    2.3k Posts 517 Posters 3.0m Views 522 Watching
      Duangkamol123 Newcomers
      Please advice how to install the lastest version
      • P
        Prorab @Nicolettepet
        Hello. I have 3 sets. But today is not working. tired
        Rich O BrienR TIGT 2 Replies Last reply
          Rich O Brien Moderator @Prorab
          @Prorab
          You need to whitelist *.sketchucation.com on your firewall/antivirus/network
          Or switch to a less strict network. The issue is client side.
          P 1 Reply Last reply
          • P
            Prorab @Rich O Brien
            @Rich-O-Brien said in SCFLicense: Extension Licensing on Sketchucation:
            @Prorab
            Thanks. I don't speak English well. I am will bee try
              TIG Moderator @Prorab
              @Prorab
              It says you already have three seats allocated to computers using those licenses., so there are none free
              If you have changed the name of a computer, then that counts twice etc.
              You can log in and manage your licenses using
              https://sketchucation.com/webshop/my-licences.php
              Remove what's not needed and then validate again...
              Also ensure you have the latest versions of the extensions, LibFredo6 and the SketchUcation toolset [for licensing] installed and SketchUp restarted to sync everything...
              • T
                tibor310599
                Hi, can I please get some help with releasing licences on Curviloft from other devices? I have reached the limit of seats and I want to release all of them but can't seem to do so through the my licenses page on sketchucation. Thanks 🙂
                  Rich O Brien Moderator @tibor310599
                  @tibor310599 Update Sketchucation Tools and libfredo on all devices to enable online releasing at https://sketchucation.com/webshop/my-licences.php
                  T 1 Reply Last reply
                  • T
                    tibor310599 @Rich O Brien
                    @Rich-O-Brien Hey, thanks for the reply. Although I tried this, it still doesn't let me release licences on curviloft. Other plugins are fine, just this one. Is there no way to ask for a global release on all licences so I can organize my licences again? thanks 🙂
                      @tibor310599 Just email us at support@sketchucation.com and we'll take a closer look
                        Salvaier Newcomers
                        Where do I go to purchase the Curvizard license?
                        TIGT 1 Reply Last reply
                          TIG Moderator @Salvaier
                          @Salvaier
                          After it's installed it creates a Tools submenu item.
                          In the dialog there's a Fredo6 Collection item and under its Curvizard there's 'license'...
                          In the dialog that opens there's a Purchase License button...
                            manova
                            Hi I purchased the licensed but after a month it already expires can you help
                              This suggests that your extension's free trial period has expired.
                              At the moment the extension is not licensed.
                              You must download the license file onto your computer, then apply that license [validate] to the related extension.
                              You need the latest version of the extension, LibFredo6 and the SketchUcation toolset installed and SketchUp restarted to sync everything...
                              There are lots of help posts and so on in the forum...
                              • K
                                kessg Newcomers
                                I want to fix the curvuloft license error that occurred after purchasing the plugin.
                                • SCFLicenseSignature - Do not modify or delete
                                • SCFLicenseLog
                                  After deleting the SCF license, it still does not run with error B03.
                                  The extension store is also up to date. Please tell me how to fix it.
                                  @kessg
                                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                    juu118 Newcomers
                                    에러가 떠서 사용할 수 없어요
                                    어떻게 해야하나요?
                                      anggasaputrae
                                      hello , how can i get fredo ?
                                        You can mention him in a reply using...
                                        @fredo6
                                        Or comment in one of his threads that's related to your query
                                        • P
                                          PRONAY24 Newcomers
                                          how to get free trial in curviloft?
                                            TIG Moderator @PRONAY24
                                            @PRONAY24
                                            Download/install the extension.
                                            After a while it needs licensing...
                                            Also remember that it needs LibFredo6, SketchUcation toolset etc to work...
                                            • 97
                                            • 98
                                            • 99
                                            • 100
                                            • 101
                                            • 115
                                            • 116
                                            • 99 / 116
