    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 15.4k Views 7 Watching
      Mike Amos @Mike Amos
      @Mike-Amos
      Greyed out, nothing doing anywhere.
        @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
        As I explained in our chat room. Greyed out is not representative of 'not working'.
        Greyed out = Installed outside of SketchUp's ecosystem
        I think your issues are bigger than 3rd party extensions.
        If you run Windows own Disk Check what is the report?
        So right click your drive, choose Properties, Tools tab and click Check
          Mike Amos @Rich O Brien
          @Rich-O-Brien
          Weird, this suggests an error on the E drive which the other scanning programs report as healthy.
              A little stability at the moment. Not sorted yet but moving forwards.
                @Mike-Amos
                I think a less ;busy' tile texture will work better on this machine and there is no artificial lighting in that render.
                Native Sketchup lighting only.
                  I think the tile choice HAS mad a difference. Not a true comparison seeing as this render went to 1000 samples and used the GPU for rendering.
                  Still no artificial light but the lighter tile bounces rays more effectively.
                    An exterior view of this small home in a hdri.
                      pixelcruncher Extension Creator @Mike Amos
                      @Mike-Amos very nice, I like the concept.
                        Mike Amos @pixelcruncher
                        @pixelcruncher
                        Ta, simple enough which I do like myself. Flat packable too.
                          Finally got a render without windoze update screaming up the works.
                          Exposure set at 2.00 and environment to 1.00 so still playing aorund with the settings here.
                          • Bryan KB Offline
                            Perfect!
                              Mike Amos @Bryan K
                              @Bryan-K
                              Thanks, on the road at least.
                              A night exterior view, well more near to sundown anyway.
                                @Mike-Amos Nice result! Those lanterns could use some sphere lights for extra effect.
                                  @pixelcruncher
                                  Ta, agreed. As could the interior lights. Another D'uh moment in life's drawer full. I just forgot while setting up the scene which means I should think a bit more or render earlier in the evening.....
                                  Oh well, next time I hope I will remember.....
                                    Trying the fake emitter thing on the exterior lights but not much of a result. I placed sphere lights in the same location as the wall lights but limited success so far.
                                    This is how it looks after 70 passes, it will take a couple of hours for the full render. Exposure reduced from 2.00 to 1.00.
                                    Mike AmosM P 2 Replies Last reply Reply Quote 0
                                      @Mike-Amos
                                      My idea of a night/evening render. Courtesy of Affinity photo.
                                        @Mike-Amos
                                        You would want to place the sphere lights (point lights) in the middle of the lanterns. If you place them inside the bulb, then add some transparency to the light bulb.
                                        I attached an example (mike_lantern_example.skp) of how to configure sphere lights. In the scene below, I have three lights with the following configuration:
                                        • Light temperature 3000K to get a warm color.
                                        • 50W power for each light.
                                        • Radius of 0.10m to make the shadows softer.
                                        I dimmed the environment to low strength to make the lights stand out.
                                        Light configuration in SketchUp:
                                        Light settings in Rayscaper:
                                        Result:
                                        That should help you tune the lights in your scene.
                                        Regards,
                                        Thomas
                                          @pixelcruncher
                                          Thanks for that, how did you rename the lights tho'?
                                            Not a full 500 samples but getting there. I desaturated in Affinity photo.
                                            P 1 Reply Last reply Reply Quote 1
                                            • 8 / 9
