    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
      sashapepperspray @pixelcruncher
      @pixelcruncher There is no option anymore to change the texture type (color or image or perlin noise). Was this purposely removed, or is this a bug. I found the perlin noise one especially to be useful (for roughness).
      • pixelcruncherP
        pixelcruncher Extension Creator @sashapepperspray
        @sashapepperspray
        I removed it from the user interface because I assumed the use was limited, and maybe too complex. If you have use for it I will definitely bring it back in the user interface the next release.
        S 1 Reply Last reply
          @pixelcruncher thanks!
          • majidM
            majid @pixelcruncher
            @pixelcruncher I was going to prepare a car paint material pack and thought it would be nice if I could have my custom material preview, nothing serious.
            pixelcruncherP 2 Replies Last reply
            • majidM
              @pixelcruncher huge amount of job! well done!
              I am wondering if this is possible to assign a map/option for "opacity" of the materials. so that I could make a perforated metal sheet i.e.?
              Also I may not be able to imagine that a metal/mirror material is emitting light.. is there any real-life example?
              • pixelcruncherP
                pixelcruncher Extension Creator @majid
                Hey @majid,
                Yeah, I see how this can be handy for you. I will re-add the material previews in one of the subsequent releases and make a note to support custom material previews.
                For my information, are you interested in having a custom material preview while editing the material or after saving it in the material library? Or in both places?
                Cheers,
                Thomas
                majidM 1 Reply Last reply
                • pixelcruncherP
                  @majid
                  That should already be there unless you are talking about something else. You can plug a map into the material's opacity input.
                  I don't think so, but artists might still want to use it. Is that something that bothers you? 😊 The implementation of emission is shared by all materials so that I can put it on every material at no extra cost.
                  Cheers,
                  Thomas
                  • majidM
                    @pixelcruncher Ah I did not noticed the "square" as an "image place holder", Thank you... πŸ‘
                    • majidM
                      @pixelcruncher Yeap it makes sense if is in front of its name. Much better if could be undocked , floating and enlarged. Untitled-1.png
                      • pixelcruncherP
                        Hey, Rayscaper friends!
                        Rayscaper 0.9.15 is available (0.9.14 was an internal test release) in the SketchUcation store. A lot of fixes and new things so I recommend you upgrade to this version.
                        What Changed?
                        Improvements
                        Desktop Scaling
                        Some users complained that Rayscaper was not legible on high-res, especially with display scaling enabled. I added a configuration option to scale the user interface to make it more readable on such displays.
                        Fast Tone Mapping
                        Improve the speed of the tone mapping operations. All operations now run in real-time, even on big render resolutions.
                        More Intuitive Exposure Control
                        Make the exposure slider more intuitive. Negative values darken the image, and positive values brighten itβ€”an exposure step value of one doubles or halves the brightness. A value of 0 means a neutral exposure.
                        More Zoom Controls
                        Add zoom controls to the Rayscaper toolbar and the option to fit the viewport.
                        Fewer Watermarks
                        Although Rayscaper is commercial ( and I think it is a very affordable piece of software πŸ™‚ ), I also wanted to reduce the watermarking to improve the experience for free users.
                        Bug Fixes
                        • Add the option to scale the user interface. This makes Rayscaper a lot more legible on high DPI displays.
                        • Bring back the capability to configure the following texture types (cc: @sashapepperspray):
                          • Noise Texture
                          • Uv Texture
                          • Mix Texture
                          • Checkerboard Texture
                        • Bring back the double-sided and fake emission controls for light-emitting materials (cc: @majid).
                        Help me build the community πŸ‘
                        I'm on Twitter (X) now: https://twitter.com/Rayscaper3d/ - Please follow the @Rayscaper3d that will help me grow the community and spread the word about Rayscaper! πŸ™
                        Happy Rendering!
                        Reply Quote 2
                          @pixelcruncher
                          thank you for this update, and putting back the noise/ mix/ checkerboard options.
                          Reply Quote 2
                          • ntxdaveN
                            ntxdave
                            If I purchase RayScaper will I be able to install and use it with both 2024 and 2020? I also have a new laptop. Will I be able to install it on both of my laptops?
