    2.2k Posts 487 Posters 929.7k Views 492 Watching
      Darius
      Hello,
      Have 3 seats on an extension, vant use the 1st one, only two releasable ones. How can I use the first one ? aaa.png
        Rich O Brien Moderator @Darius
        @Darius Update Sketchucation Tools and Libfredo on that device to enable online releasing for that device.
        Or open SketchUp on that device and release a seat using the License dialog.
        D 1 Reply Last reply Reply Quote 0
          Darius @Rich O Brien
          @Rich-O-Brien Problem is that we have 3 working seats, but the none of it uses 1st license. Is there a way to release it manually ?
            @Darius said in SCFLicense: Extension Licensing on Sketchucation:
            Sorry, your message is unclear. You have working seats that use the license file is describing a proper use case.
            If you go to any of the devices you can release the seat from its License dialog. Since I don't know what extension you are talking about I can't give more details.
            If you want to email us at support@sketchucation.com we'll try help.
              celestinf
              Bonjour,
              Je me permets de vous écire car j'ai fais l'acquisition en 2023 de plusieurs licences que je vois bien dans mon espace License. J'ai du changer de disque dur et réinstaller l'ensemble des éléments de mon pc. Lorsque je lance par exemple le fredoscale depuis sketchup j'ai le message me disant d'acheter ou utiliser ma license. Je vais donc charger dans mon espace License la License que je valide ensuite par sketchup et j'obtient le message "erreur dans la validation de licence, requete à sketchupaction ERROR_A0B.
              Pouvez vous me donner la procédure afin que je puisse corriger cela?
              Merci à vous
                Rich O Brien Moderator @celestinf
                @celestinf said in SCFLicense: Extension Licensing on Sketchucation:
                Bonjour,
                Hello I take the liberty of writing to you because I acquired several licenses in 2023 that I can see in my License space. I had to change my hard drive and reinstall all the elements of my pc. When I launch the fredoscale from sketchup, for example, I get the message telling me to buy or use my license. So I'm going to load the License in my License space that I then validate by sketchup and I get the message "error in license validation, request to sketchupaction ERROR_A0B. Can you give me the procedure so that I can correct this? Thank you
                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                C 1 Reply Last reply Reply Quote 0
                  chiklopes
                  Hello,
                  I bought FredoBundle in 2022, permanent licenses, and it was working fine. But now I receive a message that is "Not Licensed". Try to validate it but without success. the folder with the licenses still there but somehow it doesn't recognise the files....
                  try to download my licenses again but still not recognize them.
                  I update all the Fredo plugins using ExtensionStore v4.2.9, but still not working
                  please, any help on that? thanks
                    Rich O Brien Moderator @chiklopes
                    @chiklopes said in SCFLicense: Extension Licensing on Sketchucation:
                    Please update Sketchucation Tools to 4.4.1 it has the latest licensing system
                    Sketchucation Tools | SketchUcation
                    (sketchucation.com)
                    You can upgrade Sketchucation Tools directly from within our ExtensionStore. Restart SketchUp after installation and re-license.
                      chiklopes @Rich O Brien
                      @Rich-O-Brien
                      I made what you said but still not work...
                      any other advise please?
                      thanks
                      TIGT 1 Reply Last reply Reply Quote 1
                        TIG Moderator @chiklopes
                        @chiklopes
                        That error says you are trying to us a license file for another plugin [extension].
                        This can occur if, for example, you have a license for RoundCorner and you try to use it for FredoCorner - these are two different extensions and need their own licenses...
                        Please give more details if this isn't the case.
                          celestinf @Rich O Brien
                          @Rich-O-Brien
                          Bonjour voici selon votre demande, par contre petite question que je me pose pour re-installer les plugins, j'avais initialement sauvegardé les fichiers de l'ancien disque dur sur une clef USB que j'ai ensuite recopier dans le nouveau DD dans les fichiers destinés. Peut être que cette méthode n'est pas bonne et que j'aurais dû re-installer l'ensemble depuis sketchupaction en repartant de façon traditionnelle?
