    TrueBend Axis Problem
    18 Posts 5 Posters 2.0k Views 5 Watching
    • ntxdaveN Offline
      ntxdave @Gus R
      @Gus-R & @TIG I appreciate your responses but I am not getting the results I want. If you look at the orientation of the objects on the left and right, that is the orientation of the shapes that I want for the arch. When the objects are placed in the arch, I want the "tall" part to be the way the objects are oriented. I do not seem to be able to rotate them correctly to achieve what I want. Think of it like the objects are bricks and I want the arch to show the long side of the bricks.
      Press F1...thank me later
      TIGT 1 Reply Last reply Reply Quote 0
      • TIGT Online
        TIG Moderator @ntxdave
        @ntxdave
        I think the simplest way would be to draw a grouped pair of circles centered on the opening, passing through corners of the verticals. Rotate the arcs so that they start at a segment's midpoint rather than a vertex. You'll probably need to scale the group so that the arcs touch the verticals again.
        Choose a segment count that approximates to the size of a brick 75mm/3" [or double that]
        Draw a horizontal divider and delete the lower parts of the circles.
        Now edit the group and draw in edges the match some of the mortar beds for the bricks in the arch.
        You don't need to draw them all, use Rotate>RadialArray and copy them around the arc.
        Draw in missing edges the make all faces form.
        Use PushPull to add thickness to the arch bricks, double-click to repeat on all brick faces to repeat the dim...
          Rich O Brien Moderator @TIG
          • Gus RG Offline
            Gus R @Rich O Brien
            @Rich-O-Brien You can do this with shape bender too although the "bricks" at the top widen out. Ignore the exaggerated proportions.
            The line used in Shape Bender had to be the same distance as the overall length of the arc + sides.
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
              Rich O Brien Moderator @Gus R
              @Gus-R Yeah, there 10 different ways of doing it. Both natively or via plugins.
              ntxdaveN 2 Replies Last reply Reply Quote 0
              • ntxdaveN Offline
                ntxdave @Rich O Brien
                @Rich-O-Brien Thanks Rich, Gus & TIG. I finally got my act together and was able to figure things out before seeing these last posts. Here is my result (but I like the stuff you guys did as well).
                I guess this "exercise" exemplifies my age and lack of use lately. πŸ˜‘
                Gus RG Rich O BrienR 2 Replies Last reply Reply Quote 1
                • Gus RG Offline
                  Gus R @ntxdave
                  @ntxdave You're welcome, Dave. I was trying to figure out how to do my brick arches in Blender that doesn't involve an hour on some procedural. There's a lot of really good videos on Youtube but nothing that gets it done fast and simple. Then while there's a lot of great Youtube tutorials on Blender a lot of them seem to talk 100 MPH and they have 20/15 vision.
                    Rich O Brien Moderator @ntxdave
                    @ntxdave said in TrueBend Axis Problem:
                    Horses for courses. Always a good idea to get ideas from others to see what comes out of the hat
                    • ntxdaveN Offline
                      @Rich-O-Brien Did you do your model with native tools or a plugin? Yes, I know it is a dumb question but I just had to ask. I have never seen the rotation tool used like that.
                      BoxB 1 Reply Last reply Reply Quote 0
                      • BoxB Offline
                        Box @ntxdave
                        @ntxdave
                        Rich used Radial Bending, part of Fredo's Fredoscale.
                        • ntxdaveN Offline
                          ntxdave @Box
                          @Box Thank you sir. πŸ‘ πŸ‘
                          I have not used that tool so I will do some playing around.
                          • ntxdaveN Offline
                            ntxdave @ntxdave
                            I am feeling really stupid. 😊
                            I have watched @Box’s video several times and have also watched a couple of tutorials but I seem to have real problems trying to use the tool. Can someone give me a somewhat detailed (step by step) explanation of how to accomplish this?
                            • BoxB Offline
                              Box @ntxdave
                              @ntxdave
                              It tells you what to do in the task bar.
                              It is basically four single click and releases.
                              A click at the start of the bend a click at the end of the bend then a click passed the bend and then bend it and a final click to complete.
                              I used the red blocks in my original to give me visual start and stop points for the bend.
                              • ntxdaveN Offline
                                ntxdave @Box
                                @Box Thank you sir! I finally got things working correctly and was able to "play around" a little. The image below represents what I figured out using the FredoScale tools. I greatly appreciate your help. 😁 πŸ‘ πŸ‘
