    2.2k Posts 487 Posters 931.9k Views 492 Watching
      ju_marq
      Hello. I bought the RoundCorner Perpetual License, I installed FredoCorner_v2.7a, LibFredo6_v14.5b, RoundCorner_v3.4a, SketchUcationTools_v4.4.1 and LibFredo6_v14.5a.
      I also downloaded SCF_Purchased_License_RoundCorner_NORMAL_20230615.scflicense
      but it is not working.
      Please help!!!
      Captura de tela 2024-06-11 175237.png Captura de tela 2024-06-11 175304.png Captura de tela 2024-06-11 175314.png
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @ju_marq
        @ju_marq
        I assume you have saved your license files to some subfolder on your computer - e.g. ../Documents/Licenses
        That's not sufficient to complete the action.
        It is spelled out in the help links above...
        Start SketchUp and under the Tools menu find the Fredo6 Collection item, look for your extensions.
        Find the section about License...
        In the dialog choose 'Activate License' and find the license file on your computer...
        Your screenshot shows you are almost there...
        You need to be connected to the Internet to do this.
        Click the Activate License button and navigate to your license file saved onto your computer.
        Note that FredoCorner and RoundCorner are different extensions and need to have their own license on your computer and Activated...
        Occasionally users confuse the two extensions and do not actually have a valid license file available...
        J 1 Reply Last reply Reply Quote 0
          junphuc17945 @TIG
          @TIG hi TIG
          Can you help me release this stuck licenses:
          Seat ID: 27971; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
          Seat ID: 27982; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
          Thank you !
            TIG Moderator @junphuc17945
            @junphuc17945
            Can't you login and manage your licenses yourself ?
            https://sketchucation.com/webshop/my-licences.php
              PMsarto
              Hi Fredo,
              I need assistance regarding the ClothWorks plugin license management.
              A few years ago, I purchased a perpetual license for ClothWorks, allowing activation on up to 3 computers (seats). Unfortunately, one of the computers that had an active license has been formatted and disposed of. As a result, I am unable to release the license from that machine.
              Could you please guide me on how to remotely release the license from the computer that is no longer in use? This would enable me to activate the plugin on my new laptop.
              Thank you very much for your help.
              Best
              Giuseppe
                Rich O Brien Moderator @PMsarto
                @PMsarto said in SCFLicense: Extension Licensing on Sketchucation:
                Send an email to support@sketchucation.com
                • H Offline
                  hoverteamph Newcomers
                  How can I release this license without check box? Do I have an option where I can force release this kinds of license? Please help thankyou .
                    Rich O Brien Moderator @hoverteamph
                    @hoverteamph Update Sketchucation Tools on the devices missing the checkbox to 4.4.1
                    Sketchucation Tools | SketchUcation
                    (sketchucation.com)
                      aagcmis Newcomers
                      How do I edit? Pls
                        ameerproxy @TIG
                        @TIG
                        I tried as per the instructions Thanks Let me try one more time ,
                          ameerproxy @TIG
                          @TIG
                          Hi I tried the methods you mention , but its showing the same Error As license Expired
                            Rich O Brien Moderator @ameerproxy
                            @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                              ameerproxy @ameerproxy
                              @ameerproxy ![alt text](Licence file history.jpg image url)
                              Sorry i cant understand what the solution to make it possible
                                @ameerproxy
                                Please run this command
                                A 2 Replies Last reply Reply Quote 0
                                  ameerproxy @Rich O Brien
                                  @Rich-O-Brien yes i run that
                                      @ameerproxy You have yet to run it because it generate the following.
                                        Rich O Brien Moderator @Rich O Brien
                                        @ameerproxy if you edit posts after providing incorrect info it is going to slow getting you sorted.
                                        Please provide the full output of Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
                                        Select the text in the Ruby Console and copy it. Then paste that into your reply.
                                        You have omitted vital information.
                                        A 1 Reply Last reply Reply Quote 0
                                          @Rich-O-Brien sorry here we go
                                          Fredo6 Plugins Information on 2024-06-28 16:40:32 +0400
                                          • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                          • Sketchup: 22.0.354
                                          • LibFredo6: v14.5b
                                          • LibFredo6 Binary loaded
                                          • Sketchucation ExtensionStore: 4.4.1
                                          • SCFLicense: v6.4a - 74
                                          • Fredo6 Plugins
                                            Curviloft v2.0a
                                            Curvizard v2.5a
                                            FredoCorner v2.7a
                                            FredoScale v3.6a
                                            RoundCorner v3.4a
                                            ThruPaint v2.4a
                                            ToolsOnSurface v2.6a
                                            VisuHole v1.5a
                                            Signature File: 2023-01-01 14:57:22 +0400
                                            Curvizard: 2023-03-15 18:36:09 +0400
                                            ToolsOnSurface: 2023-01-03 20:07:48 +0400
                                            @ameerproxy
                                            • Close SketchUp
                                            • Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                                            • Delete the SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                            • Start SketchUp
                                            Retrieve your license files from https://sketchucation.com/webshop/my-licences.php and save them locally on your device
                                            In SketchUp go to Tools > FredoCollection > FredoScale > License...
                                            Activate FredoScale using your Fredoscale license file
                                            Screenshot any Error messages
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 109
                                            • 110
                                            • 57 / 110
