    2.2k Posts 487 Posters 929.1k Views 492 Watching
      brittico Newcomers @TIG
      @TIG have whitelisted it as a "file type", also switched of defender, tried it again, and again, no luck, have the same problem with "round corner" which was already working as I bought the license back in march.
      TIGT Rich O BrienR 2 Replies Last reply Reply Quote 0
        TIG Moderator @brittico
        @brittico
        Are there other options like 'url' ?
        The string given is not a file-type...
          Rich O Brien Moderator @brittico
          @brittico
          Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
          B 2 Replies Last reply Reply Quote 0
            brittico Newcomers @Rich O Brien
            @Rich-O-Brien Fredo6 Plugins Information on 2024-07-06 16:50:40 +0100
            • Sketchup: 24.0.553
            • LibFredo6: v14.5c
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.4.1
            • SCFLicense: v6.4a - 74
            • Fredo6 Plugins
              Curviloft v1.9b
              FredoPortrait v2.9a
              RoundCorner v3.4a
              Signature File: 2024-07-04 16:41:09 +0100
              RoundCorner: 2024-03-04 10:02:47 +0000
              @Rich-O-Brien I have just found out none of my Fredo Extensions are working anymore, Curvy Loft and Round Corner are Extensions which I was already working with as I bought the license but now none of them are working, they are all telling me that I need to get a license and when trying to activate I get the same message for all three extensions.
                @brittico Please follow the steps in my previous reply.
                  @brittico said in SCFLicense: Extension Licensing on Sketchucation:
                  Please share the error messages. If it’s network related as it has been previously please change networks or whitelist
                  The more concise information you share in terms of error messages the sooner we can paint a picture of what is going on.
                  Also make sure you are using the latest versions of all extensions. This can be checked in SketchUcation Tools
                    parkjh1477
                    I have a activate problem with purchased license. anyone help me? ㅠ
                    TIGT 1 Reply Last reply Reply Quote 0
                      TIG Moderator @parkjh1477
                      @parkjh1477
                      The error message means the signature file can't be read.
                      You can follow the instructions and delete the file [folder opens on button click], then re-validate the licenses and see if that helps...
                      This can happen if you change the name of your computer, it can also be affected if you have computer name that doesn't follow the Windows rules - e.g. the computer's name contains special characters causing issues with the licensing system saved data...
                      Let us know how you get on...
                      P 2 Replies Last reply Reply Quote 0
                        parkjh1477 @TIG
                        @TIG
                        I tried changing the computer name, but it didn't solve the problem. However, the license for SketchUp 2021 version on the same computer works normally. Should I delete SketchUp 2021?
                          parkjh1477 @TIG
                          @TIG
                          I tried changing the computer name, but it didn't solve the problem. However, the license for SketchUp 2021 version on the same computer works normally. Should I delete SketchUp 2021? (i'm using ver.2024)
                            @parkjh1477
                            Both versions can exists side-by-side, so don't delete v2021 just yet.
                            Does your computer-name follow the Windows rules - i.e. no special characters...
                            This is a range of characters that can be considered safe:
                            Letters (a-z A-Z)
                            Digits (0-9)
                            Underscore (_)
                            Hyphen (-)
                            Space
                            Dot (.)
                            Beyond this, you just have to enforce some additional rules regarding spaces and dots. This is usually sufficient:
                            Name must contain at least one letter or number (to avoid only dots/spaces)
                            Name must start with a letter or number (to avoid leading dots/spaces)
                            Name may not end with a dot or space
                            Do you have any special characters in the computer-name OR your user-name ? - I guess you are Korean ?
                              parkjh1477 @TIG
                              @TIG Yes, I am korean. I fixed my problem following your advise. Really thank you for your kindness reply. Thanks!
                              • N Offline
                                November11 Newcomers
                                Please tell me how to solve the problem??
                                  TIG Moderator @November11
                                  @November11
                                  Follow the message's instructions on opening the folder and deleting the file.
                                  You might need to rename your computer...
                                  Your computer-name must follow the Windows rules - i.e. NO special characters in it...
                                  Letters (a-z A-Z)
                                  Digits (0-9)
                                  Underscore (_)
                                  Hyphen (-)
                                  Space
                                  Dot (.)
                                  Do you have any special characters in the computer-name OR your user-name ? - I guess you are Chinese ?
                                  Try fixing that and restart to see if that helps...
                                    SergioAlbelli Newcomers
                                    I have purchased an license last year. And when I try to use the Freddy Roundcorner Plugin. The system says, "free trail expired"?
                                    Rich O BrienR TIGT 2 Replies Last reply Reply Quote 0
                                      Rich O Brien Moderator @SergioAlbelli
                                      @SergioAlbelli Please check if your extensions are updated to latest releases.
                                      https://sketchucation.com/plugin/696-sketchucationtools
                                      https://sketchucation.com/pluginstore?pln=LibFredo6
                                      https://sketchucation.com/pluginstore?pln=Roundcorner
                                      You can do this directly in SketchUp using Extensions > Sketchucation > ExtensionStore
                                      Restart SketchUp after updating and then follow the licensing guide to activate: https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                        TIG Moderator @SergioAlbelli
                                        @SergioAlbelli
                                        In addition to Rich's useful info...
                                        We are assuming you have bought a license for Fredo's RoundCorner extension and not his other FredoCorner extension, whatever, then you need to save its file onto your computer and then validate it in the appropriate dialog opened from that extension's submenu in the Tools menu...
                                        There are pages to help you mange your licenses as listed in this thread...
                                        We need more info if you still can't resolve it...
                                          ameerproxy @Rich O Brien
                                          @Rich-O-Brien
                                          Hi Rich, i tried the the method ie: to delete SCF licence and restart and activate , that timethe licence was activated ,
                                          but the issue is that i am facing now is the other fredo plugins licence was deactivate , then again i need to close and do the process
                                          at a time only one plugin can activate and ready to use
                                          A 1 Reply Last reply Reply Quote 0
                                            ameerproxy @ameerproxy
                                            @ameerproxy
                                            For MY Information, Is the plugins need internet connection even after activated the license also , Please advise
                                            Thanks in advance
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 77
                                            • 109
                                            • 110
                                            • 75 / 110
