    2.2k Posts 487 Posters 929.5k Views 492 Watching
      TIG Moderator @ameerproxy
      @ameerproxy
      Have you downloaded/installed the latest versions of all of those bundled Fredo6 extensions, and LibFredo6 and the SketchUcation tools [for the latest licensing set up].
      You also need to restart SketchUp to sync everything.
      The license files you got for the bundled set need to be stored somewhere safe on your computer - e.g. in a special subfolder made in your Documents folder. You then need to 'validate' each of them individually for each of Fredo6's extensions in the appropriate submenus under the Tools menu.
      A 2 Replies Last reply Reply Quote 0
        ju_marq
        Hello. I bought the RoundCorner Perpetual License, I installed FredoCorner_v2.7a, LibFredo6_v14.5b, RoundCorner_v3.4a, SketchUcationTools_v4.4.1 and LibFredo6_v14.5a.
        I also downloaded SCF_Purchased_License_RoundCorner_NORMAL_20230615.scflicense
        but it is not working.
        Please help!!!
        Captura de tela 2024-06-11 175237.png Captura de tela 2024-06-11 175304.png Captura de tela 2024-06-11 175314.png
        TIGT 1 Reply Last reply Reply Quote 0
          TIG Moderator @ju_marq
          @ju_marq
          I assume you have saved your license files to some subfolder on your computer - e.g. ../Documents/Licenses
          That's not sufficient to complete the action.
          It is spelled out in the help links above...
          Start SketchUp and under the Tools menu find the Fredo6 Collection item, look for your extensions.
          Find the section about License...
          In the dialog choose 'Activate License' and find the license file on your computer...
          Your screenshot shows you are almost there...
          You need to be connected to the Internet to do this.
          Click the Activate License button and navigate to your license file saved onto your computer.
          Note that FredoCorner and RoundCorner are different extensions and need to have their own license on your computer and Activated...
          Occasionally users confuse the two extensions and do not actually have a valid license file available...
          J 1 Reply Last reply Reply Quote 0
            junphuc17945 @TIG
            @TIG hi TIG
            Can you help me release this stuck licenses:
            Seat ID: 27971; HW ID: TZ1622599474.0M; Date of activation: 07/04/2022
            Seat ID: 27982; HW ID: FP1649300044.0M; Date of activation: 07/04/2022
            Thank you !
              TIG Moderator @junphuc17945
              @junphuc17945
              Can't you login and manage your licenses yourself ?
              https://sketchucation.com/webshop/my-licences.php
                PMsarto
                Hi Fredo,
                I need assistance regarding the ClothWorks plugin license management.
                A few years ago, I purchased a perpetual license for ClothWorks, allowing activation on up to 3 computers (seats). Unfortunately, one of the computers that had an active license has been formatted and disposed of. As a result, I am unable to release the license from that machine.
                Could you please guide me on how to remotely release the license from the computer that is no longer in use? This would enable me to activate the plugin on my new laptop.
                Thank you very much for your help.
                Best
                Giuseppe
                  Rich O Brien Moderator @PMsarto
                  @PMsarto said in SCFLicense: Extension Licensing on Sketchucation:
                  Send an email to support@sketchucation.com
                  • H Offline
                    hoverteamph Newcomers
                    How can I release this license without check box? Do I have an option where I can force release this kinds of license? Please help thankyou .
                      Rich O Brien Moderator @hoverteamph
                      @hoverteamph Update Sketchucation Tools on the devices missing the checkbox to 4.4.1
                      Sketchucation Tools | SketchUcation
                      (sketchucation.com)
                        aagcmis Newcomers
                        How do I edit? Pls
                          ameerproxy @TIG
                          @TIG
                          I tried as per the instructions Thanks Let me try one more time ,
                            ameerproxy @TIG
                            @TIG
                            Hi I tried the methods you mention , but its showing the same Error As license Expired
                              Rich O Brien Moderator @ameerproxy
                              @ameerproxy said in SCFLicense: Extension Licensing on Sketchucation:
                              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                ameerproxy @ameerproxy
                                @ameerproxy ![alt text](Licence file history.jpg image url)
                                Sorry i cant understand what the solution to make it possible
                                  @ameerproxy
                                  Please run this command
                                    ameerproxy @Rich O Brien
                                    @Rich-O-Brien yes i run that
                                        @ameerproxy You have yet to run it because it generate the following.
                                          Rich O Brien Moderator @Rich O Brien
                                          @ameerproxy if you edit posts after providing incorrect info it is going to slow getting you sorted.
                                          Please provide the full output of Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support
                                          Select the text in the Ruby Console and copy it. Then paste that into your reply.
                                          You have omitted vital information.
                                          A 1 Reply Last reply Reply Quote 0
                                            @Rich-O-Brien sorry here we go
                                            Fredo6 Plugins Information on 2024-06-28 16:40:32 +0400
                                            • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                            • Sketchup: 22.0.354
                                            • LibFredo6: v14.5b
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: 4.4.1
                                            • SCFLicense: v6.4a - 74
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              Curvizard v2.5a
                                              FredoCorner v2.7a
                                              FredoScale v3.6a
                                              RoundCorner v3.4a
                                              ThruPaint v2.4a
                                              ToolsOnSurface v2.6a
                                              VisuHole v1.5a
                                              Signature File: 2023-01-01 14:57:22 +0400
                                              Curvizard: 2023-03-15 18:36:09 +0400
                                              ToolsOnSurface: 2023-01-03 20:07:48 +0400
                                            • 109
                                            • 110
                                            • 4 / 110
