    2.3k Posts 517 Posters 3.0m Views 522 Watching
      Rich O Brien Moderator @dhcu321
      @dhcu321 Please update Libfredo to latest release
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
        Javier_ELARQ Newcomers
        Hola, como hago para obtener la licencia?
          Darius
          Hello,
          Have 3 seats on an extension, vant use the 1st one, only two releasable ones. How can I use the first one ? aaa.png
            Rich O Brien Moderator @Darius
            @Darius Update Sketchucation Tools and Libfredo on that device to enable online releasing for that device.
            Or open SketchUp on that device and release a seat using the License dialog.
            D 1 Reply Last reply
              Darius @Rich O Brien
              @Rich-O-Brien Problem is that we have 3 working seats, but the none of it uses 1st license. Is there a way to release it manually ?
                @Darius said in SCFLicense: Extension Licensing on Sketchucation:
                Sorry, your message is unclear. You have working seats that use the license file is describing a proper use case.
                If you go to any of the devices you can release the seat from its License dialog. Since I don't know what extension you are talking about I can't give more details.
                If you want to email us at support@sketchucation.com we'll try help.
                • C
                  celestinf
                  Bonjour,
                  Je me permets de vous écire car j'ai fais l'acquisition en 2023 de plusieurs licences que je vois bien dans mon espace License. J'ai du changer de disque dur et réinstaller l'ensemble des éléments de mon pc. Lorsque je lance par exemple le fredoscale depuis sketchup j'ai le message me disant d'acheter ou utiliser ma license. Je vais donc charger dans mon espace License la License que je valide ensuite par sketchup et j'obtient le message "erreur dans la validation de licence, requete à sketchupaction ERROR_A0B.
                  Pouvez vous me donner la procédure afin que je puisse corriger cela?
                  Merci à vous
                    Rich O Brien Moderator @celestinf
                    @celestinf said in SCFLicense: Extension Licensing on Sketchucation:
                    Bonjour,
                    Hello I take the liberty of writing to you because I acquired several licenses in 2023 that I can see in my License space. I had to change my hard drive and reinstall all the elements of my pc. When I launch the fredoscale from sketchup, for example, I get the message telling me to buy or use my license. So I'm going to load the License in my License space that I then validate by sketchup and I get the message "error in license validation, request to sketchupaction ERROR_A0B. Can you give me the procedure so that I can correct this? Thank you
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    C 1 Reply Last reply
                    • C
                      chiklopes
                      Hello,
                      I bought FredoBundle in 2022, permanent licenses, and it was working fine. But now I receive a message that is "Not Licensed". Try to validate it but without success. the folder with the licenses still there but somehow it doesn't recognise the files....
                      try to download my licenses again but still not recognize them.
                      I update all the Fredo plugins using ExtensionStore v4.2.9, but still not working
                      please, any help on that? thanks
                        Rich O Brien Moderator @chiklopes
                        @chiklopes said in SCFLicense: Extension Licensing on Sketchucation:
                        Please update Sketchucation Tools to 4.4.1 it has the latest licensing system
                        Sketchucation Tools | SketchUcation
                        (sketchucation.com)
                        You can upgrade Sketchucation Tools directly from within our ExtensionStore. Restart SketchUp after installation and re-license.
                        • C
                          chiklopes @Rich O Brien
                          @Rich-O-Brien
                          I made what you said but still not work...
                          any other advise please?
                          thanks
                          TIGT 1 Reply Last reply
                            TIG Moderator @chiklopes
                            @chiklopes
                            That error says you are trying to us a license file for another plugin [extension].
                            This can occur if, for example, you have a license for RoundCorner and you try to use it for FredoCorner - these are two different extensions and need their own licenses...
                            Please give more details if this isn't the case.
                            • C
                              celestinf @Rich O Brien
                              @Rich-O-Brien
                              Bonjour voici selon votre demande, par contre petite question que je me pose pour re-installer les plugins, j'avais initialement sauvegardé les fichiers de l'ancien disque dur sur une clef USB que j'ai ensuite recopier dans le nouveau DD dans les fichiers destinés. Peut être que cette méthode n'est pas bonne et que j'aurais dû re-installer l'ensemble depuis sketchupaction en repartant de façon traditionnelle?
                              +0100
                              • Platform: x64-mswin64_140 - Ruby: 2.7.1
                              • Sketchup: 21.0.339
                              • LibFredo6: v14.6a
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 4.3.0
                              • SCFLicense: v6.0e - 72
                              • Fredo6 Plugins
                                Curviloft v2.0a
                                FredoScale v3.5a
                                FredoSpline v2.5a
                                JointPushPull v4.8a
                                RoundCorner v3.3a
                                ToolsOnSurface v2.5a
                                Signature File: 2022-06-22 14:16:52 +0200
                                ClothWorks: 2024-03-23 12:13:34 +0100
                                Curviloft: 2023-06-02 15:34:57 +0200
                                FredoSpline: 2023-04-19 13:32:33 +0200
                                JointPushPull: 2023-04-06 11:15:28 +0200
                                RoundCorner: 2023-03-02 12:40:52 +0100
                              Rich O BrienR C 2 Replies Last reply
                                Please update Sketchucation Tools to v 4.4.1
                                Launch using Extensions > Sketchucation > ExtensionStore or via toolbar icon
                                Click Bell and update
                                Restart SketchUp
                                Activate License
                                • C
                                  chiklopes
                                  okay thanks.
                                  it works now.
                                  But also, I guess one mistake was what @TIG said. I was mixing RoundCorner with FredoCorner...
                                  thanks again both
                                    mohamed888
                                    I have bought a licence how ever it doesent work i just get this message
                                    An error occoured in comunication with sketchucation.
                                    please help
                                      Rich O Brien Moderator @mohamed888
                                      @mohamed888 said in SCFLicense: Extension Licensing on Sketchucation:
                                      please help
                                      @Lprawita That is your network blocking access to our server. Please whitelist *.sketchucation.com or activate on a less strict network
                                      sketchucation (community.sketchucation.com)
                                      M 1 Reply Last reply
                                        mohamed888 @Rich O Brien
                                        @Rich-O-Brien
                                        how can i do that
                                          @mohamed888 Either in your firewall or your networks policy settings
                                          Its a client side restriction you are facing that's impossible for us to circumvent. You need to find whether its software, hardware or policy related. Our server is up and activating licenses.
                                            @Rich-O-Brien
                                            thank you problem solve
                                            i see the problem repeated a lot in the community here
                                            i recommend this video https://youtu.be/UKfcCpoYH5I
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 100
                                            • 115
                                            • 116
                                            • 98 / 116
