    [Plugin Library] LibFredo6 - v15.9d - 09 Jul 26
    2.2k Posts 580 Posters 5.7m Views 582 Watching
      TIG Moderator @Tpdart
      @Tpdart
      Do you have the latest versions of Curviloft, LibFredo6 and the SketchUcation toolset [for the licensing], installed and SketchUp restarted to sync things ?
      If this doesn't resolve things then perhaps you could try to release the license[s], and re-validate.
      If there's a corrupted file somewhere then deleting that and restarting to recreate it might help...
      This requires detailed advice - perhaps @Rich-O-Brien or @fredo6 will chip in...
      • Rich O BrienR Online
        Rich O Brien Moderator @Tpdart
        @Tpdart Hi,
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
        M 1 Reply Last reply Reply Quote 1
          mayankkumar @Rich O Brien
          @fredo6
          After updating libfredo6 to the latest version (v14.5f), all of my Fredo plugins have stopped working. I have ensured that all the plugins are up to date. While the plugins are visible on the screen, nothing happens when I click on them.
          fredo6F 1 Reply Last reply Reply Quote 0
          • fredo6F Offline
            fredo6 @mayankkumar
            @mayankkumar
            Do you get a message?
            Do you see the toolbars and menu?
            If you open the Ruby Conole, d you see error messages?
              mayankkumar
              Thank you, @fredo6, for your response. I reinstalled SketchUp and all the plugins, and that resolved the issue. The plugins are working perfectly now.
              • F Offline
                Finito86 Newcomers @TIG
                @TIG Its beeing a while but none has contact me or gave me a solution. Tell me should i stop asking for help?
                  Rich O Brien Moderator @Finito86
                  @Finito86 said in [Plugin Library] LibFredo6 - v14.5f - 07 Aug 24:
                  • F Offline
                    Fer18
                    I need The Pluggin
                    TIGT 1 Reply Last reply Reply Quote 0
                      TIG Moderator @Fer18
                      @Fer18
                      Your posts makes little sense !
                      If you need LibFredo6 download/install it from the PluginStore.
                      If you need some other Plugin [aka an Extension] then post in its thread - OR explain yourself better - we are not mind-readers...
                        miiraka Newcomers
                        thank you so much
                          DESIGN7
                          I am using Sketchup 2024 Pro version on a PC computer.
                          I have downloaded LibFredo6-v14.5f:
                          • the logo appears in Extension Manager but only as a grey (ghost) logo
                          • does NOT appear in Extension Warehouse
                          I have viewed the 15 minute video several times and still cannot figure out how to get access to the App. the video covers so many topics.
                          Is there a simple set by step guide - text or video that show how to install LibFredo6?
                            TIG Moderator @DESIGN7
                            @DESIGN7
                            As explained in the thread's first post: LibFredo6 is NOT a standalone plugin.
                            It will appear in the native Extension Manager and should be 'active', but it does little else.
                            It will have an entry in a Tools submenu if properly installed...
                            It's used as a Lib[rary] to support most of Fredo's extensions.
                            You need to install these separately...
                            Have you restarted SketchUp after this installation so that everything is synced ?
                            It will not appear in the Extension Warehouse - essentially because that is not the sole repository of good extensions.
                            Several authors, like Fredo and myself, choose to provide our extensions solely through the SketchUcation PluginStore / ExtensionStore³...
                            Some other developers publish on both platforms, while some others even use just their own web-sites to offer downloads...
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v14.6a - 18 Sep 24
                              LibFredo6 14.6a includes changes related to:
                              • ThruPaint v2.5a
                              • New plugins
                              • U Offline
                                unit611
                                Hi. I've tinkered with my computer profile a bit, and ended up destroying my original profile. I had to use a recover program to repair the profile.
                                After that, my fredo license wouldn't work with the sketchucation message showing "error A04". I repaired sketchup, but the problem wasn't solved. I even went ahead and bought a second license for the same plug-in, but it still said I had to revalidate. How do I revalidate my license in this situation?
                                  Rich O Brien Moderator @unit611
                                  @unit611 said in [Plugin Library] LibFredo6 - v14.6a - 18 Sep 24:
                                  U 1 Reply Last reply Reply Quote 0
                                  • U Offline
                                    unit611 @Rich O Brien
                                    @Rich-O-Brien
                                    the console says
                                    Fredo6 Plugins Information on 2024-09-27 08:42:14 +0900
                                    • Platform: x64-mswin64_140 - Ruby: 2.7.7
                                    • Sketchup: 23.1.340
                                    • LibFredo6: v14.6a
                                    • LibFredo6 Binary loaded
                                    • Sketchucation ExtensionStore: 4.4.1
                                    • SCFLicense: v6.4a - 74
                                    • Fredo6 Plugins
                                      Curviloft v2.0a
                                      Curvizard v2.5a
                                      FredoCorner v2.7a
                                      FredoScale v3.6a
                                      JointPushPull v4.8a
                                      ToolsOnSurface v2.6a
                                      TopoShaper v2.7a
                                      VisuHole v1.5a
                                      Signature File: absent
                                    would this help?
                                      @unit611 The last line shows that there is no signature file.
                                      This may be because your SketchUp install does not have the correct system read/write permissions.
                                      To remedy that you need to repair your SketchUp install. You'll find info on how to do that if you press F1 with SketchUp open.
                                      If you visit this path in your Windows Explorer...
                                      C:\Users\SomeName\AppData\Local\SCF Licenses
                                      What do you see?
                                      • U Offline
                                        @Rich-O-Brien
                                        There's two files, SCFLicenseLog and SCFLicenseSignature-DO NOT MODIFY OR DELETE.
                                        I've already tried repairing sketchup via sketchup unistaller, but it didn't seem to do anything.
                                          Please delete SCFLicenseSignature-DO NOT MODIFY OR DELETE.txt file with SketchUp closed
                                          Open SketchUp and run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and copy/paste output here
                                          • U Offline
                                            @Rich-O-Brien
                                            Fredo6 Plugins Information on 2024-09-28 01:11:53 +0900
                                            • LibFredo6: v14.6a
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              Curvizard v2.5a
                                              FredoCorner v2.7a
                                              FredoScale v3.6a
                                              JointPushPull v4.8a
                                              TopoShaper v2.7a
                                              VisuHole v1.5a
                                            It still says the signature file is absent. Is there something wrong with the folder I saved my licenses?
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 111
                                            • 112
                                            • 103 / 112