                            Press F1...thank me later
                              Rich O Brien Moderator @ntxdave
                              @ntxdave Rayscaper is not compatible with SketchUp 2021 and below.
                              ntxdaveN 1 Reply Last reply
                              • ntxdaveN
                                ntxdave @Rich O Brien
                                @Rich-O-Brien Thanks Rich. That is what I thought but some place I thought I thought their product or web site said something about 2020.
                                Right now I have thr trial version but it is about to expire. I need to go try something again because u thought I saw an error but I will have to evaluate that. πŸ™‚
                                • pixelcruncherP
                                  pixelcruncher Extension Creator @ntxdave
                                  @ntxdave We only support 2021 or higher. 2020 is not supported.
                                  There’s no time-limited trial, you can use it for free as long as you like but the free version has a small watermark.
                                  Cheers,
                                  Thomas
                                  • pixelcruncherP
                                    Rayscaper 0.9.23 Beta is available in the SketchUcation store. A lot of fixes and new things so I recommend you upgrade to this version.
                                    What Changed?
                                    Improvements
                                    New GUI Framework
                                    Migrated Rayscaper to a new graphical user interface (GUI) framework. This changes the look and feel of the GUI but
                                    was done mainly to simplify Rayscaper's code base to enable faster future development. This was a significant change and why it took +1 Month since the previous release.
                                    Here's what Rayscaper looks like now:
                                    Some controls changed, so make sure to check the help:
                                    Express Light Emitting Materials in Watt
                                    • Controlling light emitting materials (LEMs) was sometimes tricky. I fixed some bugs in this area, and LEMs are now expressed in Watts.
                                    Bug Fixes
                                    • Make sure that VCB input works again with the light tools.
                                    Happy Rendering!
                                    • ntxdaveN
                                      ntxdave @pixelcruncher
                                      @pixelcruncher said in Rayscaper New Releases:
                                      I like the updated UI. To me it is easier to read and some of the tools are definitely improved (IMO) πŸ‘ πŸ‘
                                      I do not have a Twitter account and not sure I want one. You should explore the idea of having your own forum. πŸ™„
                                      pixelcruncherP Mike AmosM 2 Replies Last reply
                                      • pixelcruncherP
                                        @ntxdave
                                        Great to hear that you like the new GUI better! It took some effort to migrate the code.
                                        I have been dragging my feet on having a Rayscaper forum. I got by with the SketchUcation forum and the official SketchUp forum. I also haven’t done any real effort spread the word about Rayscaper, always have been focused on programming the software. Definitely something to think about for me.
                                        • pixelcruncherP
                                          Rayscaper 0.9.25 Beta is available in the SketchUcation store. Some fixes and improvements. As always, I recommend upgrading to the latest version.
                                          What Changed?
                                          Improvements
                                          Support SketchUp Shadows
                                          You can now create a directional light in Rayscaper that is directly coupled to the SketchUp shadows feature. You can enable this feature from the Rayscaper menu:
                                          Enabling this creates a new directional light that syncs with the SketchUp shadows controls.
                                          Filter material & light lists
                                          Type some text in the filter box to filter in your lights and materials lists:
                                          0f66e335-86d6-4479-9295-b9765127cc1f-image.png bc5f74d7-b21d-4b76-bcac-4031309d2590-image.png
                                          Bug Fixes
                                          • Fix "ghost" lights in Rayscaper. Sometimes, lights that you deleted before would re-appear again when loading the scene at a later time.
                                          • Disable the light tools when the user is editing inside a component. Adding Rayscaper lights to SketchUp components is not supported (it's on our roadmap). To avoid this, we now disable the light-creation tools when a component is edited.
                                          • Show light and material names alphabetically.
                                          If you like Rayscaper, please share your renders! This will help me showcase its capabilities to other potential users.
                                          Happy Rendering!
                                          • pixelcruncherP
                                            Hey folks,
                                            There was an issue with the previous release (0.9.25 Beta). Rayscaper would refuse to render and stay idle. This is fixed in version 0.9.26 Beta. You can get it from the plugin store.
                                            • 26
                                            • 27
                                            • 2 / 27