                          +0100
                          • Platform: x64-mswin64_140 - Ruby: 2.7.1
                          • Sketchup: 21.0.339
                          • LibFredo6: v14.6a
                          • LibFredo6 Binary loaded
                          • Sketchucation ExtensionStore: 4.3.0
                          • SCFLicense: v6.0e - 72
                          • Fredo6 Plugins
                            Curviloft v2.0a
                            FredoScale v3.5a
                            FredoSpline v2.5a
                            JointPushPull v4.8a
                            RoundCorner v3.3a
                            ToolsOnSurface v2.5a
                            Signature File: 2022-06-22 14:16:52 +0200
                            ClothWorks: 2024-03-23 12:13:34 +0100
                            Curviloft: 2023-06-02 15:34:57 +0200
                            FredoSpline: 2023-04-19 13:32:33 +0200
                            JointPushPull: 2023-04-06 11:15:28 +0200
                            RoundCorner: 2023-03-02 12:40:52 +0100
                          Rich O BrienR C 2 Replies Last reply Reply Quote 1
                            Please update Sketchucation Tools to v 4.4.1
                            Launch using Extensions > Sketchucation > ExtensionStore or via toolbar icon
                            Click Bell and update
                            Restart SketchUp
                            Activate License
                              chiklopes
                              okay thanks.
                              it works now.
                              But also, I guess one mistake was what @TIG said. I was mixing RoundCorner with FredoCorner...
                              thanks again both
                                mohamed888
                                I have bought a licence how ever it doesent work i just get this message
                                An error occoured in comunication with sketchucation.
                                please help
                                  Rich O Brien Moderator @mohamed888
                                  @mohamed888 said in SCFLicense: Extension Licensing on Sketchucation:
                                  please help
                                  @Lprawita That is your network blocking access to our server. Please whitelist *.sketchucation.com or activate on a less strict network
                                  sketchucation (community.sketchucation.com)
                                  M 1 Reply Last reply Reply Quote 0
                                    mohamed888 @Rich O Brien
                                    @Rich-O-Brien
                                    how can i do that
                                      @mohamed888 Either in your firewall or your networks policy settings
                                      Its a client side restriction you are facing that's impossible for us to circumvent. You need to find whether its software, hardware or policy related. Our server is up and activating licenses.
                                        @Rich-O-Brien
                                        thank you problem solve
                                        i see the problem repeated a lot in the community here
                                        i recommend this video https://youtu.be/UKfcCpoYH5I
                                          celestinf @celestinf
                                          @celestinf
                                          Salut afin de dire ce que j'ai fais. J'ai totalement desinstallé sketchup et supprimé l'ensemble des fichiers dans le roaming.... Après ré-installation, j'ai tout téléchargé depuis votre site sans utiliser ou copier les fichiers que j'avais sauvegardé et cela refonctionne correctement merci du temps passé.
                                          Bonne journée
                                          Hi in order to say what I did. I totally uninstalled sketchup and deleted all the files in the roaming.... After re-installation, I downloaded everything from your site without using or copying the files I had saved and it works properly again thanks for the time spent. Have a nice day
                                          • F Offline
                                            frajo
                                            Ich habe am 12.11.24 eine Lizenz für das 50 Dollar inkl FAT ca 60 Dollar Fredo Paket ausgewählt und per PayPal bezahlt. Der Bezahlvorgang lief ohne Probleme. Heute sehe ich, dass PayPal die Zahlung abgelehnt hat. Haben Sie eine Ahnung warum?
                                            Andere Zahlungen am gleichen Tag auf deutsche Konten liefen ohne Probleme.
                                            Grüße Franz
                                            I selected a license for the 50 dollar incl. VAT approx. 60 dollar Fredo package on 12.11.24 and paid via PayPal. The payment process went without any problems. Today I see that PayPal declined the payment. Do you have any idea why? Other payments on the same day to German accounts went without any problems. Greetings Franz
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 109
                                            • 110
                                            • 25 / 110
