    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 914.8k Views 122 Watching
    • fredo6F
      NEW RELEASE: FredoTools v4.5a - 02 Apr 24
      Requirement:
      • LibFredo6 v14.3b or above
      FredoTools 4.5a is a maintenance release for:
      • Future compatibility
      See FredoTools plugin home page for Download.
      See also main post of this thread for User Discussion.
      yanrothwellY 1 Reply Last reply
      • yanrothwellY
        yanrothwell @fredo6
        @fredo6 Hi I have used Fredo6's tools for manyt years and they are always super useful.
        At present, since SU2024 I have had issues with SUClock, which I stopped using whilst it was updated.
        I've since started using SUClock since the update and its been working fine.
        Today I started up SU2024 with an existing project (double clicking on the skp file itself, incase that is ever relevant how I 'opened up' the file) and I got the following error.
        This error hasn't gone away and did not start working up next restart of SU2034, so I wonder if you can help - Screenshot 2024-06-04 104337.png
        I see the icon of SUClock but it does nothing when clicked on.
        Multiple restarts have not fixed anything. There are similar errors with ThruPaint and Toposhaperm unforrtunately. Can anyone help? plugin information as follows:
        Fredo6 Plugins Information on 2024-06-04 12:00:59 +0100
        • Sketchup: 24.0.484
        • LibFredo6: v14.5b
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.4.0
        • SCFLicense: v6.4a - 74
        • Fredo6 Plugins
          LordOfTheToolbars v2.7b
          Curviloft v2.0a - licensed FULL
          Curvizard v2.5a
          FredoCorner v2.7a - licensed FULL
          FredoScale v3.6a - licensed FULL
          FredoTools v4.5a
          JointPushPull v4.8a - licensed FULL
          SUClock v3.1a
          ToolsOnSurface v2.6a - licensed FULL
          TopoShaper v2.7a - licensed FULL
          Signature File: 2022-03-30 14:03:14 +0100
          ClothWorks: 2022-10-27 15:42:55 +0100
          Curviloft: 2022-09-03 15:21:17 +0100
          FredoCorner: 2024-03-04 13:57:21 +0000
          FredoScale: 2022-04-25 11:42:35 +0100
          FredoSpline: 2022-11-21 16:26:56 +0000
          JointPushPull: 2022-05-08 14:44:25 +0100
          ToolsOnSurface: 2022-04-25 13:46:45 +0100
          TopoShaper: 2022-09-02 16:10:20 +0100
        MrHide_1.8a
        AutoInstall Finished.
        Using Main Plugins Folder.
        C:/Users/<user>/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins
        http://www.ianrothwell.co.uk
        fredo6F 1 Reply Last reply
        • fredo6F
          fredo6 @yanrothwell
          @yanrothwell
          Did you install SU2024 with 'Run as dministrator'?
          • yanrothwellY
            yanrothwell @fredo6
            @fredo6 yes
            • fredo6F
              fredo6 @yanrothwell
              @yanrothwell
              Could you open the Ruby console and copy paste the following command, and then type Enter:
              UI.openURL F6_SUClock::Project.get_tmpdir
              This will open the temp directory, in which you have files with extension .txt and a form like XXX__YYY.txt.
              Just erase them. It seems that one of them is corrupted.
              Erasing them should not impact your SUClock data.
              Then restart Sketchup.
              • yanrothwellY
                yanrothwell @fredo6
                @fredo6 Many thanks - after doing just that and restarting, it worked. no errors upon startup.
                Cheers \o/
                • fredo6F
                  NEW RELEASE: FredoTools v4.5c - 24 Jun 24
                  Requirement:
                  FredoTools 4.5c is a maintenance release for:
                  • Fix for the caluclation of volumes in SolidVolume
                    rv1974
                    a true Doh! moment - Angle Inspector has Slope meter in %% ! Many many thanks, Fredo.
                    P.S. Maybe one day it would become interactive - showing live the slope altering.
                    • fredo6F
                      NEW RELEASE: FredoTools v4.6a - 21 Oct 26
                      Requirement:
                      • LibFredo6 v16.3b or above
                      FredoTools 4.6a is a maintenance release for:
                      • Compatibility SU2027
                      • Fix along with LibFredo6 v16.3a
                        romelsantiago0892 Newcomers
                        We have a lincense of the fredo tools knowing that thru paint is bundled together with it, but then the Thru paint has seperate lincense today, how will we be able to activate the thru paint if that is now seperated. kindly need Help.
                        • 20
                        • 21
                        • 22
                        • 23
                        • 24
                        • 24 / 24
