    2.3k Posts 507 Posters 1.3m Views 512 Watching
      TIG Moderator @chiklopes
      @chiklopes
      That error says you are trying to us a license file for another plugin [extension].
      This can occur if, for example, you have a license for RoundCorner and you try to use it for FredoCorner - these are two different extensions and need their own licenses...
      Please give more details if this isn't the case.
        celestinf @Rich O Brien
        @Rich-O-Brien
        Bonjour voici selon votre demande, par contre petite question que je me pose pour re-installer les plugins, j'avais initialement sauvegardé les fichiers de l'ancien disque dur sur une clef USB que j'ai ensuite recopier dans le nouveau DD dans les fichiers destinés. Peut être que cette méthode n'est pas bonne et que j'aurais dû re-installer l'ensemble depuis sketchupaction en repartant de façon traditionnelle?
        +0100
        • Platform: x64-mswin64_140 - Ruby: 2.7.1
        • Sketchup: 21.0.339
        • LibFredo6: v14.6a
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.3.0
        • SCFLicense: v6.0e - 72
        • Fredo6 Plugins
          Curviloft v2.0a
          FredoScale v3.5a
          FredoSpline v2.5a
          JointPushPull v4.8a
          RoundCorner v3.3a
          ToolsOnSurface v2.5a
          Signature File: 2022-06-22 14:16:52 +0200
          ClothWorks: 2024-03-23 12:13:34 +0100
          Curviloft: 2023-06-02 15:34:57 +0200
          FredoSpline: 2023-04-19 13:32:33 +0200
          JointPushPull: 2023-04-06 11:15:28 +0200
          RoundCorner: 2023-03-02 12:40:52 +0100
        Rich O BrienR C 2 Replies Last reply Reply Quote 1
        • Rich O BrienR Online
          Rich O Brien Moderator @celestinf
          @celestinf said in SCFLicense: Extension Licensing on Sketchucation:
          Please update Sketchucation Tools to v 4.4.1
          Launch using Extensions > Sketchucation > ExtensionStore or via toolbar icon
          Click Bell and update
          Restart SketchUp
          Activate License
            chiklopes
            okay thanks.
            it works now.
            But also, I guess one mistake was what @TIG said. I was mixing RoundCorner with FredoCorner...
            thanks again both
              mohamed888
              I have bought a licence how ever it doesent work i just get this message
              An error occoured in comunication with sketchucation.
              please help
                Rich O Brien Moderator @mohamed888
                @mohamed888 said in SCFLicense: Extension Licensing on Sketchucation:
                please help
                @Lprawita That is your network blocking access to our server. Please whitelist *.sketchucation.com or activate on a less strict network
                sketchucation (community.sketchucation.com)
                M 1 Reply Last reply Reply Quote 0
                  mohamed888 @Rich O Brien
                  @Rich-O-Brien
                  how can i do that
                    @mohamed888 Either in your firewall or your networks policy settings
                    Its a client side restriction you are facing that's impossible for us to circumvent. You need to find whether its software, hardware or policy related. Our server is up and activating licenses.
                      @Rich-O-Brien
                      thank you problem solve
                      i see the problem repeated a lot in the community here
                      i recommend this video https://youtu.be/UKfcCpoYH5I
                        celestinf @celestinf
                        @celestinf
                        Salut afin de dire ce que j'ai fais. J'ai totalement desinstallé sketchup et supprimé l'ensemble des fichiers dans le roaming.... Après ré-installation, j'ai tout téléchargé depuis votre site sans utiliser ou copier les fichiers que j'avais sauvegardé et cela refonctionne correctement merci du temps passé.
                        Bonne journée
                        Hi in order to say what I did. I totally uninstalled sketchup and deleted all the files in the roaming.... After re-installation, I downloaded everything from your site without using or copying the files I had saved and it works properly again thanks for the time spent. Have a nice day
                        • F Offline
                          frajo
                          Ich habe am 12.11.24 eine Lizenz für das 50 Dollar inkl FAT ca 60 Dollar Fredo Paket ausgewählt und per PayPal bezahlt. Der Bezahlvorgang lief ohne Probleme. Heute sehe ich, dass PayPal die Zahlung abgelehnt hat. Haben Sie eine Ahnung warum?
                          Andere Zahlungen am gleichen Tag auf deutsche Konten liefen ohne Probleme.
                          Grüße Franz
                          I selected a license for the 50 dollar incl. VAT approx. 60 dollar Fredo package on 12.11.24 and paid via PayPal. The payment process went without any problems. Today I see that PayPal declined the payment. Do you have any idea why? Other payments on the same day to German accounts went without any problems. Greetings Franz
                            Rich O Brien Moderator @frajo
                            @frajo Sometimes banks will initiate the charge but when it comes to authorising it doesn't complete for any number of reasons.
                            In some instances there some third party that sits between your account and PayPal. For instance we see in Poland there's a third party called P24 that Polish visitiors use for online payments. 9/10 these fail because they are authorised payment processors that we use.
                            So if you have some type third party banking solution that you use to purchase items I would use our Stripe payment processor. It is more bank friendly in some cases than PayPal.
                              Mike Backman
                              Thru paint does not show up in "my licenses"
                                Rich O Brien Moderator @Mike Backman
                                @Mike-Backman When did you purchase a license? Do you have multiple accounts?
                                • F Offline
                                  FERREIRA DOS SANTOS Newcomers
                                  Olá!
                                  Já adquiri a compra da licença e estou no aguardo da ativação da mesma.
                                    Rich O Brien Moderator @FERREIRA DOS SANTOS
                                    @FERREIRA-DOS-SANTOS said in SCFLicense: Extension Licensing on Sketchucation:
                                    Olá!
                                    Hello! I have already purchased the license purchase and am waiting for it to be activated.
                                    Licenses are at https://sketchucation.com/webshop/my-licences.php
                                      Prorab
                                      Hellow. I need help. "computer name mismatch it is advised to erase the Signature file and revalidate".Снимок экрана 2024-11-22 170645.png / Please. Help me
                                        Rich O Brien Moderator @Prorab
                                        @Prorab I would click Yes/OK to open the folder where the signature file is located.
                                        Close SketchUp
                                        Delete the signature file
                                        Open SketchUp
                                        Activate License
                                        If the error repeats please check your PC name...
                                        If your device name has special characters please change the device name to only use alphanumeric characters
                                        P 2 Replies Last reply Reply Quote 0
                                          Prorab @Rich O Brien
                                          @Rich-O-Brien Delete the signature file i dont know where is, Which path ? Thanks
                                            @Rich-O-Brien 25.png Its my fredo plugins. but missing only Fredo spline
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 100
                                            • 114
                                            • 115
                                            • 98 / 115
