    Iria - main car
    53 Posts 4 Posters 3.1k Views 4 Watching
    • Bryan KB Offline
      As always, I'm not sure where to start and it's more complicated than it looks. πŸ˜†
      • Bryan KB Offline
        I'll start with two component halves based on these pics:
        • Bryan KB Offline
          Front section first. Just a flat outline. Two component halves. I want to make sure the nose profile and general scale is right. I'll eyeball this for a while and then go to the next step. 3 curves to make the nose. The rest of the model will hang on this.
          L 1 Reply Last reply Reply Quote 2
            L i am @Bryan K
            @Bryan-K Are you really sure you want to do this?😲 πŸ˜• πŸ˜‰
            Bryan KB 1 Reply Last reply Reply Quote 0
            • Bryan KB Offline
              Bryan K @L i am
              @L-i-am said in Iria - main car:
              LOL! I hope it doesn't take as long as the Nadesico did!
              • Bryan KB Offline
                So basically boat shape. Extrude top and bottom. Scale front and side.
                Rounding of side hulls is not right. Proportions are way off. So that will be next.
                • Bryan KB Offline
                  Way off. So, so far off. This is better.
                  • Bryan KB Offline
                    Well dang. It's only better because now I've just seen what I've done wrong. πŸ˜† πŸ˜†
                    • Bryan KB Offline
                      OK. Now we're getting somewhere.
                      • Bryan KB Offline
                        Doing the rough blocking.
                        • Bryan KB Offline
                          OK, now just have to smooth and connect everything. The proportions are just about right. The details will come after I'm happy with the overall shape.
                          • Bryan KB Offline
                            Slight change in proportions. Main body slightly wider and parasol slightly bigger. Outboard riggers stayed the same, just move outward to match outer edge of main body. I want to make sure the proportions are right before committing to details.
                            • Bryan KB Offline
                              Still refining proportions and locations. Just using simple geometry and component halves until ready to commit to curves.
                              • Bryan KB Offline
                                Still working on proportions.
                                Same problems as all the other anime spacecraft I've done. No consistency between drawings. But as usual, I'll solve it.
                                • Bryan KB Offline
                                  Checking alignments and solving the curves.
                                  I'm off by a few inches center of body and twin tails. Half to fix that first.
                                  • Bryan KB Offline
                                    BTW, you can the anime for free here. Old school stuff.
                                    • Bryan KB Offline
                                      Beginning the geometry subdivide and positioning.
                                      • Bryan KB Offline
                                        A little more refinement while I'm thinking about it.
                                        Also, tails were too far out, port and starboard. Moved them back in a little. This gave me a better angle from body to tails.
                                        It's starting to shape up!
                                        • Bryan KB Offline
                                          Yeah, that back end was not easy and it's probably still wrong. But there are no reference pictures to go by. None.
                                          But look at that profile! BTW, the top and bottom of the main body are not identical. The bottom has a slight offset and bulkier profile as shown in the drawings.
                                          Iria car 15.jpg Iria car 16.jpg Iria car 17.jpg Iria car 18.jpg Iria car 19.jpg
                                          • Bryan KB Offline
                                            This is better. Cleaned up some other geometry as well.
                                            • 1 / 3
