    Iria - main car
    53 Posts 4 Posters 6.8k Views 4 Watching
    • Bryan KB
      Way off. So, so far off. This is better.
      • Bryan KB
        Well dang. It's only better because now I've just seen what I've done wrong. πŸ˜† πŸ˜†
        • Bryan KB
          OK. Now we're getting somewhere.
          Reply Quote 2
          • Bryan KB
            Doing the rough blocking.
            • Bryan KB
              OK, now just have to smooth and connect everything. The proportions are just about right. The details will come after I'm happy with the overall shape.
              • Bryan KB
                Slight change in proportions. Main body slightly wider and parasol slightly bigger. Outboard riggers stayed the same, just move outward to match outer edge of main body. I want to make sure the proportions are right before committing to details.
                • Bryan KB
                  Still refining proportions and locations. Just using simple geometry and component halves until ready to commit to curves.
                  • Bryan KB
                    Still working on proportions.
                    Same problems as all the other anime spacecraft I've done. No consistency between drawings. But as usual, I'll solve it.
                    • Bryan KB
                      Checking alignments and solving the curves.
                      I'm off by a few inches center of body and twin tails. Half to fix that first.
                      • Bryan KB
                        BTW, you can the anime for free here. Old school stuff.
                        • Bryan KB
                          Beginning the geometry subdivide and positioning.
                          • Bryan KB
                            A little more refinement while I'm thinking about it.
                            Also, tails were too far out, port and starboard. Moved them back in a little. This gave me a better angle from body to tails.
                            It's starting to shape up!
                            • Bryan KB
                              Yeah, that back end was not easy and it's probably still wrong. But there are no reference pictures to go by. None.
                              But look at that profile! BTW, the top and bottom of the main body are not identical. The bottom has a slight offset and bulkier profile as shown in the drawings.
                              Iria car 15.jpg Iria car 16.jpg Iria car 17.jpg Iria car 18.jpg Iria car 19.jpg
                              • Bryan KB
                                This is better. Cleaned up some other geometry as well.
                                • Bryan KB
                                  More geometry clean up.
                                  Normally, I would just do a top/bottom component mirror, but the bottom hull is a slightly different proportion as per the original drawings.
                                  • Bryan KB
                                    Roughing in the arcs. I will use Curviloft for the final curves from body to tails. 5 arcs to make the curve. One for the nose, and two arcs, top and bottom.
                                    • Bryan KB
                                      Component structure. Left right mirror for body, left right and top bottom for tails
                                      • Bryan KB
                                        The Curviloft begins. After much jiggling and fiddling and a few choice words, and corrections to the base geometry (my alignment off as usual), and then a couple of dozen arcs failures to find just the right curve, I got the top part made.
                                        Yeah, I like this! On to the bottom part!
                                        • Bryan KB
                                          LOL! And it's wrong. Nice, but wrong. Close. Oh so close.
                                            Rich O Brien Moderator @Bryan K
                                            @Bryan-K turn on wires so we can see topology. I'm wondering if your skinning method or skinning rails are causing the bulging/pinching at either extremity.
                                            Sometime balancing the vertex will help with better skinning results.
                                            • 1 / 3
