    [Deprecated]Sketchucation Tools 4.4.1
    60 Posts 18 Posters 7.2k Views 17 Watching
      Rich O Brien Moderator @ricky2468
      @ricky2468
      Have you followed the activation instructions?
      https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
      Go here https://sketchucation.com/webshop/my-licences.php
      Download your license files to your Downloads folder on your device. There is no need to open these files after downloading. Proceed to the next step...
      Now in SketchUp go to Tools > Fredo Collection > JointPushPull > License... and when you click Activate navigate to your Downloads folder, pick your license file and click Open
      Repeat these steps for the other extensions.
        ricky2468
        Thank you. I have the plugins ive downloaded working. when i read the activation instructions before i didnt see that there was more than one page as I can see on your link. Thats probably me!!!!
        Im still getting a blank page on the red button inside the Extension store Window in Skecthup. Not causing me a problem but before I updated to V4.4 i had a list of plugins showing.
          @ricky2468 said in Sketchucation Tools 4.4.0:
          That's could be a cache issue. If you clear your Microsoft Edge Cookies does it load?
          TIGT R 2 Replies Last reply Reply Quote 0
            TIG Moderator @Rich O Brien
            @Rich-O-Brien
            With an HtmlDialog SketchUp caches its 'chromium' stuff somewhere like here:
            C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2024\WebCache-112.0.5615.165
            I don't know what's in it or how to clear it !
            R 1 Reply Last reply Reply Quote 0
              ricky2468 @Rich O Brien
              @Rich-O-Brien
              I cleared the cookies and reloaded sketchup but still nothing showing
                ricky2468 @TIG
                @TIG Ive
                I found this. Im using skecthup 2018 but it has dolders for verions of skecthup from 2017 to 2023. I expect 2017 was the first vesion I used on this pc.
                Looking in the 2018 folder there are three other folders inside WebCache. They are Cache, Dictionaries and GPUCache. Plus some some other files, Cookies 7KB; Cookies - journal 0KB; debug.log 568KB txt doc and visited links 128KB.
                  RLGL
                  I am trying to understand the managing of sets. If I have the steps right:
                  Start store extension
                  Use the blue button
                  disable extensions
                  select the sets menu
                  provide name
                  click the add button
                  At this point I expect the name I added to populate the list box
                  Any Ideas???
                  Thx Dave
                    Rich O Brien Moderator @RLGL
                    @RLGL It looks to be broken in 4.4 but I need to test further to see how broken. Thanks for heads up.
                      sungeric
                      Hi everyone,
                      I'm running into a similar situation where the plugin store extension is properly installed but when I click on the extensionstore, the dialogue box opens but nothing shows up.
                      Ruby Console doesn't show anything when I open the extension as well. I have tried the full access adjustment, restarting sketchup, etc. and nothing helps.
                      Is there a site that I'm supposed to unblock with my organization? I do see a sonic wall error when I open the plugin manager. Extensions manager works fine and shows all installed extensions with no errors.
                      I'm running 2024 SketchUP.
                        Rich O Brien Moderator @sungeric
                        @sungeric said in Sketchucation Tools 4.4.0:
                        I think you've found the source of the issue with the Sonic Wall software.
                        You need to get *.sketchucation.com whitelisted
                          v4.4.1 - Plugin/Extension Manager bugfixes
                          Extension Manager Load Temp functionality has been removed as Extension's Manager Temp-load is 'blocked' by the sketchup API
                            pipinek
                            Greetings,
                            I have a strange issue with this extension.
                            Simply cannot activate via the extension via this one.
                            Skin extension returns itself to the right part of the Sketchucation Tools window (as Disabled - see attached image)
                            Thank you in advance for any piece of advice!
                            TIGT 1 Reply Last reply Reply Quote 0
                            • RTCoolR Offline
                              RTCool
                              I'm getting an error on a dozen plus plugins when trying to install in SU 2024 on my 2016 Macbook Pro saying that the file could not be unzipped. Didn't have this problem on 2023 with this machine, or with 2024 on a new M1 Max Macbook Pro. Any ideas?
                                TIG Moderator @pipinek
                                @pipinek
                                If you try and load it using the native Extension Manager [and restart] what happens ?
                                RTCoolR 1 Reply Last reply Reply Quote 0
                                • RTCoolR Offline
                                  RTCool @TIG
                                  @TIG Looks like my mistake. Without checking carefully, I thought the last version I had downloaded was current, but apparently, it was 4.3.1 and that was causing the problem. Now that 4.4.1 is installed it's working OK.
                                  I must say, the new version seems laggy. We'll see.
                                  • mariochaM Offline
                                    mariocha
                                    download page still says 'Latest is 4.4.0 ' πŸ™‚
                                    %(#008000)[Mario C.
                                    • mariochaM Offline
                                      mariocha @Rich O Brien
                                      @Rich-O-Brien
                                      Hi Rich,
                                      minor thing; the download page still says Latest is 4.4.0 πŸ™‚
                                      %(#008000)[Mario C.
                                        Rich O Brien Moderator @mariocha
                                        @mariocha said in Sketchucation Tools 4.4.1:
                                        @Rich-O-Brien
                                        Hi Rich,
                                        Sorted now...good find
                                        • ntxdaveN Offline
                                          ntxdave
                                          When I try to reply or add a post and want to include a file (like a skp file) I do not see the link to add a file. I also tried just dropping an skp file in the response box but got an error message that said I do not have the privilege to do that. I do not recall ever having that problem in the past. Can someone help?
                                          Press F1...thank me later
                                            PSG64 Newcomers @ricky2468
                                            @ricky2468 said in Sketchucation Tools 4.4.1:
                                            I have purchased licenses for Fredo bundle, i.e. RoundCorner etc.
                                            Instructions say to update Sketchucation Extension Store to activate fredo plugins. I now have Extensionstore v4.4.
                                            It is empty. No plugins are listed. Before I update it showed all my plugins.
                                            I cant see how to view extensions and apply my new Fredo licenses.
                                            Hopefully someone can help me resolve the issue.
                                            I have the same problem. All my Fredo Licenses were active now when I try to use the Fredo Plugins i get the message that the trial has ended (even Round Corner which I thought was free and didnt require a paid license?). If I go into my license manager to release the seat it is not allowing this? How can I release the seats to activate the license again?
                                            Paul
                                            • 2 / 3
