    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 38.7k Views 7 Watching
      @Mike-Amos Since the viewport zooming/panning update I've noticed that behaviour.
      I tend to use the material list to pick materials because its not giving me a sense of security picking materials from the render viewport.
      • pixelcruncherP
        pixelcruncher Extension Creator @Rich O Brien
        Hey @Mike-Amos ,
        As @Rich-O-Brien mentioned, the metal material is a physically correct metal shader. So, there's no accurate artistic control. Rich made a metal library available, and I will also put that in the next release. For complete artistic control, the Disney material is what you want.
        I will have a look at the picking bug. Out of curiosity, is the material directly painted on the faces, or is it painted on the object?
        Cheers,
        Thomas
        majidM Mike AmosM 2 Replies Last reply
        Reply Quote 2
        • majidM
          majid @pixelcruncher
          @pixelcruncher it seems that the HDRI image is also pixly, so maybe adding an "upscaling" option to make low-res images, smooth, would be nicen
          Reply Quote 2
            Mike Amos @pixelcruncher
            @pixelcruncher
            When I mention colur of a metal I am talking abouyt the change in colour when 'metal' is chosen as a finish but, still early days yet.
            At the moment an automatic colour change turns what I want to be chrome becomes brass or bronze with no method of changing/preventing that.
            • pixelcruncherP
              pixelcruncher Extension Creator @majid
              @majid said in Rayscaper, My trip down the road to adjumacation.:
              That's a good idea; I will put it in my backlog. edit: It would not necessarily be upscaling because that might result in quality loss. I would add texture filtering to blur away those offensive pixelation artifacts, similar to what is done in games.
              Note that if you are using the HDRI from the asset library (which is sourced from PolyHaven), you can choose to increase the default resolution:
              You need to restart SketchUp for the change to take effect. Increasing the resolution will also increase the download time for the asset.
              Cheers,
              Thomas
              • pixelcruncherP
                pixelcruncher Extension Creator @Mike Amos
                @Mike-Amos said in Rayscaper, My trip down the road to adjumacation.:
                @pixelcruncher
                Hey @Mike-Amos
                I'm not sure I'm following the when metal is chosen as finish - do you mind providing some more info or a screenshot?
                Cheers,
                Thomas
                Mike AmosM 1 Reply Last reply
                  @pixelcruncher
                  A little further down the road, moving on, officer......2 4M 56s GPU Irfanview.jpg
                  • pixelcruncherP
                    Nice render, but the interior could do with some extra lights. Very interesting stairs, never saw that before. Was this done in Rayscaper?
                      @pixelcruncher
                      This is my Rayscaper thread so, yes, in Rascaper.
                      There are 8 lights in that scene which should be OK along with an EXR.
                      I would like to have a better, more informative method of identifying the lights being adjusted. Several are candles so the light has to be reduced for that. Perhaps a designator on the scree would help.
                      Basically I am finding any real adjustment difficult to near impossible due to not being able to read the dialogue boxes. I will have at some stage to acquire a nother monitor but that will do nothing to fix this issue.
                      TBH, while I render architectural pieces, I do not DO architectural renders. I have a leaning towards more realistic lighting levels which is out of synch with folk who want "More lights on everything".
                      The stairs are more commonly found on yachts and small boats and are a space saving measure. Not popular with architectural purists who will simply say that "Never get that past inspection in America, etc".
                      I know, a bit like those who want fridge freezers in a kitchen boxed in for the same reason. Not doing architectural renders and NOT in America let alone actually expecting these things to be built.
                      • pixelcruncherP
                        @Mike-Amos @Rich-O-Brien - The latest release should resolve the material/camera picking issues. Can you confirm that?
                        • pixelcruncherP
                          Makes sense, I didn't want to assume 😁
                          That's a good idea. Overlaying the viewport with some widgets to indicate the lights. I will put it on my roadmap.
                          This is good feedback. What is your display resolution, and are you using display scaling? I don't think Rayscaper respects display scaling right now, but I have to check the documentation of the user interface library I am using.
                          Gotcha!
                          No worries, I wasn't criticizing; I was just curious about the staircase.
                          Cheers,
                          Thomas
                            @pixelcruncher
                            G'day mate,
                            The monitor is set at 2560 x 1330 at the moment. Good enough for most tasks.
                            No criticism taken mate, we are discussing the topic and it's all good. Just covering off the things I do rather idiosynchratically. Being a 'do things my own way' personality.
                            I am getting to grips with Rayscaper, it's taking a bit of adjustment from the ol' noggin but getting there bit by bit. Well worth the time tbh.
                            Something that might help the screen issue I feel is in the way would be on demand dialogue boxes to reduce screen 'clutter'.
                            Mike AmosM pixelcruncherP 2 Replies Last reply
                              Mike Amos @Mike Amos
                              Further on, different view. I have managed to return the walls to the previous material.6 4m 49s GPU.png
                              • Bryan KB
                                Wow! That is well done!
                                  Mike Amos @Bryan K
                                  @Bryan-K
                                  Thanks mate, some mat changes and a better hdr for the scene will help.
                                  • pixelcruncherP
                                    @Mike-Amos Very well done. I'm pleased to see you are getting good results.
                                    • pixelcruncherP
                                      Do you also use display scaling, or is it at 100%? Also, do other applications behave well? A screenshot might help us see how it compares to other applications.
                                      Great to hear!
                                      In the latest release, I'm trying to hide more things, especially if they are not enabled. But can I hide even more things? Is there any screen in particular that is bothering you?
                                      Cheers,
                                      Thomas
                                        @pixelcruncher
                                        Nothing actually 'bothers' me, the screen is reminiscent of Maxwell in most respects.
                                        The hdri/texture corner is both bigger than it need to be while being too small to show much in the way of detail of the different options.
                                        When it comes to it, the single screen thing is getting old but I am looking into that but clearing screen clutter when elements are not requirted would be very helpful.
                                        Undocking these different parts of the Rayscaper window an placing them on =the second or third monitor would enable much more clarity for the render window itself. IMOHO, of course.
                                          @Mike-Amos
                                          Movement.
                                            • 1 / 9
