    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 649.3k Views 161 Watching
      sashapepperspray
      Is clothworks going to be updated to work with sketchup 2024?
      (I get the following error when i try loading it
      Error: NoMethodError (undefined method exists?' for File:Class) c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:71:in block in require_all’
      c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in each' c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in require_all’
      c:/users/tenen/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/main.rbe:746:in <main>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval’
      C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load’
      C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in register_extension' C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in module:ClothWorks’
      C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:7:in module:AMS' C:/Users/tenen/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:6:in <top (required)>’)
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @sashapepperspray
        @sashapepperspray
        The method File.exists? has long been deprecated, but worked.
        In the latest Ruby version it doesn’t - File.exist? - works in v2024 and older versions as well.
        Many developers are working to adjust their code accordingly.
        Have patience and post any instances in an affected extension's thread - as there are 100s of 1000s of line of code with the tiniest corrections needing to be found and change, then the extension re-encrypted and signed…
        Many authors have already fixed their extensions, so look regularly to see if there’s already an update available…
        • EdsonE Offline
          Edson
          Since I installed Sketchup 2024 I keep getting a message to the effect that ClothWorks has to be updated to run on it. Could you possibly do it? Thanks.
          Edson
          http://www.mahfuz.arq.br
          B 1 Reply Last reply Reply Quote 0
            burakberlin @Edson
            @Edson same here, i would appreciate the update for SU 2024.
            best,
            burak
              a4jp.com @Anton_S
              @Anton_S Any updates for SketchUp 2024?
                dbrazina
                I have just upgraded to Sketchup 2024 and Clothworks plugin will not load. I get the following error messages. I have uninstalled and reinstalled the plugin.
                Extension Errors Report
                SketchUp: 24.0.484
                OS: Windows 11
                Ruby: 3.2.2
                Extension: ClothWorks (1.7.7a)
                Error: NoMethodError (undefined method exists?' for File:Class) c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:71:in block in require_all'
                c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in each' c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/extension_manager.rbe:69:in require_all'
                c:/users/dave/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/ams_clothworks/main.rbe:746:in <main>' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in eval'
                C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in load'
                C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in register_extension' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:38:in module:ClothWorks'
                C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:7:in <module:AMS>' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/ams_ClothWorks.rb:6:in <top (required)>'
                Rich O BrienR TIGT 2 Replies Last reply Reply Quote 0
                • Rich O BrienR Online
                  Rich O Brien Moderator @dbrazina
                  @dbrazina said in [Plugin] ClothWorks v1.7.7 - 2 May 2022:
                  Its not yet compatible with SketchUp 2024. The developer is aware and plans a release ASAP
                    TIG Moderator @dbrazina
                    @dbrazina
                    The error relates to
                    File.exists?()
                    this method was deprecated long ago and replaced with
                    File.exist?()
                    which is grammatically incorrect in English, but hey Ruby is international !
                    The older version had worked for many years 'in tandem', but it's now been removed from the newest Ruby version which ships with v2024.
                    So this now breaks older scripts that still include it...
                    It's relatively easy to fix - I found 2 instances that needed fixing in the various SketchUcation tools scripts when I was preparing them for this current version !
                    Another issue that the ClothWorks developer faces is that his code relies on some functions within some .so/.bundle files for different OSs, so he will need to compile new versions of these for compatibility with v2024's Ruby version...
                    • jo-keJ Offline
                      jo-ke
                      I hope, it will be updated.
                      http://www.zz7.de
                        Anton_S
                        Hi all, the ClothWorks is now updated for SU2024. Thank you for your patience!
                        F X 2 Replies Last reply Reply Quote 5
                        • F Offline
                          FlawinneF
                          I receive an error message when importing a license.
                          18-Apr-24 19:13:56 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                          18-Apr-24 19:00:51 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                          18-Apr-24 18:59:02 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                          18-Apr-24 18:58:45 validate_response_error Error in the License Validation--Response from Sketchucation: License seats exceeded.
                            TIG Moderator @FlawinneF
                            @FlawinneF
                            Have you got the newest version of the SketchUcation Tools installed ?
                            It handles the licensing system.
                            You can also login to you own licenses on this site using the link in the Extensions > SketchUcation submenu... My Licenses at SketchUcation...
                            https://sketchucation.com/webshop/my-licences.php
                            There you can manage all of your licenses...
                            F 1 Reply Last reply Reply Quote 0
                            • F Offline
                              FlawinneF @TIG
                              @TIG thank you, it's activated
                              • F Offline
                                FlawinneF @Anton_S
                                @Anton_S Why not fix the problem of the bar remaining active on Mac !!!
                                if tb.get_last_state == TB_NEVER_SHOWN
                                  tb.show
                                else
                                  tb.restore
                                A 1 Reply Last reply Reply Quote 0
                                  Anton_S @FlawinneF
                                  @FlawinneF Thanks for that tip. I never knew about the get_last_state or restore. Will utilize in next release
                                    TIG Moderator @Anton_S
                                    @Anton_S
                                    I use this usually
                                    tb.show if tb.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                                    Has the same result...
                                    A 1 Reply Last reply Reply Quote 1
                                      Anton_S @TIG
                                      Version 1.8.0 released.
                                      • Fix adaptive grid not working properly for some models on Mac OS X
                                      • Show toolbar properly on Mac OS X. Thanks @FlawinneF and @TIG
                                      F 1 Reply Last reply Reply Quote 1
                                      • F Offline
                                        FlawinneF @Anton_S
                                        @Anton_S
                                        Sorry I didn't, say thank you sooner, thank you for everything 🙂
                                        • X Offline
                                          xinige @Anton_S
                                          @Anton_S Hello, Mr. Anton. I don't know when you will initiate the redevelopment of MSPhysics. As far as I know, countless people are looking forward to this project. Alternatively, you can develop a plugin that can partially implement certain functions.
                                          For example, a simulation tool that can implement simulation functions similar to fusion360 and SolidWorks may not require embedding a physics engine (I'm not sure), but only adding axes and motors, as well as collision detection. Used for designing machinery, mechanical gif diagrams, and checking the rationality of mechanical design in sketchup. I hope to receive your reply.
                                            rick149
                                            Anton
                                            ClothWorks is amazing
                                            I still use MSPhysics because nothing else is as good at what it does
                                            Can you supply me with code to
                                            1. turn layers on and off
                                            2. hide/unhide objects
                                              for me to use with my variables, keydown,, ontouch and ontick events in my MSPhysics scripts
                                              old msphysics video example here...
                                              https://www.youtube.com/watch?v=MTfpvgY1HBk
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
