid Plugins stopped working.
                                        Can you please assist.
                                        Thanks,
                                          Please follow the instruction in the alert.
                                          Click Yes and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                          Restart SketchUp
                                          M 1 Reply Last reply
                                            Mol93 @Rich O Brien
                                            @Rich-O-Brien Thank you,
                                            But now i get a warning of exceeding license seats.
                                            Is there a way to remove/reset all seats from my license ?
                                            • 97
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 115
                                            • 116
                                            • 99 / 116
