    [Deprecated]Sketchucation Tools 4.4.1
    60 Posts 18 Posters 10.4k Views 17 Watching
    • P
      pipinek
      Greetings,
      I have a strange issue with this extension.
      Simply cannot activate via the extension via this one.
      Skin extension returns itself to the right part of the Sketchucation Tools window (as Disabled - see attached image)
      Thank you in advance for any piece of advice!
      TIGT 1 Reply Last reply
      • RTCoolR
        RTCool
        I'm getting an error on a dozen plus plugins when trying to install in SU 2024 on my 2016 Macbook Pro saying that the file could not be unzipped. Didn't have this problem on 2023 with this machine, or with 2024 on a new M1 Max Macbook Pro. Any ideas?
          TIG Moderator @pipinek
          @pipinek
          If you try and load it using the native Extension Manager [and restart] what happens ?
          RTCoolR 1 Reply Last reply
          • RTCoolR
            RTCool @TIG
            @TIG Looks like my mistake. Without checking carefully, I thought the last version I had downloaded was current, but apparently, it was 4.3.1 and that was causing the problem. Now that 4.4.1 is installed it's working OK.
            I must say, the new version seems laggy. We'll see.
            • mariochaM
              mariocha
              download page still says 'Latest is 4.4.0 ' πŸ™‚
              %(#008000)[Mario C.
              • mariochaM
                mariocha @Rich O Brien
                @Rich-O-Brien
                Hi Rich,
                minor thing; the download page still says Latest is 4.4.0 πŸ™‚
                %(#008000)[Mario C.
                  Rich O Brien Moderator @mariocha
                  @mariocha said in Sketchucation Tools 4.4.1:
                  @Rich-O-Brien
                  Hi Rich,
                  Sorted now...good find
                  • ntxdaveN
                    ntxdave
                    When I try to reply or add a post and want to include a file (like a skp file) I do not see the link to add a file. I also tried just dropping an skp file in the response box but got an error message that said I do not have the privilege to do that. I do not recall ever having that problem in the past. Can someone help?
                    Press F1...thank me later
                    • P
                      PSG64 Newcomers @ricky2468
                      @ricky2468 said in Sketchucation Tools 4.4.1:
                      I have purchased licenses for Fredo bundle, i.e. RoundCorner etc.
                      Instructions say to update Sketchucation Extension Store to activate fredo plugins. I now have Extensionstore v4.4.
                      It is empty. No plugins are listed. Before I update it showed all my plugins.
                      I cant see how to view extensions and apply my new Fredo licenses.
                      Hopefully someone can help me resolve the issue.
                      I have the same problem. All my Fredo Licenses were active now when I try to use the Fredo Plugins i get the message that the trial has ended (even Round Corner which I thought was free and didnt require a paid license?). If I go into my license manager to release the seat it is not allowing this? How can I release the seats to activate the license again?
                      Paul
                        Rich O Brien Moderator @PSG64
                        @PSG64
                        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                        P 2 Replies Last reply
                        • P
                          PSG64 Newcomers @Rich O Brien
                          @Rich-O-Brien Hi Rich, heres the output...
                          • P
                            @Rich-O-Brien Rich just checked the LIcense info again and it appears that the problem only exists on the joint push pull, curvizard, fredoscale, toposhaper licenses? The curviloft is not showing any licenses?
                            Regards
                            Paul
                              @PSG64 Your output shows you have not activated licenses on this device. Except for Tools on Surface and Visuhole.
                              Every device needs you to activate licenses. If you go to https://sketchucation.com/webshop/my-licences.php you can see a list of devices you have activated on.
                              Clicking the Chevron icon will reveal more info...
                              If you see a scenario like the above where there's no Checkbox that means you activated on a device that was running an older release of Sketchucation Tools that did not enable online releasing.
                              Updating Sketchucation Tools and Libfredo on these devices will force the Checkbox to appear.
                              Does this help?
                              P 1 Reply Last reply
                              • P
                                @Rich-O-Brien Hi Rich, I have gone through and checked that both Sketchuation tools and Libfred6 are latest versions on both my Laptop and Work PC. My Laptop seems to have all the correct licenses in place. See output
                                I will go through my Work PC and redo all the licenses and provide the output from that. Regards Paul
                                  @PSG64 Looks good so far.
                                  At https://sketchucation.com/webshop/my-licences.php you may have activations on devices you no longer have access to. In these instances, if there's no checkbox to release, your seat is frozen to that device.
                                  As I explained, these devices had licenses activated prior to our online release functionality. To remedy that just send us an email at support@sketchucation.com so you don't expose sensitive information publicly and we'll work through those with you.
                                  Ideally, you want you be in a position where you have full control over releasing seats at a device and online. This is only possible by keeping extensions updated.
                                  • P
                                    @Rich-O-Brien Hi Rich, thanks for your help on this. Here is the output from my Work PC.
                                    bade7c3b-b1d9-4cb2-aa0b-aecbb52a3eef-image.png.
                                    It looks like the only license with a problem now is the Fredo pushpull as all the Fredo collection tools appear to work on both systems. I only use my Laptop and Work PC so its not an issue at the moment not being able to free up the 3rd license. I will do as you suggest and email support direct. Thanks again for your help.
                                    Regards
                                    Paul
                                      Jerome_971
                                      I don't know if it is the right place to post.
                                      I am under Win10 and Sketchup Make 2017
                                      I have a display issue with Sketchucation Tools : some icons are missing.
                                      sketchucation.com and fontawesome.com are in whitelist in internet options.
                                      I've installed IE-11 and I still have that issue.
                                      Can you help me to solved it ?
                                        TIG Moderator @Jerome_971
                                        @Jerome_971
                                        @Rich-O-Brien or @Gabor will get back to you with detailed advice.
                                        I think this has been reported a few times before and resolved...
                                        IE11 is not needed with newer dialogs which use a built-in Chrome browser system
                                          Rich O Brien Moderator @TIG
                                          @TIG @Jerome_971
                                          Icons are served via Javascript, which at runtime, deliver icons via SVG or CSS depending on browser type.
                                          The JS is piggybacks on CloudFlare to make sure you receive icons from nearest server to you.
                                          That said, we've no way to test on SketchUp 2017 so reproducing this not possible.
                                          Your only way to get us any info would be to right click the ExtensionStore dialog and choose Show Dev Tools
                                          Then in Dev Tools under Console you see some error messages...
                                          My suspicion is something is blocking the javascript locally on your system
                                          J 1 Reply Last reply
                                            Jerome_971 @Rich O Brien
                                            @Rich-O-Brien @TIG
                                            Thanks for your responses.
                                            There are errors on Dev Tools Console :
                                            • 2 / 3
