    2.3k Posts 515 Posters 2.3m Views 520 Watching
      tibor310599 @Rich O Brien
      @Rich-O-Brien Hey, thanks for the reply. Although I tried this, it still doesn't let me release licences on curviloft. Other plugins are fine, just this one. Is there no way to ask for a global release on all licences so I can organize my licences again? thanks πŸ™‚
        Rich O Brien Moderator @tibor310599
        @tibor310599 Just email us at support@sketchucation.com and we'll take a closer look
          Salvaier Newcomers
          Where do I go to purchase the Curvizard license?
          TIGT 1 Reply Last reply Reply Quote 0
            TIG Moderator @Salvaier
            @Salvaier
            After it's installed it creates a Tools submenu item.
            In the dialog there's a Fredo6 Collection item and under its Curvizard there's 'license'...
            In the dialog that opens there's a Purchase License button...
              manova
              Hi I purchased the licensed but after a month it already expires can you help
                This suggests that your extension's free trial period has expired.
                At the moment the extension is not licensed.
                You must download the license file onto your computer, then apply that license [validate] to the related extension.
                You need the latest version of the extension, LibFredo6 and the SketchUcation toolset installed and SketchUp restarted to sync everything...
                There are lots of help posts and so on in the forum...
                  kessg Newcomers
                  I want to fix the curvuloft license error that occurred after purchasing the plugin.
                  • SCFLicenseSignature - Do not modify or delete
                  • SCFLicenseLog
                    After deleting the SCF license, it still does not run with error B03.
                    The extension store is also up to date. Please tell me how to fix it.
                    @kessg
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                      juu118 Newcomers
                      μ—λŸ¬κ°€ λ– μ„œ μ‚¬μš©ν•  수 μ—†μ–΄μš”
                      μ–΄λ–»κ²Œ ν•΄μ•Όν•˜λ‚˜μš”?
                        anggasaputrae
                        hello , how can i get fredo ?
                          You can mention him in a reply using...
                          @fredo6
                          Or comment in one of his threads that's related to your query
                            PRONAY24 Newcomers
                            how to get free trial in curviloft?
                              TIG Moderator @PRONAY24
                              @PRONAY24
                              Download/install the extension.
                              After a while it needs licensing...
                              Also remember that it needs LibFredo6, SketchUcation toolset etc to work...
                                Mol93
                                I've been using the plugin for while now. recently I have changed the PC name.
                                After I changed the PC name, all of Sketchucation paid Plugins stopped working.
                                Can you please assist.
                                Thanks,
                                  Please follow the instruction in the alert.
                                  Click Yes and delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                  Restart SketchUp
                                  M 1 Reply Last reply Reply Quote 0
                                    Mol93 @Rich O Brien
                                    @Rich-O-Brien Thank you,
                                    But now i get a warning of exceeding license seats.
                                    Is there a way to remove/reset all seats from my license ?
                                      Make sure your devices are running Sketchucation Tools 4.4.1: https://sketchucation.com/plugin/696-sketchucationtools
                                      This enables online releasing at https://sketchucation.com/webshop/my-licences.php
                                        Mol93 @Rich O Brien
                                        @Rich-O-Brien
                                        Great!! Thanks alot
                                          svorleak Newcomers
                                            TIG Moderator @svorleak
                                            @svorleak
                                            So its trial period is ending, and to use it after 8 Feb you need to buy/download/activate a license [currently $30?]
                                            There's lots of help in posts and on SketchUcation about how to do this...
                                            There's even a "Help on Licensing..." button on the dialog you showed us.
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 102
                                            • 115
                                            • 116
                                            • 100 / 116
