    Rayscaper Alpha Version Available
    114 Posts 14 Posters 17.3k Views 14 Watching
    • ntxdaveN Offline
      ntxdave
      @pixelcruncher said:
      @ntxdave said:
      @majid said:
      Wow, some good news....
      Since you are looking for a job, perhaps you should contact Thomas as well. ๐Ÿ˜„
      Really wish I could hire someone talented like you Majid, but I havenโ€™t made a lot of money from Rayscaper yet. Last time I counted it was $0.0 ๐Ÿ’š
      I have been talking to Fletch from TR. He has been very gracious with his time and gave great advice. I asked him to try Rayscaper and give his opinion.
      Cheers,
      Thomas
      Thanks for reaching out Thomas. These see very talented individuals. I hope that something can come about.
      Press F1...thank me later
      • majidM Offline
        majid
        Thanks, Thomas and Dave.
        I wish I had some spare time to do a favor for RS.or lucky to work with you, but am busy making some money to support my family and stay in the Netherlands for the "search year" period. Somehow challenging ๐Ÿ˜„.
        • ntxdaveN Offline
          ntxdave
          I wish I had some spare time to help develop RS, as a beta tester ...or lucky to work with you, but am busy making some money to support my family and stay in the Netherlands for the "search year" period. Somehow challenging ๐Ÿ˜„.
          Glad you have an income. ๐Ÿ˜„ ๐Ÿ‘ Was just trying yo help if possible. ๐Ÿ˜„
          I hope one of these days I can back to โ€œmodelingโ€ and rendering. Would love to be able to try Rayscaper as well. ๐Ÿ˜„
          Given the status of TR, I hope Thomas and Fletch & Chris ab work something out. ๐Ÿ˜„
          • jo-keJ Offline
            jo-ke
            today I started a new test with rayscaper.
            finished render is still grainy and the texture at the picture on the wall messes up.
            http://www.zz7.de
              That render looks very promising!
              There's a regression in the current release; textures are not automatically scaled when converted to Rayscaper. You can manually work around this by setting the scaling in Rayscaper.
              Rayscaper texture scaling.
              Assuming your texture scale in SketchUp is in millimeters, the formulate is: 1 / ((texture_scale_mm / 10) / 2.54 inc/cm). So for this example: 1 / ((1828.8 / 10) / 2.54) = (1 / 72) = 0.013888 = 0.014. So basically the reciprocal of the size in inches.
              Again, I will fix the option to sync this.
              For the grainy noise:
              1. How many samples/px have you configured?
              2. Are you using AI denoise? That should resolve most of the noise.
              Rayscaper render settings.
              Cheers,
              Thomas
              • jo-keJ Offline
                jo-ke
                I used the default settings
                http://www.zz7.de
                  Do you mind mailing me the scene packed with the textures when you have time? You can pack the scene via the "Extensions > Rayscaper > Create Archive" menu. Can you also send me the log file? For some reason, it feels that the denoiser is not activated on your machine.
                  I appreciate your help!
                  Thanks,
                  Thomas
                    sashapepperspray
                    Is it possible to make that if I insert a light in a component, all instances of the component get a light added?
                      Yes, improving the light component instances is planned for 1.0. As you already observed, lights don't work if they are part of a group or component.
                      Cheers,
                      Thomas
                      • majidM Offline
                        majid
                        This would be a nic option and I am wondering if it is possible to keep the intensity the same but use bucket tool to change the color of some?
                        I mean if it is applied "inside" the component, all instances change, if applied without opening the component it changes the color of that particular one...
                          Thatโ€™s a good idea Majid, I will put it in Rayscaperโ€™s backlog.
                          • majidM Offline
                            majid
                            After a while installed the latest version and a, wondering how may I copy the same material texture to the normal map? any copy/apst or drag/drop option?
                              You can drag and drop the same image multiple times from a file browser. But you are pointing out a good worklow improvement here, you should be able to at least right-click and copy/paste. I will put it on the list, and expect it in one of the upcoming releases.
                              • jo-keJ Offline
                                jo-ke
                                in the current render there is an ugly branding. So I can't use the result.drh001.png
                                http://www.zz7.de
                                  pixelcruncher Extension Creator @jo-ke
                                  Hey @jo-ke - now that Rayscaper is in beta, I started selling discounted beta licenses: https://sketchucation.com/purchase-smart.php?plugin=rayscaper - The watermarks are a limitation of the free version.
                                  Cheers,
                                  Thomas
                                  • 6 / 6
