[Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
hello
i can't download FredoLib6 cause it contain Trojan virus. Have you the same problems? -
NEW RELEASE: LibFredo6 v14.5c - 03 Jul 24
LibFredo6 14.5c includes changes related to:
- Various bug fixing for several plugins
- small technical adjustment
@TIG said in [Plugin Library] LibFredo6 - v14.5c - 03 Jul 24:
Sketchup::require('SketchUcation/SCF_loader.rbe')
Hello there, sorry for the delay. I've tried your steps....here are some screenshots as usuall (lol). The first one is from the Ruby Console...you where right
asuming the SU its no able to load or find the files it need. Algo here its a picture of the sketchucation foldes on my roaming/sketchup folder.
The last part i've tryied it before by myself....the TOtal Control or Control Total is indeed ticked. I dont know why i sees so many "users" as i'm the onlyone using this computer. But here is a picture of 3 of them with all permissions ticked.
The strange thing is that theres is Special Permission at the bottom of the list i cannot tick.
Hope this is helpfull. You're trully are, thanks for helping me
@Finito86
The Plugins folder's permissions look OK...SketchUcation.rb is loading OK
but
../PluginsSketchUcation/SCF_loader.rbe is not loading OK.Please look at the ../Plugins/SketchUcation folder's Properties/Edit and check all entries have 'Full Control'...
Changes to the Plugins folder's Properties should filter down to all of the contents...
Also check that its RBE files have 'Full Control' and 'read' properties set - if not adjust them to suit...Perhaps @Gabor has some ideas ?
@TIG
Everything seems ok.... -
son estafa no lo descarguen lo intale haora no me deja abri shect
hup -
es estafa lo intale y haora ni me habra el sketchutp 2024 y a pesar de lo desintalo me sigue apresiendo y sigue igual no se soluciona nada ni desintlando
You are sorely mistaken.
It is not a 'scam'.
Fredo and this site are highly regarded.
The reason you can't use it, is that it relies on a 'Lib' - LibFredo6.
It is clearly spelled out on its download page...
The error message even gives you a link to get it [you need to answer 'Si'].
After it's been downloaded and installed, restart SketchUp so that everything gets synced.
It will need licensing after a trial so you also need the SketchUcation tools installing for this...Estás muy equivocado.
No es una 'estafa'.
Fredo y este sitio gozan de gran prestigio.
La razón por la que no puedes usarlo es que depende de una 'Lib': LibFredo6.
Está claramente explicado en su página de descarga...
El mensaje de error incluso te da un enlace para obtenerlo [debes responder 'Si'].
Una vez descargado e instalado, reinicia SketchUp para que todo se sincronice.
Necesitará una licencia después de una prueba, por lo que también necesitará instalar las herramientas SketchUcation para esto... -
thank you!!
NEW RELEASE: LibFredo6 v14.5f - 07 Aug 24
LibFredo6 14.5f includes changes related to:
- Bug fixing for dialogs
- small technical adjustments
Ok, just fired up SU and I get popup
'You must install Libfredo6 (v7.6 or higher to run Curviloft (which I have a licence for).
Open the download page.....'
Yes/no.
If I answer yes it takes me to the Sketchucation page and terminates the SU session.
I manually downloaded 7.6 and placed it in my extensions folder, but the popup still appears and terminates SU whether I answer yes or no...
Help please! -
@Tpdart
Do you have the latest versions of Curviloft, LibFredo6 and the SketchUcation toolset [for the licensing], installed and SketchUp restarted to sync things ?If this doesn't resolve things then perhaps you could try to release the license[s], and re-validate.
If there's a corrupted file somewhere then deleting that and restarting to recreate it might help...
This requires detailed advice - perhaps @Rich-O-Brien or @fredo6 will chip in... -
@Tpdart Hi,
Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
@fredo6
After updating libfredo6 to the latest version (v14.5f), all of my Fredo plugins have stopped working. I have ensured that all the plugins are up to date. While the plugins are visible on the screen, nothing happens when I click on them. -
@mayankkumar
Do you get a message?
Do you see the toolbars and menu?
If you open the Ruby Conole, d you see error messages? -
Thank you, @fredo6, for your response. I reinstalled SketchUp and all the plugins, and that resolved the issue. The plugins are working perfectly now.
@TIG Its beeing a while but none has contact me or gave me a solution. Tell me should i stop asking for help?
@Finito86 said in [Plugin Library] LibFredo6 - v14.5f - 07 Aug 24:
