    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 586 Posters 10.8m Views 588 Watching
      Anonimos24 Newcomers
      es estafa lo intale y haora ni me habra el sketchutp 2024 y a pesar de lo desintalo me sigue apresiendo y sigue igual no se soluciona nada ni desintlando 2a32bed3-76e4-4394-b6cf-66da5d6c11d7-image.png ![alt text](image url)
      TIGT 1 Reply Last reply
        TIG Moderator @Anonimos24
        @Anonimos24
        You are sorely mistaken.
        It is not a 'scam'.
        Fredo and this site are highly regarded.
        The reason you can't use it, is that it relies on a 'Lib' - LibFredo6.
        It is clearly spelled out on its download page...
        The error message even gives you a link to get it [you need to answer 'Si'].
        After it's been downloaded and installed, restart SketchUp so that everything gets synced.
        It will need licensing after a trial so you also need the SketchUcation tools installing for this...
        Estás muy equivocado.
        No es una 'estafa'.
        Fredo y este sitio gozan de gran prestigio.
        La razón por la que no puedes usarlo es que depende de una 'Lib': LibFredo6.
        Está claramente explicado en su página de descarga...
        El mensaje de error incluso te da un enlace para obtenerlo [debes responder 'Si'].
        Una vez descargado e instalado, reinicia SketchUp para que todo se sincronice.
        Necesitará una licencia después de una prueba, por lo que también necesitará instalar las herramientas SketchUcation para esto...
        • F
          fwany
          thank you!!
          • fredo6F
            NEW RELEASE: LibFredo6 v14.5f - 07 Aug 24
            LibFredo6 14.5f includes changes related to:
            • Bug fixing for dialogs
            • small technical adjustments
            • T
              Tpdart
              Ok, just fired up SU and I get popup
              'You must install Libfredo6 (v7.6 or higher to run Curviloft (which I have a licence for).
              Open the download page.....'
              Yes/no.
              If I answer yes it takes me to the Sketchucation page and terminates the SU session.
              I manually downloaded 7.6 and placed it in my extensions folder, but the popup still appears and terminates SU whether I answer yes or no...
              Help please!
              TIGT Rich O BrienR 2 Replies Last reply
                TIG Moderator @Tpdart
                @Tpdart
                Do you have the latest versions of Curviloft, LibFredo6 and the SketchUcation toolset [for the licensing], installed and SketchUp restarted to sync things ?
                If this doesn't resolve things then perhaps you could try to release the license[s], and re-validate.
                If there's a corrupted file somewhere then deleting that and restarting to recreate it might help...
                This requires detailed advice - perhaps @Rich-O-Brien or @fredo6 will chip in...
                  Rich O Brien Moderator @Tpdart
                  @Tpdart Hi,
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  M 1 Reply Last reply
                    mayankkumar @Rich O Brien
                    @fredo6
                    After updating libfredo6 to the latest version (v14.5f), all of my Fredo plugins have stopped working. I have ensured that all the plugins are up to date. While the plugins are visible on the screen, nothing happens when I click on them.
                    fredo6F 1 Reply Last reply
                    • fredo6F
                      fredo6 @mayankkumar
                      @mayankkumar
                      Do you get a message?
                      Do you see the toolbars and menu?
                      If you open the Ruby Conole, d you see error messages?
                        mayankkumar
                        Thank you, @fredo6, for your response. I reinstalled SketchUp and all the plugins, and that resolved the issue. The plugins are working perfectly now.
                        • F
                          Finito86 Newcomers @TIG
                          @TIG Its beeing a while but none has contact me or gave me a solution. Tell me should i stop asking for help?
                            Rich O Brien Moderator @Finito86
                            @Finito86 said in [Plugin Library] LibFredo6 - v14.5f - 07 Aug 24:
                            • F
                              Fer18
                              I need The Pluggin
                                TIG Moderator @Fer18
                                @Fer18
                                Your posts makes little sense !
                                If you need LibFredo6 download/install it from the PluginStore.
                                If you need some other Plugin [aka an Extension] then post in its thread - OR explain yourself better - we are not mind-readers...
                                  miiraka Newcomers
                                  thank you so much
                                    DESIGN7
                                    I am using Sketchup 2024 Pro version on a PC computer.
                                    I have downloaded LibFredo6-v14.5f:
                                    • the logo appears in Extension Manager but only as a grey (ghost) logo
                                    • does NOT appear in Extension Warehouse
                                    I have viewed the 15 minute video several times and still cannot figure out how to get access to the App. the video covers so many topics.
                                    Is there a simple set by step guide - text or video that show how to install LibFredo6?
                                      TIG Moderator @DESIGN7
                                      @DESIGN7
                                      As explained in the thread's first post: LibFredo6 is NOT a standalone plugin.
                                      It will appear in the native Extension Manager and should be 'active', but it does little else.
                                      It will have an entry in a Tools submenu if properly installed...
                                      It's used as a Lib[rary] to support most of Fredo's extensions.
                                      You need to install these separately...
                                      Have you restarted SketchUp after this installation so that everything is synced ?
                                      It will not appear in the Extension Warehouse - essentially because that is not the sole repository of good extensions.
                                      Several authors, like Fredo and myself, choose to provide our extensions solely through the SketchUcation PluginStore / ExtensionStore³...
                                      Some other developers publish on both platforms, while some others even use just their own web-sites to offer downloads...
                                      • fredo6F
                                        NEW RELEASE: LibFredo6 v14.6a - 18 Sep 24
                                        LibFredo6 14.6a includes changes related to:
                                        • ThruPaint v2.5a
                                        • New plugins
                                        • U
                                          unit611
                                          Hi. I've tinkered with my computer profile a bit, and ended up destroying my original profile. I had to use a recover program to repair the profile.
                                          After that, my fredo license wouldn't work with the sketchucation message showing "error A04". I repaired sketchup, but the problem wasn't solved. I even went ahead and bought a second license for the same plug-in, but it still said I had to revalidate. How do I revalidate my license in this situation?
                                            Rich O Brien Moderator @unit611
                                            @unit611 said in [Plugin Library] LibFredo6 - v14.6a - 18 Sep 24:
                                            U 1 Reply Last reply
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 113
                                            • 114
                                            • 103 / 114
